(Topic ID: 177016)
Dialed In Owners and Fans Club
By goren1818
5 years ago
  • 13,015 posts
  • 686 Pinsiders participating
  • Latest reply 1 day ago by mbott1701
  • Topic is favorited by 242 Pinsiders
23 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 13,015 posts in this topic. You are on page 259 of 261.
#12901 67 days ago
Quoted from Pinball-Ike:
Might have to make it to your 50th year party
I hope you can. It's a free event. Pop, hot dogs, cheese pump, 10 slabs of Famous Dave ribs, a round of pizza, and 22 pins on free play.
It should be a lot of fun. Since I've been helping people on line for 28 years, it should be a good turn out.
#12902 66 days ago
The coin door menu buttons aren’t working. Any ideas? Figure it’s something obvious and simple but it’s definitely odd. Thx
#12903 66 days ago
Quoted from DropGems:
Turn the game off.
Right inside the coin door follow the coin door harness. The first connector you come to, grab by the wires both sides and push the connector together as hard as you can.
That should fix you up.
Then tell jjp to get LTG : ) back.
#12904 66 days ago
Is it possible to do combo by chaining the left ramp continiously?
Does this count as combo or you have to use different ramps?
#12905 66 days ago
Hi guys,
I just got an issue on my dialed in, the theater does not grab the ball anymore, in the test switches i got "theater enter" stuck open
Does anyone knows where is the issue?
I also seem to have a gate/switch behind the theater that seems in an odd position (see photos)
#12906 66 days ago
IT seems my opto got unstuck somehow... does anyone have a picture of where the opto is supposed to sit?
#12907 66 days ago
I managed to sort it out, the opto felt from the rail, I removed the mini play field and Clic the opto back in
#12908 66 days ago
Quoted from skwal:
Hi guys,
I had to bend the metal gate a little to make it move freely.
#12909 65 days ago
Quoted from TrekTobbyGermany:
Can you post a photo on how you bended it?
#12910 64 days ago
Quoted from skwal:
Like that. Just needs a little...
#12911 60 days ago
Who wants to trade their DILE for a NIB UMCE preorder? PM me if interested.
#12912 60 days ago
You are serious?
Quoted from Tres:
#12913 58 days ago
Gameplay question, I’m going through disasters with multiballs sprinkled in then get to chaos on quantum city. Is this the general flow or is there something I am missing? How are y’all attacking gameplay? This is a fairly new addition to my lineup so still figuring out how to navigate. Unlike, Wonka for example, where you can stack mini modes(super spinner, etc..) I’m failing to see what to stack and best way to play. Thanks in advance.
#12914 58 days ago
Quoted from Jamwin:
Nothing much to stack in DI compared to other pins, except some modes work well with MB. So, waiting on starting meteor and then MB is useful, for instance.
Otherwise, it is making your way through modes one at a time and trying to collect the SIM cards. Lots of other stuff to do along the way. Just not many stacking opportunities.
#12915 58 days ago
Quoted from Jamwin:
Don't shoot the big bang before you start a disaster, then you can hit it and it counts as mode completed
#12916 58 days ago
Quoted from Jamwin:
The biggest stacking opportunity is to bring sim cards in to modes. So try to collect those sim cards before starting a new mode. Also you can skip multiball after you lock the second ball by hammering on the flippers (watch the phone screen for the cue)
#12917 58 days ago
Quoted from PinballTilt:
What's the phone screen cue ? I didn't know you could skip multiball. And if you skip how do you get multiball after that ?
#12918 58 days ago
Quoted from adol75:
Right after you light your multiball, you can hit both flippers twice and cancel it until you start a mode. Once you start a mode, the phone will be lit for multiball.
#12919 58 days ago
Quoted from adol75:
I think it's after you lock your second ball the phone will say shoot phone for multiball and then in small text say press flippers twice to cancel. So you can then start a mode and the phone will be lit to start multiball. Allows you to make progress on a mode during multiball. Give it a try next time you play
#12920 51 days ago
Just checked my SIM area, thought I would post what works well for me. About 2000 games in as is after removing the metal protector and dropping the RHS rubber. This is still the first mylar application. Thought it would be due to be replaced but looks fine.
Plays perfectly with this setup on my machine. Still hard shot but not beyond reasonable expectations.
#12921 44 days ago
Just replaced the original battery, thought I would share the voltage was 2.90V.
Have put it off too long and sure I’m not the only one. The fix for the battery not working finally got to me.
#12922 44 days ago
I need a little phone scoop help. I have a protector on there now, and a protector inside a bag of Cliffys that was part of the Dialed In kit. I assume the protector in the bag is an actual Cliffy, and the one installed is factory. Two questions:
1) How can I tell the difference for sure, because
2) Which is better at lowering rejects?
I have a lot of rejects from that shot. The ball appears to fall into the hole partway and then pop back out again more often than I think it should. My searches seemed to give inconsistent answers. Anyone?
