My Dr. Who looks like it has a gloss to it, but there is no Diamond Plate logo. I saw the logo on a friend's DW.
Do they all have Diamond Plate?
Also check below the apron if its says Lenc Smith somewhere.
Wms had 3 companies supplying pfs.
SunProcess developed DP and LencSmith their alternative.
DP was better and their pfs have the logo.
LS pfs have clearcoat but no logo and are sometimes of less quality.
Bsd and WW pfs from LS ie..
CCC not only made cabinets but also pfs like for tz.
These different manufacturers also explain color differences like hot pink version of cftbl and pink/red tz.
What's with the seemingly random red insert and drill holes underneath the apron on WMS playfields? Anyone have a reasonable explanation?
Quoted from S37VEN:What's with the seemingly random red insert and drill holes underneath the apron on WMS playfields? Anyone have a reasonable explanation?
The insert is for testing the clear. They would randomly pull playfields off the line and test the clearcoat (hardness, thickness, etc) above that insert in the lower left of the pf. From what I understand is that the test is destructive to the clear over the insert. This way they don't ruin a pf just to test the clearcoat. Who cares if there is a scratch on that insert under the apron.
The other holes could just be for indexing the pf in the press that applies the dimples and holes to the backside, for indexing the silkscreen, etc. They may also be there for hanging the pf while spraying the clearcoat.
Quoted from schudel5:The insert is for testing the clear.
Mike - You should start a new thread to introduce yourself here, since you've been posting some good info.
More info about all this is here: http://www.flippers.be/pinball_playfields.html
Everyone knows Mike
Quoted from aeneas:More info about all this is here: http://www.flippers.be/pinball_playfields.html
Everyone knows Mike
Informative link. Thanks.
Quoted from Arcadedl:Ah..my old Dr. Who, its's looking pretty good all torn down. Did you put the topper on it?
Dan
Tore it down completely. Visited Allan for some white rubbers. Shining everything up. In the process of putting the puzzle back together now. Hope to play again tonight.
No topper yet.
I don't believe that all DW games had diamond plate on them, logo or not. I've got a DW playfield that is far too worn to have been diamond plated (it doesn't have the logo on it).
Generally most of the DW games I've seen without the logo tend to have a massive amount of wear between the flippers. I don't think that I have ever seen a DP logo DW games with that kind of wear.
While I'm aware of Aeneas' website detailing the history, I suspect that DW fits somewhere in the midst of all the changes between non-cleared and cleared playfields. Either that, or as Aeneas suggested, the non-logo playfields had the LS clearcoat which wasn't as good as the DP version.
So if you really have a non-DP logo DW playfield with no wear, it's quite a rarity!
Tony
This page was printed from https://pinside.com/pinball/forum/topic/diamond-plate-without-logo-dr-who and we tried optimising it for printing. Some page elements may have been deliberately hidden.
