More voltage tests ... this time at the connectors at the transformer panel.
A12P3
P1 64 instead of 95
P9 30 instead of 95 return
P4 18 instead of 12.6
P12 7.8 instead of 12.6
P10 67 instead of 58
15 on pins where there should be 12
22 on pins where there should be 20
A12P2
P2 4.4 instead of 6
P4 70 instead of 48
A12P1
58.6 on pins that should be 48
4.5 on pins that should be 6
11 on pins that should be 16
24 on pin that should 50
28 on pin that should be 50 return
I'm wondering if this is a bad ground issue (i.e. fix the grounds at the transformer per pinrepair.com). I forgot to mention that when I first inspected the inside of the cab, I found the green ground disconnected at the power box, and loose at the transformer.
Or bad resistors?
I checked the Bridges again. They are all giving me the 4.3-4.6 readings.
My DMD showed a little life when I reconnected the connectors: about half the columns lit up.
