Quoted from Butch2099:I just joined the club! Happy I waited because the machine came with new style protectors. Packaged very well also.
The game looks great! The only problems I have had so far is the start button assembly wasn't put in the button (easy fix), when I tried to slide the playfield back in place I didn't realize there was a big foam block in the back (took some figuring out).
The only problem I need to keep an eye on is on a couple of games I got a signal lost message on the screen & it went blank & into power saver mode. I assume it's a loose connection somewhere? It's working at the moment but would appreciate any tips on where to look if it happens again.
Congratulations and welcome! It sounds like the monitor video cable is loose and likely just needs pushed back in a little more. I would check both ends of it. So where it goes in the monitor and the other end going into the composite.
It’s all located in your backbox and the monitor swings out but you have a couple wooden locks on each top left and right corner you will need to loosen a little. This will allow you to unlock the monitor mounts and swing it towards you. Then just below that to the right is the computer.
Here are some pics.
