Hi All,
Since I picked it up I have had trouble with my Diner's display. Some of the letters show up faint or not at all, but every character shows up fine in test mode. I have already replaced the power supply board and bought new ribbon cables. I was going to place an order for either a pinscore or rottendog display tonight, However I figured I would check with the vets around here first to see if a new display would fix the issue or should I be trying something else first (before throwing more money at this problem ). I've attached a few images below to show you what my display is doing. Thanks !
The "AU 25" is very dim. Seems to be just thjose letters effected during gameplay.
You can see the "I" character is faint and tends to flicker.
