We're back!
After a disaster in our datacenter took down our server, we are now running Pinside on a brand new server. However, things may not work as expected as we are still polishing the playfield and adjusting some switches! We might be switching to maintenance mode a few times. Please see this forum topic for more info.
(Topic ID: 177016)
Dialed In Owners and Fans Club
By goren1818
  • 11,833 posts
  • 620 Pinsiders participating
  • Latest reply 23 hours ago by Kingpin22
  • Topic is favorited by 215 Pinsiders
23 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 11833 posts in this topic. You are on page 27 of 237.
#1301 3 years ago
#1302 3 years ago
Currently installing the ISO to my flash drive and I was asked if I want to overwrite menu.c32. Anyone know what I should do here?
#1303 3 years ago
Quoted from pinstadium:
Here is how to get into the Settings menu to install the "Director's Cut". I hope this helps!
Thanks is it easy to change back if you don’t dig it?
#1304 3 years ago
1.50 is up on Jjp I was just told
#1305 3 years ago
Quoted from Connor:
I would assume YES because it's replacing the file with an updated version.
#1306 3 years ago
In case you were wondering which USB port to use on Dialed In for the update - the installation instructions alongside the download don't include this info, but the 2.0 manual does:
"Remove the USB stck from your personal computer. Power your game down and insert the USB stck you burned into the USB cable atached to the cabinet divider, behind the coin box, just inside your game’s coin door."
So, no need to get into the back box to update. Nice!
#1307 3 years ago
So, just to quickly clarify, is this 1.5 a Delta or Full Install?
Since this is my first JJP pin, is there much difference when downloading (between the two) from the JJP site?
#1308 3 years ago
Is the full install the same way you would update WOZ? Just making sure.
#1309 3 years ago
It's a full install. Instructions are right on the support page, under Downloads: http://www.jerseyjackpinball.com/support/
#1310 3 years ago
Quoted from JMK:
Full Install, and yes, the procedure is quite different. Follow directions on JJP site for Full Install.
Use UNETBOOTIN.EXE
#1311 3 years ago
Thanks Kev & Moonduckie- will be my first JJP update, hope it goes smoothly.
Great game all around.
#1312 3 years ago
Quoted from JMK:
Make sure you use a USB drive over 8GB, and make sure you format it to FAT32 (if using Windows).
Follow the directions and it should go smooth.
Quoted from Connor:
Click YES TO ALL. That's what I did. Worked fine.
10
#1313 3 years ago
Gotta love JJP's way of announcing the code update considering the timing, lol.
#1314 3 years ago
Quoted from andre060:
Yes, no need to open the backbox. Just remove the Bluetooth dongle currently attached to the USB cable behind the coin box, and don't forget to plug it back in when you're all done.
#1315 3 years ago
Quoted from PanzerFreak:
Totally using this as my Attract Mode custom graphic!
#1317 3 years ago
Quoted from moonduckie78:
#1318 3 years ago
1.50 is a full install.
Viewing update :
"note that the full update sometimes appears on one of the smaller screens (Theater or Phone) instead of the main screen. This is because the displays don't always initialize in the same order.
While it looks pretty weird, the update will complete successfully and the game boots up just fine when power cycled after the update.
--Ted"
On my game it was in the theater and backwards because of the mirror. It worked. Back up your settings and reinstall them after the update.
#1319 3 years ago
Quoted from LTG:
Lol...that's what I get for guessing it would be a delta. I should just shut up, hehe.
Thanks LTG!
#1320 3 years ago
Quoted from brucipher:
No, you weren't the only one wondering or trying to do it wrong.
Thank you for helping to inform.
#1321 3 years ago
So, what does PHONE OVERCHARGE mode do?
I see that if I hit QED too many times, the little battery indicator on the phone screen starts going above 100%, but what does this DO?
#1322 3 years ago
Why should I spoil it for you?
#1323 3 years ago
Quoted from Pinballomatic:
Been playing new code for 2 weeks and still can't figure out what overcharge does....
#1324 3 years ago
Quoted from bigd1979:
Doesn't it award you with more points during the mode if you start with the phone overcharged?
#1325 3 years ago
My NIB Dialed In is going to be delivered today. The timing of the 1.50 code update could not be better.
#1326 3 years ago
Is the monitor supposed to lock into those latches? am I supposed to remove the wood blocks installed above the latches so that they pegs can slide them up and lock into place?
#1327 3 years ago
Quoted from zucot:
Yes. No need to remove the blocks, just loosen and twist them out of the way.
#1328 3 years ago
Quoted from romulusx:
Yes you can go back and install "Medium" and that is back to the the original factory settings. See the screenshot below and it shows that that they all match back up (this is after a fresh 1.5v install too).
#1329 3 years ago
I thought I read somewhere or heard it on the buffalo stream perhaps? That overcharging the phone awards extra scoring to the next mode started by % of how much it’s overcharged. I believe it can build the phone up to 150% Good risk/reward points strategy.
So if you light multiball, then cancel multiball, overcharge the phone, start a mode, start multiball, you can rack up some good points.
Or...start quick multiball, hammer away on QED guy to fully charge phone safely, then start a mode.
#1330 3 years ago
Check out this new voice synchronization with the GI and the Mechanic flasher when multiball starts. This is a new feature in version 1.5v, very cool!
