Quoted from MoSeS_1592:What are the major differences in the different versions (LE/pro/premium) of machines that Stern releases? I noticed that prices can be several thousand more or less depending on pro/premium/LE. Is the game play/roms the same in all machines? Is it just more toys and props? Anything that truly affects gameplay?
I am interested in the Ghostbusters pin in particular. What are the major differences between the versions for this machines? Any opinions on if the premium is worth the extra several grand?
The Pros have mechanisms removed to cost reduce them, so they have less "wow factor" in general. USUALLY the Premium is better, but sometimes the Pro will do.
In the case of Ghostbusters, the Premium is the one you want. The slimer moves much more than the pro, which just bobs a bit, it has magna slings which make the balls do crazy things once you power them up, the premium has a scoop on the right that is missing completely on the pro and replaced with a kickout, the ramp on the premium goes under the playfield then back up unless you lock a ball in the subway (the ramp and ball lock is crap on the pro and nowhere near as cool), and the trim like the library is a full 3D building on the premium, but just a flat piece of plastic on the pro. You get the idea. Pretty major differences.
Stern usually releases a feature matrix that shows the differences, but sometimes they get them wrong, or something that seems not a big deal on the list turns out to be more important than you thought. Anyway, here's the feature matrix for Ghostbusters (note that when Stern says "butyrate" they mean a crappy flat printed plastic piece):
http://www.sternpinball.com/upload/games/ghostbusters/le/Ghostbusters%20Features%20Matrix.pdf
And sometimes the Premium can have features that end up with scoring advantages over the Pro. This is the case with Aerosmith which has a double scoring mode on the upper playfield you can't get on a pro (it's different than 2x scoring, and stacks with that on a Premium/LE).
