(Topic ID: 177016)
Dialed In Owners and Fans Club
By goren1818
  • 10,914 posts
  • 572 Pinsiders participating
  • Latest reply 8 hours ago by nettek
  • Topic is favorited by 206 Pinsiders
There have been 1,341 images uploaded to this topic. (View topic image gallery).
23 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 10914 posts in this topic. You are on page 218 of 219.
#10851 11 days ago
Quoted from Oneangrymo:
Ok i give up on theater magnet tried several settings including negative and positive . Nearly every time it’s active it just holds the ball then drops it down the middle . Maybe magnet needs to be replaced ? Defective ? Anyone replace theirs ? Thanks !
Have you tried raising the right leg a smidge? I believe I've heard that somewhere in this thread.
#10852 11 days ago
Quoted from RonSS:
Ill try that, ugh, time to get under the machine again with my crowbar.
#10853 11 days ago
I don't think replacing the magnet will do anything. What version code are you running? Have you tried new balls? Is the mylar removed from the magnet? The opto switch works properly in switch test? Sorry if you've addressed these questions already.
#10854 11 days ago
Quoted from FatPanda:
Yes new balls , removed Mylar I think all tests work fine . Newest version . Thanks for ur help
#10855 11 days ago
I know for my particular game, I think my maget adjustment value is something like -120 (negative 120) I understand that different games will have different values. What values have you tried?
also, if you're not sure, I would confirm that the opto registers accurately.
#10856 11 days ago
There's another setting that changes the behavior of the theater magnet catch behavior. Under game settings
#10857 11 days ago
Ive tried + 20 , -120, -80, -90, -50 and -20. Only one time it shot up to the bumpers, rest of the time held it then let it go straight down the middle
#10858 11 days ago
Which time did it shoot it up?
#10859 11 days ago
Man.. I dont remember, only once, I think it was after I got the mystery box. and I think it was near -50 at that time.
#10861 11 days ago
Is the theater magnet only supposed to hold the ball, then toss it up to pops? Or is it supposed to hold the ball, then release it back to the flippers?
#10862 11 days ago
Quoted from 27dnast:
I could have swore when I first got the machine , it was brand new direct from JJP when they first made them, it only went up to popbumpers.. the entire time, Im pretty sure.
#10863 11 days ago
Sometimes it should hold and fling, at other times - during EMP strike is one example, it should hold and then drop.
#10864 11 days ago
Depending on the situation, it will hold and drop or hold and toss.
For example, if you have the train bash, it will hold and drop, but the QED guy will move in the way to divert the ball from draining SDTM. If you have a mystery award, it should hold and toss around to the upper flipper.
oneangrymo, you will have to keep playing around with the magnet settings. I would start with -50 where you think it might have been set at, and continue going further into the negatives -60, -70 etc, each time rolling a ball into the theater, until you get the tossing behavior, you might have to go deep into the the negative -150, -160 etc.
#10865 11 days ago
Is there a test setting that allows me to test the hold and fling?
#10866 11 days ago
yeah, it's buried in the menu somewhere. LTG or kingpingames might know off-hand, or I could dig around my machine when I get home later today.
#10867 11 days ago
Not sure if there is off hand. If there is, it would be in devices.
#10868 11 days ago
Quoted from LTG:
Yup. Tests, device tests, theater magnet.
I was having the same problem with STDM throws but this let's you pick any setting and test it. I put mine to -100 and all the ball throws went up and out.
#10869 10 days ago
When working, in most situations it will fling the ball back setting a shot for the lock ramp. Really cool when working and when your game doesn’t do this it’s rubbish. Mine DID NOT work the same in test as game. It took a really long time to get it right - weeks.
I had to start at a number someone else was using, try -90 as above. Play several games, if it’s not working (probably won’t) move it say 5 either way, play several games. Repeat, Keep moving in the same direction. You will work out if you are getting closer or further away from the magic fling back. Write down your results. If you moved the wrong way, repeat in reverse. It’s frustrating but worth the time. The game doesn’t function properly if this isn’t working. This process didn’t work in test for me. Don’t know why. If your game isn’t flinging back properly you are missing a great feature but more importantly the flow is lost.
#10870 10 days ago
Probably a known question, but I’m a little late to the party. Has the latest code basically disabled the propellers on the drones?
#10871 10 days ago
Yup. SUPER minimal and almost impossible to notice.
Thought mine were busted but they all were firing strong in test mode.
On the plus side your motors will probably never burn out!
#10872 10 days ago
No, but they are rarely used now.
You can always go into tests and spin them.
