(Topic ID: 177016)
Dialed In Owners and Fans Club
By goren1818
2 years ago
  • 9,055 posts
  • 494 Pinsiders participating
  • Latest reply 20 hours ago by Mageek
  • Topic is favorited by 165 Pinsiders
There have been 1,088 images uploaded to this topic. (View topic image gallery).
22 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 9055 posts in this topic. You are on page 78 of 182.
#3851 1 year ago
Quoted from gliebig:
Heard something fall, then I noticed the Betty arm/diverter not working. Loomed in the cab and found these parts. I'm not sure how to put it back together or if I found all the pieces.
Also i took the washer out of mine bc it worked better without it....
#3852 1 year ago
Quoted from LTG:
Should be a couple springs wound together too. The leg leveler looking thing rides on that cam. It screws into the shaft above, you can adjust the height with that nut.
Seems some pins used springs and some didnt? I may have took them out also lol...
#3853 1 year ago
Quoted from PinBuck:
Thanks vireland. I gotta be honest, this freaks me out a little. I can see this turning out badly since I'll be doing it... lol.
Take a picture beforehand. Worse case scenario, you get an apron sticker under warranty.
#3854 1 year ago
Found springs too
#3855 1 year ago
All good. Thanks gentlemen.
#3856 1 year ago
Are JJP games all price locked? Trying to figure out if i need to shop around
#3857 1 year ago
Quoted from GrimDog:
Yes, all manufacturers are setting lowest street prices
#3858 1 year ago
So, it’s pretty much msrp on nib JJP or no?
#3859 1 year ago
No,MSRP is "manufacturer suggested
Retail price". What they are pushing now is a "minimum sales price". In other words, it can not officially go lower for any reason. Game console manufacturers have been doing this since the 80s. This is also why you sometimes see "call for price" in ads.
#3860 1 year ago
If u call around u will find some distros fee hundred cheaper.
#3861 1 year ago
When the manual is supposed to be received?
#3862 1 year ago
Just a heads up for anyone getting a new Dialed In. Replace the balls! After 10 games or so games two of the stock balls already had gouges in them, and one even a small burr. I noticed a couple very light clear scratches that thankfully came out with Novus 2. I threw the stock balls away and replaced with premium Super Shiny balls.
#3863 1 year ago
Quoted from PanzerFreak:
I can't believe they're still shipping machines with those shitty balls! We all went through this months ago, clearcoat getting scratched to fuck within minutes of playing because of the crap balls. FFS Jack, sort it out!.
#3864 1 year ago
Quoted from Kevlar:
Something in the game tears them up. They are ok out of the bag(mine were) it sld use chrome ones but they magnetize and cause issues, so u have to use the softer carbon core ones unfortunately.
#3865 1 year ago
Quoted from bigd1979:
Yeah. I read in another thread to turn the power on the pops slightly down. Others have posted that changing to the premium Super Shiny balls solved their issues and that the balls are fine after 100's of plays. I'm just glad I noticed those two fine scratches before things got worse. A good 30 seconds or so of Novus 2 being wiped over the area took them out.
#3866 1 year ago
I always put better balls in from day 1, all manufactures.......
#3867 1 year ago
The JJP protectors have sharp edges, so they will mangle balls early on. I tumbled the balls more often for the first while.
Scratches are normal. They are just more visible on thicker, clearer clear.
#3868 1 year ago
DI recovered from a boot issue today. I was impressed. I let my 3-year old son play DI yesterday and I assume when he turned it off he probably flipped the switch a few times. Since DI uses writable storage I figured some files must have been corrupted when I turned it on and got some Ubuntu boot menu.
Let it sit. Nothing happened. Rebooted. Same thing. Rebooted again, waited, it went through some process and then finally booted up. Subsequent reboots worked as normal. Not sure what happened but glad DI has a mechanism to recover from this.
Unrelated....is it me or do DI's flippers seem softer than other machines? All of my Stern's have lightening fast, super responsive flippers. My WMS games a close 2nd. My MMR a close 3rd. But DI seems to suffer from random fading even during single ball play, and much more prominently as the ball gets to the end of the flipper, making orbit shots hard to hit since the power seems to vary each shot. The flipper strength is set plenty powerful enough as the ball goes up the left and right ramps without issue. But the orbits, especially the left one shot from right flipper seems to vary in power every shot. Am I losing my mind or does anyone else experience this?
#3869 1 year ago
Quoted from mrgregb123:
No, the flippers are pretty much cannons on factory settings.
#3870 1 year ago
It's out for delivery! I'm stop #14, :-/ sounds like end of the day.....But today at any rate!
#3871 1 year ago
I've asked this same question and was told that the flippers are exactly the same as other pins. So it's just us.
#3872 1 year ago
Quoted from crwjumper:
HA! Yeah, not even close. Can only guess people saying that have never played a Stern. If I play DI and then play Metallica it feels like the flippers in MET are powered by rockets.
