replaced LED's with incandescents? if so, then yes.
Quoted from weaverj:replaced LED's with incandescents? if so, then yes.
No, just removed the broken LED's and did not replace them with anything until I can get the replacements in. So right now, the backbox only has about 1/2 the LED lamps installed.
I did notice that the ground wire from the speaker to the bottom of the back box was not firmly screwed in with the wing-nut. I tightened it and it made no difference.
When I was working on the game originally, I turned the volume off since I didn't want to deal with sounds for a long period of time. When I went back a few hours later, I still had the volume off, but that's when I heard the buzz. I'd be curious if I can hear it with the volume at a normal level.
Maybe I'll try reseating the cables and the sound board screws (none are missing that I can see)
A follow up..,
No difference
-Tried another outlet
-Pull connectors and reattach
-Tightened screws
Made sound louder
-Removed screws from soundboard
I'm trying to remove the cup and saucer. I understand there is a 90 degree L bracket behind the playfield that keeps this in place.
I tried lifing the entire playfield straight up and lifting it up off the hinges so I could access it, but was not successful.
Can anyone recommend the easiest way to do this?
Thanks.
Quoted from Cmjb13:Anyone know what the best way is to access the target decals so I can replace them?
T nuts are what is on the bottom. Posts svrew into them and sometimes they use loc tite and they break.
Quoted from Cmjb13:I'm trying to remove the cup and saucer. I understand there is a 90 degree L bracket behind the playfield that keeps this in place.
Thanks.
I would disconnect the wires in the back box and remove the playfield, personally.
Quoted from Tomass:I would disconnect the wires in the back box and remove the playfield, personally.
Got it. Thanks
Thanks.
Definitely don't need to remove the playfield or really any connectors. From earlier in the thread. Doing this I could get plenty of space to remove the cup and the whole back panel.
I’m in the process of replacing the LED’s
Are the black slots on the back box to be filled with 13V flasher LED’s?
Also, the top row on the pcb on the back box (that lights the customers) only takes 13v?
E5B52656-EE1D-41C9-8458-38B62A06BAE3 (resized).jpegF6827D60-F53A-4CEB-AD95-BBE456DF9970 (resized).jpeg
Quoted from Cmjb13:I’m in the process of replacing the LED’s
The top 3 are flashers, the bottom 3 are GI (555's).
Quoted from TheOnlyest:The top 3 are flashers, the bottom 3 are GI (555's).
Appreciate the info, thanks
Anyone here have a really good pic of the area between the lower flippers? im helping a friend to repaint some of the black figures (a dog and some women i think it was) due to being worn away abit and kinda need a pic that shows the white lines in the black figure areas.
Quoted from Luzur:Anyone here have a really good pic of the area between the lower flippers? im helping a friend to repaint some of the black figures (a dog and some women i think it was) due to being worn away abit and kinda need a pic that shows the white lines in the black figure areas.
I can try to get something for you later tonight if you don't get one sooner.
Quoted from Cmjb13:I can try to get something for you later tonight if you don't get one sooner.
Thanks, i wont meet up with him until after christmas so you have lots of time.
Sorry, glass is still on. Do you need better?
1545361769937-2107054085 (resized).jpg1545361790076-1442186198 (resized).jpg15453618039751630599748 (resized).jpgI noticed one of the flipper buttons had an E clip and one did not.
I replaced the buttons from blue to red and am having a problem trying to reinstall the E clip.
Are they needed?
Quoted from Cmjb13:Are they needed?
Depends on the buttons.
To the best of my knowledge:
The original buttons use a spring (on the outside of the cabinet) and have the e-clip.
Remakes have no spring, and have a plastic lip, with no groove to put an e-clip on, and have no use for them.
-mof
Quoted from Tomass:Sorry, glass is still on. Do you need better?
Those are good enough, but i need one of the dog below aswell, if you could. Very much thanks anyway for your work.
Quoted from Luzur:Those are good enough, but i need one of the dog below aswell, if you could. Very much thanks anyway for your work.
Quoted from Cmjb13:I was replacing the star posts and a couple of the "claw holders" broke that allow the screws to go into them.
