New! Dark mode!
(Topic ID: 269589)
Diner Pinball Won’t Boot!
By Pinball-DOOD
4 months ago
  • 83 posts
  • 9 Pinsiders participating
  • Latest reply 3 months ago by Pinball-DOOD
    There have been 10 images uploaded to this topic. (View topic image gallery).
    There are 83 posts in this topic. You are on page 2 of 2.
    #51 3 months ago
    http://techniek.flipperwinkel.nl/wms11/index3.htm
    internet -- how do you check for chip shorts on the backside of the master display board?
    Seems tricky.
    #52 3 months ago
    Gotcha! Well without J2 plugged in, the game starts just fine. We just don’t get a display
    #53 3 months ago
    http://73.21.92.229/sys11/index3.htm
    "Testing the UDN7180/UDN6118 Chips and Score Glass for Shorts."
    good luck ! DMM set to diode test... 7 * 2 tests per chip... hunt for a difference!
    #54 3 months ago
    Quoted from Pinball-DOOD:
    Sounds good! Since I don’t have the schematics in front of me, what is U19?
    U19 is a UDN7180, which is obsolete, pricey, and hard to find. I have a few around here that are "pulls" from boards with bad glass.
    Chris Hibler - CARGPB #31
    http://www.ChrisHiblerPinball.com/Contact ... for board repairs
    #55 3 months ago
    Quoted from mof:
    Thanks so much, man!
    Quoted from ChrisHibler:
    Ohh, gotcha.
    #56 3 months ago
    So black lead on a ground and red lead should read 0.7V on each leg?
    7CDFC897-7140-4270-B194-C54CD0B78E2C (resized).png037CBF27-4D1B-4FEB-A033-6C0E26FA9E24 (resized).png
    #57 3 months ago
    Yes. You can compare that readings from the suspect 7180 to others on the board. The bird has several of them.
    Http://chrishiblerpinball.com/contact
    http://www.PinWiki.com/ - The new place for pinball repair info
    #58 3 months ago
    #59 3 months ago
    So there was one leg on U19 that had a far lower reading than all of the other legs on U19 and U20. Do we have a short? If so, should I recommend him buying a new display?
    #60 3 months ago
    In other words, would buying a new display be a good idea? I think he just wants the easy way out
    #62 3 months ago
    Well...if he wants the easy way out, then sure...new display.
    #63 3 months ago
    #64 3 months ago
    Hope you get the satisfaction of replacing the part and seeing it test good.
    #65 3 months ago
    I vote for the red LED display. It looks good in Diner.
    #66 3 months ago
    Thanks all! I learned a lot from this thread. Red would look killer
    #67 3 months ago
    PinLED is the way to go.
    Looks better and draws way less power.
    #68 3 months ago
    Got it connected! But we get this...
    #69 3 months ago
    Got it connected! But we get this... [quoted image]
    Maybe ribbon cable not hooked up right?
    #70 3 months ago
    He sent this! It could possibly be a bad ribbon cable maybe? I believe everything is hooked up okay
    #71 3 months ago
    Looks like you need to flip your ribbon cable over at the MPU so that the red stripe is to the right, not the left.
    #72 3 months ago
    We will try this! Thanks! I was trying to walk him through it but I think we miscommunicated
    #73 3 months ago
    He said he this is the way he has it. The bottom display works fine and the upper display is messed up
    5F2944DF-62A4-4E4F-843A-26B000296567 (resized).png9A0660A3-DE91-4E40-A003-674F52C83399 (resized).png
    #74 3 months ago
    That is correct. If pressing the segment test on the display shows all digits work correctly on the top and bottom display, either that ribbon cable is bad or the MPU. Could flip the ribbon cable at both ends to see if the results change.
    #75 3 months ago
    Quoted from PinballManiac40:
    We will try! Thanks!
    #76 3 months ago
    Was this machine in a known state or unknown to start? I don't recall whether we expect everything to be great and something recently changed, or is this a recent pickup, and an unknown.
    Continuity check the ribbon cable wire by wire. That's low hanging fruit to isolate. If the DMM points are not small enough, wrap a dead diode leg (clip the legs off) around the end of each probe tip.
    -mof
    #77 3 months ago
    He tried a ribbon cable from another game and go the same result. Any ideas? Thanks!
    #78 3 months ago
    result?
    #80 3 months ago
    Pushing the segment test and all displays go on like normal
    #81 3 months ago
    Definitely not the ribbon cable. Anywhere else?!
    #82 3 months ago
    Need to see a picture of the MPU below the battery pack to be sure there is no battery damage to U41. Above the battery pack looks great.
    #83 3 months ago
    I will get a pic!
    $ 69.95
    $ 1,099.00
    $ 19.95
    Filament Printing
    Metal-Mods
    $ 139.99
    Great American Pinball
    French Fry - LED Out of stock
    $ 369.00
    $ 26.95
    $ 149.00
    $ 11.95
    $ 89.99
    $ 20.99
    Lee's Parts
    $ 38.75
    The MOD Couple
    $ 159.00
    Sparky Pinball
    Game Room Info Shop
    $ 9,500.00
    Lighting - Backbox
    Various Other Swag
    $ 122.00
    $ 18.00
    The MOD Couple
    $ 159.00
    $ 130.00
    Pinwize.com
    $ 159.00
