I finally decided not to hold off changing the CR2032 battery any longer. I dreaded having to do it. The process should be simple but it is not (hopefully it was not simple for me since as I explain below I tried to use electrical tape rather than masking tape….)
My back glass is really tight in the lock. I feel like I have to force the lock to turn to get it to open and similar to close it. But it came off as usual.
I have the physical manual so I followed the steps on pages E-11 and E12.
I am pointing with the screwdriver to the two latches you need to pull up after you rotate the wood out of way so the latches can come up. Then I moved away the screen.
I removed the four screws but you also need to disconnect the LEDs that are at the top of the shield to remove the shield from the game.
I tried to use electrical tape. Clearly reading the instructions NOW it says masking tape. Maybe that is why my tape would not stick to the battery. I will use masking tape 3 or 4 years from now when I have to do it again. Oh well, it is amazing what I READ and what I THINK I READ....
I ended up using a small screwdriver with a clean rag protecting the lower part of the computer area. I only buzzed my fingers against the fan a few times. I used the small screwdriver to pop the battery out of the holder and fling it out to me. Probably not the best way to do it (now that I know I didn't use masking tape), but it flew out really nicely and far away from the game.
I did use electrical tape to place the new battery in without an issue.
I turned off the game. Put the shield back on. The 4 screws were secure but still felt like they moved in the hole so I covered them with electrical tape. I put the monitor back in position. I turned on the game and thankfully it worked.
I checked the voltage on the old battery and it was 2.895 V.
IMG_1254 (resized).jpegIMG_1255 (resized).jpegIMG_1256 (resized).jpegIMG_1257 (resized).jpegIMG_1258 (resized).jpegIMG_1259 (resized).jpegIMG_1260 (resized).jpegIMG_1261 (resized).jpegIMG_1262 (resized).jpegIMG_1263 (resized).jpegIMG_1264 (resized).jpegIMG_1265 (resized).jpegIMG_1266 (resized).jpegIMG_1267 (resized).jpeg
