Quoted from finnflash:So I updated to newest code and I started troubleshooting the phone issue. When I swap the theater and phone then the theater has the "fuzz" and the phone shows upside down which think is correct. So if the problem is being sent to the device, how do I fix that?
Sorry you are having some trouble.
Did you purchase it NIB or from someone else? If from someone else, did this phone problem exit before you purchased it? I'm only asking for context and to, perhaps, eliminate thing like "something came loose" while it was being moved.
With no further insight available, seeing "fuzz" is odd IMHO. I'd expect the little display, whether the theater or the phone, it either show the video mostly correctly or not at all. This is because the display device is synching to the analog signal. Seeing snow may represent a more several graphic card problem.
But before assuming anything, if possible, I'd suggest plugging an older VGA monitor directly into the phone output on the Dialed In PC box.
Sorry I don't have any "this will fix it the issue" comments.