Is there a specific term for these?[quoted image][quoted image]
Those are called t-nuts. It is common for these to break during removal on System 11 games like Diner because they were threadlocked (like a blue glue) into place during manufacture to prevent them coming loose during play. I hate that this was done and always have a few break on me. Gottlieb Sys 3 games have this issue too.
Relatively easy to replace if you have them on hand.
https://www.pinballlife.com/6-32-tee-nuts.html
The common sizes are 6-32, 8-32, 10-32
RussM
You can either:
1. Raise the drop target into the Up position and jam a piece of folded cardboard under the reset plate to hold it up while you install new decals from the top side
2. Disconnect the connectors (2 I think, one to power the reset coil and one for the switches) and unscrew the bracket and pull the whole assembly out.
RussM
Quoted from mof:Depends on the buttons.
-mof
Here’s a pic. Seems that this has the plastic lip.
03BCBA73-FA8A-4E34-9B0D-0CC9F287ECFD (resized).jpegQuoted from Cmjb13:The ice cream floats on the sides of the flippers have 3 screws/post studs.
Can anyone tell me which one goes in each hole?
What exactly are you needing? I thought pics, but it is already installed in your pic. I might be able to help.
Quoted from Tomass:What exactly are you needing? I thought pics, but it is already installed in your pic. I might be able to help.
I was able to get the right pieces from the pile I had. Next time, I’ll be sure I label everything to make it easier to assemble.
Had a chance to work on getting a Pinduino to work in a Diner this weekend controlling addressable LEDs in the cup. Let me know your thoughts. Order up!
Source code available: https://github.com/elyons/professor_pinball_pinduino_sketches/tree/master/Diner-Cup
The lighting sequence looks quite nice. Is the Pinduino sensing game activity in any way? I watched the video and it seemed like the behaviour changed initially then I could not tell after that.
Quoted from BJM-Maxx:The lighting sequence looks quite nice. Is the Pinduino sensing game activity in any way? I watched the video and it seemed like the behaviour changed initially then I could not tell after that.
Thanks! Yes -- the pinduino senses game activity using P11 and P12 on the driver board. The core pinduino library and all the code I write is open source and available, and the controller for the pinduino is an Arduino nano. You can take a look at my code (if you like to read code) to see that it is programmed to sense things like the cup flashers and dine-time flasher for triggering various lighting effects.
Just a heads up, I'm probably going to try and do a Diner coffee cup repro sometime in the near future. Gauging interest in this thread - https://pinside.com/pinball/forum/topic/diner-coffee-cup-group-buy
Quoted from Cmjb13:Does anyone know if the playfield glass that came from the factory was tempered glass?
Most definitely.
Hello fellow Diner owners. I've been doing a lot of 3D design and printing at my local library. After having some luck designing dalek pinball posts for Dr. Who I wanted to freshen up my Diner. The existing plastic switch covers for the ramps are big and boring. I hope y'all like these updated ones. Feel free to download the file and print your own.
https://www.thingiverse.com/thing:3391247
DinerHotdog (resized).JPGDinerHotdogs (resized).JPGQuoted from cadmium:Hello fellow Diner owners. I've been doing a lot of 3D design and printing at my local library. After having some luck designing dalek pinball posts for Dr. Who I wanted to freshen up my Diner. The existing plastic switch covers for the ramps are big and boring. I hope y'all like these updated ones.
Very creative!!
Quoted from dozer1:New member request. Is there supposed to be a deflector shield mounted in back of the cash register? If so, mine is missing. Could someone take a pic of it? Just recently picked this up and have it all apart now for a good shop out.
Here are some pics of mine.
IMG_8353 (resized).jpgIMG_8347 (resized).jpgIMG_8349 (resized).jpgIMG_8351 (resized).jpgtstone , think I found my deflector shield for the cash register. Looking through my teardown pics I see this. Also saw it laying on my parts table and new it looked like the part, but knew it wasn't on the cash register. Looks like an old shop out fail.
DSCF6804 (resized).JPGQuoted from dozer1:Anybody have some good custom apron cards for Diner?
There's one on the 1st page of this thread
This page was printed from https://pinside.com/pinball/forum/topic/diner-clubowners-and-previous-owners-welcome/page/15 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
