So I'm pretty excited - I have a Dialed In coming tomorrow. I have basically been out of the hobby over the past couple years, so this is the first pinball move I have made in awhile (sadly, two of my existing pins were sacrificed to make this a reality).
Combing through all the posts regarding Dialed In, I have distilled a checklist of a few things I need to look into. I am hoping some owners out there can share some of their adjustments / advice that I may have missed.
1. Turn upper flipper coil strength down to 15 (so as to not destroy the SIM hole) - consider metal protectors from Cliffy or factory (WIP).
2. Check the sensitivity of the skill shot switch (top of the playfield) to avoid balls hang ups.
3. Adjust magnet delay time in Quantum Reality theater (in diags) so the ball is tossed back up into the pops and not dropped SDTM.
4. Protect cabinet art from destruction from deadly possible new leg design (I bought felt from Terry).
5. Make sure the trap door is working and doesn't get stuck. Lloyd recommends applying a spot of oil to pivot point and release coil contact point mechanism.
6. Factory mylar over the two magnet cores may bubble over time - one solution is to remove mylar installed directly on the metal cores.
7. Adjust backbox lock mechanism as necessary to correct design flaw (early production models only).
I think that is all I can remember - if there is anything else, I sure would appreciate a heads-up!
-PC
