New! Dark mode!
(Topic ID: 267212)
Dim controlled lights “help”
By P1GPEN
6 months ago
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 6 months ago by ChrisHibler
    #1 6 months ago
    I have a 79 Bally Globe Trotters. Controlled lights work fine for about the first 3-5 minutes, nice and bright as they should be. Then they all get dim, about half the brightness. All still operate as they should, but just dim. Shut game off, and come back later and same issue. Any suggestions????
    #2 6 months ago
    Possibly cold solder joint on the rectifier board, bad pins male or female there, bad fuse clips, bad bridge rectifier. I'd concentrate on the rectifier board first, especially the pins as it's really common for the pins to get loose on the board - you should replace, but sometimes you can just resolder them (remove the old solder first)
    #3 6 months ago
    Quoted from slochar:
    This is everything you should attack first.
    Burned/fractured connections are always a good bet.
    In "all lamps" test, the lamps will normally be dimmer than in game play. That's just a feature of Bally games from that era.
    Chris Hibler - CARGPB #31
    http://www.ChrisHiblerPinball.com/Contact
    $ 9.99
    $ 29.99
    Full Tilt Pinball LEDs
    $ 6.00
    $ 12.95
    COINTAKER.COM
    $ 99.99
    $ 9.99
    $ 3.00
    Doc's Pinball Shop
    $ 45.00
    € 35.00
    Creo Pinball
    $ 49.95
    Pin Stadium Pinball Mods
    £ 50.00
    $ 49.95
    Playfield - Plastics
    MicksPinball
    $ 6.00
    $ 29.95
    Pinball Photos
    $ 48.00
    $ 99.00
    Arcade Upkeep
    $ 7,599.00
    Little Shop Of Games
    Metal-Mods
    $ 70.00
    Cobra Amusements
    $ 54.99
    Comet Pinball
    $ 42.00
    The MOD Couple
