(Topic ID: 296781)
Dimensions of Hyperball and Rapid Fire?
By shevett
3 months ago
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 3 months ago by SilverUnicorn
#1 3 months ago
I just managed to score these two machines, but transporting them requires a drive out with my truck. I've looked on pinside and ipdb, but I don't know the physical dimensions of the machines - so I can't tell if I can carry both them in my pickup truck (obviously disassembled and padded), but I'm not sure the two play cabinets can sit side by side between my wheel wells.
Does someone have the dimensions of these two machines? I know Hyperball is somewhat non-standard, so I'm not going with the defaults.
#2 3 months ago
https://pinside.com/pinball/machine/hyperball/gallery
It's on the flyers....I imagine same for Rapid Fire
#3 3 months ago
Quoted from shevett:
They are both about the size of a standard pin. Hyperball comes apart like any system 7 machine did. The head removes easily.
Rapid Fir was in the deluxe cabinet that they also used for Mr & Mrs Pac Man, 8 Ball Deluxe Limited Edition, and Centaur II. I'm not sure how those come apart as I have never had one, but size wise they aren't off from a normal pin. If you have moved 2 standard body games side by side between the wheel wells, these should fit as well.
Chris
