(Topic ID: 269589)
Diner Pinball Won’t Boot!
By Pinball-DOOD
    There are 83 posts in this topic. You are on page 1 of 2.
    #1 3 years ago
    Hey all! I have a Diner that won’t boot at all. I was told that it was working just recently and when the batteries were replaced, it stopped booting. GI are on but no display and no attract mode. We do get a test bong but that’s about it. I reflowed solder on the power supply and CPU headers and then even touched up solder on the ICs. Any idea what could be the culprit? Thanks! One of the pics shows a chip that looks a little toasty, not sure if it would be an issue though
    51EEE418-87EF-4A3F-8BE1-4EBF9C5498C4 (resized).jpeg51EEE418-87EF-4A3F-8BE1-4EBF9C5498C4 (resized).jpeg8947F71F-9160-4819-B0E0-262481409E77 (resized).jpeg8947F71F-9160-4819-B0E0-262481409E77 (resized).jpeg
    #2 3 years ago
    Go directly to the power supply board and measure the DC output voltages.
    #3 3 years ago
    Quoted from KenLayton:
    Will do. What am I looking for here? Haha sorry I’m learning
    #4 3 years ago
    bong sound indicates music board is booting with required 5V 12V and -12V voltages present
    #5 3 years ago
    Quoted from PINTEC:
    Ah, good point. Anywhere I should check first?
    #6 3 years ago
    Quoted from Pinball-DOOD:
    Check these 3 test points.
    #7 3 years ago
    Quoted from GRUMPY:
    One lead on the ground braid, and one on the TP, right? on Diode test? And what measurements should I be getting? Thanks!
    #8 3 years ago
    Set meter for DC voltage. Black to ground braid, red to test points.
    #9 3 years ago
    Quoted from GRUMPY:
    Gotcha, Am I checking for a beep?
    #10 3 years ago
    Nope, tell us what the meter reading is.
    #11 3 years ago
    checking for a beep
    in DC voltage mode -- there's no beeping =)
    Check page 84 of your manual to see the voltages on the schematics for the power supply board.
    To get ideas on what to check in what order -- study this:
    http://techniek.flipperwinkel.nl/wms11/index2.htm
    Also - you can search for "test points" to quickly see what values to test for.
    #12 3 years ago
    Quoted from GRUMPY:
    Will do
    #13 3 years ago
    I will conduct measures at the test points and get back to you all!
    #14 3 years ago
    Just to clarify, do I obtain these measures with the game powered on or off??
    #15 3 years ago
    It would be hard to measure power with the power turned off.
    #16 3 years ago
    Quoted from GRUMPY:
    Hahah, just want to make sure
    #17 3 years ago
    When testing resistance/continuity/beep, the game would be off. Voltage measurements are always with the game on.
    #18 3 years ago
    Got the test point readings!
    TP 1: 05.1 (normal)
    TP 3: 11.7 (normal)
    TP 4: -14.7 (incorrect)
    I think TP4 is the issue! Could it be that bridge rectifier 1 is the issue since it’s in TP4’s circuit?
    #19 3 years ago
    TP -4 is fine.
    Now find the 5 volt and ground TPs on the cpu board. Measure these with the volt meter.
    #20 3 years ago
    Quoted from GRUMPY:
    TP -4 is fine.
    Okay gotcha. I hate to be trouble but could you maybe explain how I’d do this? This is something new for me!
    #21 3 years ago
    Turn on game. Put meter on DC volts setting. Put red lead the CPU 5 volt test point. Put black lead on the CPU ground test point. Let me know what you read.
    #22 3 years ago
    Quoted from GRUMPY:
    Okay, thanks! Is the tp2 a ground?
    #23 3 years ago
    Left is the 5 volt test point and right is the ground test point.
    #24 3 years ago
    Quoted from GRUMPY:
    Huge help! Thanks
    #25 3 years ago
    Just out of curiosity, what would you guess could be the issue at this point? Have we omitted the Power Supply from being the issue? Thanks!
    #26 3 years ago
    You are needing to determine if the power supply 5v output is getting to the cpu board test point.
    What you read will tell about the condition of the wires and connectors between the power supply board and the cpu board.
    #27 3 years ago
    Quoted from keith20mm:
    #28 3 years ago
    Did you check for any loose or accidentally unplugged cables?
    Bad or loose fuse?
    Just maybe its something simple?
    #29 3 years ago
    Quoted from pinballinreno:
    Bad or loose fuse?