#1331 3 years ago
Quoted from zucot:
I posted this up earlier, this may help you so that you don't have to scroll through to find it. For anyone that needs to access their computer boards, fuses, wiring, monitor. Here is a tip, the tower is now in the backbox (unlike WOZ) and in order to access the boards you must unlock the monitor and it swings out on an articulating arm to give you quick easy access. Here are a few pics showing the wooden stoppers on each side they need to be loosened and pull out of the way. There is no need to remove them, but just rotate them so that you can lift the metal gate on each side to release the monitor. Then just pull the monitor out and you have easy access to all the goodies in the back.
#1332 3 years ago
Kewl
#1333 3 years ago
Thanks Scott!
#1334 3 years ago
My D.I LE arrives tomorrow!
Downloading the new 1.50 code now.
From what I've picked up from this thread:
Set magnet in Theatre to -90 and tweak until ball goes up towards right flipper
Left ramp exit- ball bounce outs- raise with a couple of small washers and put Velcro!? under the wire form I assume to slow the ball down?
I've been reading about scratches that appear where the flippers are? Any preventative measure to stop this from happening?
Hole protectors- JJP ones bit naff, so order & fit Cliff ones.
Anything else?
#1335 3 years ago
For Ron.
Look at it. Sticking up there like it’s flipping me off. Same to you, door mech.
#1336 3 years ago
Quoted from epthegeek:
For Ron.
Thanks for posting that as I think this really clarifies where to make the adjustment if needed.
#1337 3 years ago
Quoted from Pinhead1982:
Make sure Jack's factory balls (LOL) are in good condition.
If you do get the lower playfield scratches (which I did...BAD!), a rubdown with some One Grand Blitz Wax (or a similar brand of carnauba wax) on the problem area can really help make them MUCH less noticeable.
10
#1338 3 years ago
My new custom attract mode graphic!
#1339 3 years ago
Ok, so here's an issue I'm having, which I haven't seen discussed before. Maybe I missed it. Hopefully there's an easy, low-tech fix?
Any low frequency (bass) sounds cause my cabinet to rattle and vibrate quite loudly. Specifically, it mostly seems to be coming from the left side rail. If I pull the glass forward just a bit, so it's not fully inserted into the cabinet's rear glass channel, the left side rail stops making the rattling noise.....but of course, I can't insert the lockdown bar like this. As soon as I slide the glass all the way back into the rear glass channel, that left side rail starts rattling like a snake whenever the game's audio plays any low frequencies. I'm not blasting the volume, either. I always keep it between 22-24.
Actually, I can get it to make this ugly rattling noise without the game even being on. Merely tapping on the rear glass channel will cause that left side rail to start rattling. With the game audio playing, it's just rattles that much louder!
It's really annoying. None of my other pins do this.
At first, I thought I had a blown speaker, but I soon discovered the sound was coming from the cabinet itself.
Anyone's thoughts are greatly appreciated!!!! <3
#1340 3 years ago
For Ron.
What the deuce?!
I haven’t had problem with mine.....yet.....but going to check mine when I get home today.
Thanks for posting the pic Eric and Ron for the video.
#1341 3 years ago
I unboxed my game yesterday and I love everything about it except the most important thing my left and right flippers are weak. Surprisingly the flipper most people are having trouble with the upper right flipper works great. I have the flipper strength set to 25 on all of the flippers.
What are all the things I should do to trouble shoot this thanks in advance.
#1342 3 years ago
Quoted from Pinballpal:
DI flippers - should be strong. I'd start with the basics. Plungers move freely ? Coil stops on tight ? A tiny bit of up and down play on the flipper so the pawl below the playfield isn't binding on the nylon bushing the flipper shaft rides in, too much play and the plunger doesn't move in a straight line.
Then I'd follow wiring. From flipper to backbox. Any connector along the way, reseat and push in tight.
#1343 3 years ago
All you need to do is level your game correctly - levelers all the way in the legs to the bottom, then left/right level to 6.5 degrees. There might be some jumps for the first 20 games or so and then it settles down.
Here's what else I've done.
Re-seat all the connectors to the computer and screens.
Remove the skill shot switch and bend it back a small amount.
Put some 3 oil on the pivot points of the trapdoor.
Replace the flipper springs with new ones.
Swap the wires on the BOB sign for Extra Ball and Multiball.
Install Cliffys - does both scoops as well as three switches and the shooter lane.
Install the Director's Cut settings.
#1344 3 years ago
+ Added design team selfies in attract mode. Has anyone seen this? Watched the attract mode for 10 minuets, didn't see any pic
#1345 3 years ago
Question guys...is the bob latch suppose to be closed at startup? If so when should it open? On a side note, this game is amazing.
#1346 3 years ago
My upper flipper only goes to 20 max. Is this like everyone else?
#1347 3 years ago
Anyone fitted something here to stop this ball hangup?
#1348 3 years ago
Quoted from Kevlar:
Anyone fitted something here to stop this ball haungup?
Just hit the side of the pin where the ball is at
#1349 3 years ago
Quoted from woody76:
Got mine at factory 15 and its plenty strong...
#1350 3 years ago
Nah, couldn't dislodge it, was a glass off moment.