#12923 44 days ago
Quoted from arcyallen:
The factory protector was quite thick and had a cut out in the front. Cliffy's is much thinner, without a cutout. I use a Cliffy and do not have a lot of rejects after bending it a little to fit properly and staying flat on the playfield. Same on Sim card. Plays fine with Cliffy's. Some like mantis Protectors more. To absolutely minimize rejects you have to play without Protectors and the risk of chipping playfield. But that's no option for me...
#12924 44 days ago
I had tons of rejects from the cliffys, it made playing the game painful, so I removed it and put some mylar instead. The playfield is protected and my shots go straight in the phone.
#12925 42 days ago
Scoop kick seems like it’s dying. Was getting weaker and weaker past two days now ball won’t make it out. Any suggestions? Thx!
#12926 42 days ago
Still looks new,that what I did but
Did you look at the coil sleeve for operation ect!
#12927 42 days ago
Quoted from rockrand:
How’s that work? Ball is jumping but not making it out.
#12928 42 days ago
Plunger intact and not worn ? Where plunger rests ( coil stop or rubber grommet ) still there and not worn ? Coil sleeve not missing, worn, or cracked ?
If all good. Then go into Settings - Coils - and make it stronger.
#12929 41 days ago
Any way to read the comic book online or dl somewhere?
#12930 41 days ago
Quoted from Rondogg:
No that I know of.
I wish it was.
#12931 41 days ago
Thanks Lloyd.
I learned to google and did find this:
https://nypinball.com/flyers/dialed-in-2/
Can anyone confirm that this is the complete comic?
#12932 41 days ago
Thanks Lloyd.
Yep that's the complete book. Good find!
#12933 41 days ago
Quoted from mjfisher:
Thank you !
#12934 41 days ago
...getting ready to switch out the non-working drones for new ones. The new ones don't have propellers, and tips on how to move the old propellers to the new drones without breaking them? Thank you.
#12935 41 days ago
Very gently pull up to remove and then push on to stick back on.
#12936 40 days ago
so, no tools LTG?
#12937 40 days ago
so, no tools LTG?
Back when I changed one. I just pulled them off and shoved back on. Didn't even think about it.
#12938 40 days ago
Thanks bud...
#12939 40 days ago
So related to the drones….one did not work, changed all motors (ali express, really good price!) and in test mode they work perfectly (all three, the new one even better/harder). During game (last update) they don’t work….some times one second…. Is this how it should be?
#12940 40 days ago
Quoted from JvdS:
They nerfed them in the last code update.
#12941 40 days ago
Quoted from nitrojcrawf:
I’m on latest code and still occasionally see them fire.
#12942 40 days ago
Quoted from mrossman5:
Exactly! They use to be more prominent if the older code. Now not so much.
#12943 40 days ago
FYI:
23-005010-00
DI Quadcopter Drone Motor
$4.99 each
30-000088-50
DI Quadcopter Drone Body, Propeller
$0.25 each
If you need any, please submit a ticket via http://store.jerseyjackpinball.com/Support-Form/
#12944 40 days ago
Or 6,50 euro for four (!) motors via Aliexpress ;
Search on this at their website:
Cheerson CX-10 CX10 CX-10 CX-10A V646 V676RC Part CW/CCW Motor for Cheerson CX-10 Hubsan H111 RC Quadcopter Parts
Quoted from PghPinballRescue:
FYI:
23-005010-00
$4.99 each
30-000088-50
$0.25 each
#12945 38 days ago
Quoted from TOLLS:
Anyone see any advantage to removing the rubber ring off the lower post on the SIM card scoop to help get the ball in the scoop? Obviously a tough shot but trying to improve chances of scoop hits. Thanks in advance.
#12946 38 days ago
Quoted from Jamwin:
It does seem to help with not so perfect shots
#12947 34 days ago
At one point I thought there was a way to shut off the "wave your hand" requirement for Lottery Frenzy, but can't find that option anywhere in the game menu, the manual, or in this forum. Did I imagine it?
#12948 34 days ago
Just wiggle your head
#12949 34 days ago
Quoted from LTG:
Two screws remove the clear plastic over the pop bumpers and set aside, a couple lock nuts to remove the plastic on left side of the theater. A couple locknuts and one screw to remove theater and set aside. Then you can check the left and right opto if one popped out of the hole it's stuck in.
This was a long time ago but thank you Lloyd, it helped me today. A tab had broken on the right side plastic and I hot glued it back in.
While I was there I found the answer to my mysterious missing ball. Last week a ball went missing and I couldn’t find it so I just added another. I guess the last guy who owned it did the same thing. Couple of times
#12950 33 days ago
Hello all! I will be joining the group soon. Game will be getting shipped to me Monday. I am very excited to give wonka a proper buddy in the game room haha. Anything I should look out for?
Gweem's Mods
$ 599.95
Pin Stadium Pinball Mods
9,400 (OBO)
Clermont, FL
Eugene, OR
Precision Pinball prod.
$ 22.50
$ 5.00
Pin Monk
$ 5.00
Pin Monk
$ 399.95
8,250
Newington, CT
$ 3.75
Pinball Mod Co.