Thanks for confirming what I suspected. There must be an issue with the voltage regulator that controls the coil power. I say this because sometimes the kickback punches the sh*t out of the ball and sometimes it barely makes it half way up the playfield. Same with the phone scoop. I set it lower so it would stop hitting the ramp rail, and 90% of the time it kicks out perfectly. The other 10% is barely makes it out of the hole. I imagine the flipper(s) suffer from the same randomness.
#3873 1 year ago
Quoted from Marvin:
For sure. My game had both lower flippers set to 18 which is a few notches down from the default settings.
#3874 1 year ago
All three of my flippers are set to max to make it play well. Can only make it up the right ramp from the left flipper about 50% of the time. And I have tuned the EOS, tightened the coil mounts so that there is no play and checked the gap between the flippers and the playfield etc. Playfield is set at 6.5 degrees.
#3875 1 year ago
variably of the kickback is going to be mostly determined by the ball. The coil fires when the switch is closed, a slow ball may not be as far back in the outlane when contact is made with the plunger. This will affect the kickback strength. A fast moving ball will contact the plunder deeper in the outlane but also have more inertia to be stopped and turned around, also affecting the exit velocity.
#3876 1 year ago
If you are at max, either there's something wrong with your game, or your setup is wrong.
#3877 1 year ago
Quoted from WackyBrakke:
Always.
#3878 1 year ago
Quoted from Marvin:
It’s setup right. Any idea what could be wrong?
#3879 1 year ago
Quoted from Marvin:
Always flipper issues
#3880 1 year ago
My left/right are @ 21 (max 26) and upper @ 15 (max 20). I believe these are the default settings.
Might want to purchase this handy tool for monitoring your voltage (amazon.com link »).
If the voltage checks out, then something else is wrong. Are the coils weak in general or just the flippers?
snaroff
#3881 1 year ago
The only thing about monitoring the voltage is that I have 3 other pins in the same room all running from the same socket. Usually only one is turned on at any given time. All of the other pins flippers work well, including (in the past) a TZ, MMR, and a few Sterns. It's definitely this pin. I guess I could change out the coils. Is there any way to tell if the coils are getting the proper power? I have a pretty good meter but have NO idea how to use it. Was going to learn, but haven't gotten around to it. . .
#3882 1 year ago
Makes sense. I doubt it's the coils. Were the flippers ever working properly? I'm not savvy with JJP electronics...I'd call them and see if they have any suggestions on what to look out for.
snaroff
#3883 1 year ago
WOW....something must be wrong with your game. My left flipper is on default and even dribblers make it up the right ramp. Right flipper is one notch up from default....all shots are fine but left orbit shot fades hard. Turning the flipper strength up won't help because it will make every other shot too powerful. This is my 2nd DI and they both felt the same way.
#3884 1 year ago
Awesome! I think you are really going to like it. I've had mine for less than a week and I'm having a blast. If you haven't already order a audio ground loop isolator, or better yet ask JJP for one, as there's a good chance your speakers will have static present due to electrical interference.
#3885 1 year ago
I’m sorry, your SECOND?
#3886 1 year ago
wellllll that didn't go well, delivery refused.
Glass busted, cabinet probably busted.
#3887 1 year ago
Oh crap. That sucks
#3888 1 year ago
Thanks for the blown weekend guys
#3889 1 year ago
Man that pisses me off... mine came damaged also.... freaking idiots cant do a easy f--ing job.
#3890 1 year ago
Oh no! Sorry to hear that. Thank goodness you refused delivery. My distributor uses R&L and it sounds like they have done a very good job shipping games. Maybe see if your distributor can use them for the replacement.
https://www.rlcarriers.com/
#3891 1 year ago
This was R&L.........
#3892 1 year ago
Damn, well nevermind, lol. Guess it just depends on whoever is moving the game if they are being careful or not.
#3893 1 year ago
Sounds like JJ @ Game Exchange might save my day! They might have an LE is stock. Just waiting to hear back from JJP if I can get a refund and buy from JJ.
#3894 1 year ago
R&L is super inconsistent in my experience.
#3895 1 year ago
Damn that sucks good luck with Game Exchange
#3896 1 year ago
Woohooo JJ @ Game Exchange rocks! Purchasing a replacement LE from him, to be here Thursday.
#3897 1 year ago
Weekend saved!
#3898 1 year ago
Nice glad it worked out. I buy from
JJ too and he has been great to deal with. It will be worth the wait it is a fantastic game.
#3899 1 year ago
I finally got to and completed the showdown wizard mode (no SIM card carry over) what a great pin .
#3900 1 year ago
Quoted from Pinballpal:
Impressive, and congrats!! My best is 3 sims so far. I'm just glad to know I have a whole lot more games to play!!
$ 50.00
Gweem's Mods
$ 8,000.00
$ 99.00
Pinball Sales