    Oh my god, it could totally be a fuse. The owner of the game said he checked fuses but I never actually checked myself haha
    #30 3 years ago
    Then again, I think it’s something else. I checked all connectors and even reflowed solder
    #31 3 years ago
    Quoted from GRUMPY:
    TP -4 is fine.
    I seriously don't know how you can tell any of these boards will have bad solder not even knowing what board is at fault.
    I have never seen any bad solder on any system 11 games in my 11 years, unless someone did a bad repair job.
    So here we wait for your answer to Grumpy's post.
    #32 3 years ago
    Once you establish 5v is at least 4.8v on the CPU board, please report what is the state of the blanking and diagnostic LEDs on the CPU board.
    #33 3 years ago
    Quoted from PinballManiac40:
    Okay will do.
    #34 3 years ago
    I haven’t been able to get out there to take the measurement yet but, I have an account of the led flash sequences. Upon initial start up, the left most LED stays on, the middle LED blinks 5 times, and the far right LED blinks 10 times.
    #35 3 years ago
    You still need to measure the 5v on the MPU. If it is good, sounds like there is a bad part on the board. What all work was done to the MPU? Just wondering to see if it can be potentially related the error codes you are currently seeing.
    #36 3 years ago
    Gotcha. Upon removing the MPU, it appears everything was in tact and untouched. Traces were perfect and no hack work was done. I’m wondering if there is a bad component somewhere (if it isn’t a wiring issue)
    #37 3 years ago
    Before I go out to measure, is there anything I should look for if I can confirm there is proper voltage? I just want to minimize the number of times I have to go out there
    #38 3 years ago
    Just the 5v on the MPU as Grumpy mentioned. If is above 4.8v, better consider sending it to ChrisHibler for repair. MPU bootup issues are too complicated to direct anyone to a part to replace. He can install NVRAM at the same time.
    #39 3 years ago
    Well sir. Good advice provided in this thread.
    Let’s hear about that 5V on the MPU.
    Happy to help.
    Chris Hibler - CARGPB #31
    Http://chrishiblerpinball.com/contact
    http://www.PinWiki.com/ - The new place for pinball repair info
    #40 3 years ago
    Quoted from ChrisHibler:
    Happy to help.
    I will report back to you sometime tomorrow regarding the 5 Volts. Thanks!
    #41 3 years ago
    Looks like we have 5v on the CPU! So I guess we are looking at a bad component on the board. I will give ChrisHibler ’s number to him! Thanks!
    #42 3 years ago
    Looks like he is not down to send them in! Is it possible you all could walk me through where to start? Maybe common culprits on the board? I feel confident in fixing it, just need some guidance on this era system 11
    #43 3 years ago
    There could be several reasons for the failure.
    My advice again is to send it to a competent repairman.
    If he buggers up the board in an attempt to repair it, it will make the actual repair that much tougher.
    What competent repairmen hate to hear, "I'm going to try it myself. If I mess it up, I'll send it to you". Argh.
    http://www.ChrisHiblerPinball.com/Contact ... for board repairs
    #44 3 years ago
    I recommended sending them in! But he is still on the fence. We found that the F3 fuse keeps constantly blowing. What could this be?
    #45 3 years ago
    It only blows when a connector is plugged in!
    #46 3 years ago
    Unplugging J2 allows the game to boot! No display
    #47 3 years ago
    F3 on which board? power or aux power?
    What could this be?
    Search "site:pinside.com" + "system 11C" + "F3" or "site:pinside.com" + "Diner + F3" to get a sense of the range of ideas on what to check.
    also, you can substitute Diner with other 11c's
    #48 3 years ago
    Progress! Looks like you may have things isolated to the master display board.
    https://www.pinwiki.com/wiki/images/d/d2/D-12232.jpg
    https://pinside.com/pinball/forum/topic/system-11c-display-issue-single-digit-broken
    shot in the dark:
    With the power off -- check for a short on U19 UDN7180
    #49 3 years ago
    Quoted from mof:
    https://pinwiki.com/wiki/index.php?title=File:WMS-D-12502-1.jpg
    shot in the dark:
    Sounds good! Since I don’t have the schematics in front of me, what is U19?
    #50 3 years ago
    get them in front of you.
    https://www.ipdb.org/machine.cgi?id=681
    -mof
    This page was printed from https://pinside.com/pinball/forum/topic/diner-pinball-wont-boot/page/1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
