The A/C select relay clicks on and off 8 times on power up and then it stays activated. Q8 (TIP122) on the CPU tested fine but I replaced it anyway with the more robust TIP102. Still having the same problem with the relay staying activated. The relay is also new. When I got the game the relay contacts were melted together causing solenoids 1-8 to not work.