#10873 10 days ago
Quoted from BillySastard:
Thanks for this. Mine ended up getting adjusted to -110. Works great.
#10874 10 days ago
can someone please post a photo of what that plastic piece is supposed to look like behind the phone? The fly ball protector? I took it off and can't seem to remember how it looked when it was originally on
#10875 10 days ago
I did that once. Hope these help.
#10876 10 days ago
Quoted from Nokoro:
[quoted image][quoted image]
Thanks man
#10877 9 days ago
So if u complete one mode lit sim chip but don’t get it while ur trying complete another mode u still only get one sim ?
#10878 9 days ago
SIMs don’t carry over from ball to ball if you fail to collect (though you can change that in settings). And you can only collect one at a time. So, if you’ve completed three modes but haven’t collected any SIM cards yet, you will need to hit that scoop three separate times to collect all three.
#10879 9 days ago
I’ve never really played a game that hurts my arms and hands because I just keep playing it over and over and over . Dialed in definitely has it going on
#10880 9 days ago
I’ve just got mine but I find the bass is lacking, no real punch. Looking in the cab I noticed it has a crappy looking 8” 8 ohm speaker.
All the other JJP pins seems to have a beefier 4 ohm sub, just checked spares.
Anyone swopped theirs out? What did you use and did you stick to 8 ohm?
I don’t want to add an external sub. Other pins I have with pinsound and speakers sound pretty decent.
#10881 8 days ago
Hi,
not sure if it was already adressed, but ball sometimes stucks under the BOB trap. It enters well on floaty shot, but then doesn't move under the playfield to the phone scoop. I have to raise the playfield and give a good shake for the ball to go down.
Otherwise plays perfectly.. any tricks, tweaks to recommend ?
#10882 8 days ago
Quoted from BENETNATH:
Hi,
I had the same issue, raising the right back leg some helped I think
#10883 8 days ago
ok, but as the whole pinball is flowing at its best, I fear to kill the whole equilibrium found
I'm questioning about a small piece of mylar or like that to cover the junction of the ramp..anyone tried ?
#10884 8 days ago
Who is going to wear their DI jacket this fall ? I was thinking about leaving the baby and wife at home, throw it on, cruise around town and try to pick up some chicks.
#10885 8 days ago
I had the same thing happen and the info here completely solved my problems:
https://pinside.com/pinball/forum/topic/dialed-in-owners-and-fans-club/page/105#post-4565687
#10886 8 days ago
Quoted from t500:
Seems exactly what I'm looking for!
#10887 7 days ago
I'm there. We should all wear our DI jackets, and if those Wonka punks try to start some $#!*, we will throw down, like West Side Story.
#10888 7 days ago
Having a problem with video on the main monitor. I get horizontal static in the video - tough to capture in a picture, but you can see the lines at the top. I checked the connection from the pc to the monitor, and both seem tight. Any thoughts on what might cause this? Bad cable? If so, is there a replacement? Thanks in advance!
#10889 7 days ago
Quoted from demaximis:
Try reseating the cable first. Make sure it isn’t bent or pinched at a connector.
#10890 6 days ago
My keys don’t work for the back box which is really weird anyone else have this problem ? I never tried to access back box before but I want to add an led strip to it
#10891 6 days ago
Check the set of keys that should be inside the coin door, hanging on a loop. Those are the keys for the backbox.
#10892 6 days ago
LOL
#10893 6 days ago
Yes I know that, those keys dont work. Weird.
#10894 6 days ago
https://pinside.com/pinball/forum/topic/dialed-in-owners-and-fans-club/page/184#post-5226238
#10895 2 days ago
I've been sitting on my drone replacements for a year, about to tackle it today. Anything I should be aware of before going in?
It's still odd that two of them work a single time after a power reboot and then never work again.
#10896 1 day ago
Quoted from javagrind888:
Not sure I'd spend the time since the code rarely (if ever) spins them. I'd hold onto them and play some games with that time instead.
#10897 1 day ago
I got them installed. They spin every time I hit the drone targets now. Added something I didn't realize I was missing for almost two years.
#10898 1 day ago
That’s awesome! Thanks for sharing
#10899 1 day ago
One or two of mine don't work 100% ... but if you spin the blade, it works for a while.
I purchased a bunch of replacement motors from Aliexpress a few months ago and they recently arrived. You have motivated me to replace them!
#10900 1 day ago
Quoted from altan:
If the motors work can you shoot me the link. I have one drone that I have to spin the blade to get to work
7,000 (OBO)
Yoder, IN
$ 8,000.00
