(Topic ID: 177016)
Dialed In Owners and Fans Club
By goren1818
2 years ago
  • 8,819 posts
  • 486 Pinsiders participating
  • Latest reply 2 hours ago by koops
  • Topic is favorited by 158 Pinsiders
There have been 1,067 images uploaded to this topic. (View topic image gallery).
22 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 8819 posts in this topic. You are on page 165 of 177.
#8201 35 days ago
Quoted from PjM:
What does/purpose of the bluetooth doggle have in the game? Mine stopped working.
It's to connect your phone to it and use your phone for the flippers. Mine has never quite worked right and even when it does there is a flipper delay. It's one of those throw in features that just isn't worth the trouble honestly.
#8202 35 days ago
Quoted from PjM:
Just curious, but how do you know it stopped working if you don't know what it is for?
Mine always worked fine. It is kind of a cool feature, but not really the way I prefer to play.
#8203 35 days ago
Your bluetooth shows up on the test report at startup for game diagnostics. That is how I know it is not working.
#8204 35 days ago
Quoted from PjM:
Try unplugging it and plug back in. Or try plugging it into a different USB port on the motherboard. Or leave it out.
#8205 35 days ago
Quoted from PjM:
Ah, got it.
#8206 35 days ago
Quoted from Nokoro:
Not preferred but I’ve played with my wife that way to even the playing field (so to speak). Problem is you have the Big Bang button right there on the phone - big advantage if lit
#8207 35 days ago
Does anyone have a picture of the line filter for the sound and how it is installed? It's 1/8 stereo jack ground loop isolator according to the JJP site.
Rob
#8208 35 days ago
Quoted from Rob_G:
You want to install something like this:
amazon.com link »
onthesnap wrote about it earlier:
"Just pop open the back cabinet, and you will see the 3.5mm cable for audio plugged into the main computer behind the screen. Plug it in and secure with some zip ties. Problem solved"
#8209 34 days ago
Quoted from Rob_G:
Rob
Check out post 5805 for a picture and directions.
#8210 34 days ago
Quoted from ralphs007:
I could only find one type of isolator locally and it's really meant for cars, but it's the same thing. I just needed to adapt the RCA stereo to 3.5mm. A little ghetto perhaps, but it still works like a treat - no more annoying background noise!
I'll maybe order something better, but until that comes this will work fine. I'll just clean up the wires and put the glass back on for now.
Rob
#8211 34 days ago
JJP should be sending you an isolator! I had the same noise and that is not acceptable. JJP sent me one. You should do the same because again, that is not acceptable to have that noise.
#8212 34 days ago
Quoted from Mbecker:
True, but it is so hard to be accurate with your shots without having your hands on the physical buttons that it almost justifies the Big Bang button.
#8213 34 days ago
Quoted from PjM:
To be honest, I don't know how the machines went out like this because the noise is pretty bad. I'm not the original owner and the game is 1.5 years old now so I just went and spent $20 locally. I decided to test the audio channels after install and find left and right are switched even though everything is wired correctly. So I just swapped the RCA connectors on one end and it's now correct.
(If I was original owner, I would have asked). Install completed.
Rob
#8214 34 days ago
I just bought mine NIB 2 weeks ago and made that noise out of the box. I expressed my concern! That noise would have been a deal breaker - was terrible. Was not going to pay $9K for that!
#8215 34 days ago
I just got the game and was wondering what the best code is to update to? It came with 1.57 already and a friend mentioned that the latest code has some issues. Thank you
#8216 34 days ago
I went to 1.60 right away. I do not notice anything but I did not have the previous version to compare it against.
#8217 34 days ago
Quoted from splitcms:
Just wait. Some people have had issues with the new code, others have not. 1.57 has all the rules so there is no need to rush to update. Wait until the next release which hopefully will remove any bugs.
#8218 34 days ago
You can go into the menu and put the game back to original settings! or do you have to have it on the USB to do that?
#8219 33 days ago
Besides bug fixes I really would like to see more gimmicks and hidden features. Funny moments now and then would make the experience even more humorous - like on the good old B/W machines.
#8220 33 days ago
Quoted from LTG:
Drop an 8/32nds locknut in there will do it.
I'm going to give this a shot. I want through four trap doors in one year. I got so tired of replacing them ,that I just shut the trap door mechanism off.
#8221 33 days ago
It'll work, do it. I did.
I didn't think I was missing much without a trap door, but really it changes the game. So much more fun.
#8222 33 days ago
Quoted from MEuRaH:
Thanks,I'll pick up a 8/32 lock nut at Home Depot tomorrow. It's been so long since I've fooled with the trap door,do I need to take anything apart to drop the lock nut and into the sleeve. I'm sure I'll know the answer when I lift the play field,but I was just wondering.
#8223 33 days ago
Of course. That coil isn't hanging there in thin air.
#8224 33 days ago
OK. I'm having trouble picturing out the "drop a 8/32 lock nut into the sleeve". Can someone please show a picture or a sketch of this? Sorry but sometimes I can be a little slow . . .
#8225 33 days ago
Just got this game and haven’t really been able to play yet. Issue after issue. My switch 13 (theater entrance) is open now that I need to try and fix later today.
#8226 33 days ago
Just had this happen to me a few weeks ago for the first time. In my case the opto had just come unglued. A dab of hot glue and I was back in business.
#8227 32 days ago
Quoted from LTG:
Thanks for the kind reply to a dumb question.
#8228 32 days ago
Quoted from crwjumper:
Two pictures. Hope you can figure out the drop a nut in and where it should land.
#8229 32 days ago
Easy enough.
Thanks Lloyd!
#8230 32 days ago
What is the flipper angle set to on your game? I found Bob to be a 'harder than it should be' shot off the tip of the flipper with a bit less power than desirable. Nothing is worn or binding on the flipper itself, I think it's just the angle of the bat. Here is a picture of mine with the right lowered a slight amount for testing purposes. Judging by videos I have watched on youtube, the left flipper seems a little high. That's the one I have not adjusted yet.
Rob
#8231 32 days ago
So I got impatient and set the left flipper a bit lower to match the right. I also adjusted the flipper EOS so they close just as the flipper reaches maximum stroke. Before, shots to the left ramp and Bob always felt weak. Now there's plenty of strength in these shots. So it would appear that EOS switch adjustment is pretty critical to having good flipper strength on this game. And correct flipper angle is important too of course!
Rob
#8232 31 days ago
Is there a way to adjust the Flap Gate Assembly (the one in the bumper area)? Sometimes the ball is stuck there as in the fully opened position it‘s still not high enough (I have to wait for a ball search to free it as nudging doesn’t free it). I think it’s exactly the hight the playfield protector takes. I tried to bend it a very little upwards but this doesn’t seem to help much.
I think next time when it happens I‘ll take a photo as it looks somewhat funny.
#8233 30 days ago
Game working yesterday, booting issue. Any help appreciated.
#8234 30 days ago
Quoted from Tmezel:
If you turn the game off. Turn back on, and same thing. I'd try putting a full install in, start over.
#8235 30 days ago
The operating system is throwing I/O errors because it has having a hard time reading / writing to sections of the drive. I would try as LTG suggested and do a full reinstall, but if the drive is failing, you will need a replacement.
18
#8236 30 days ago
#8238 30 days ago
Quoted from DeeGor:
What if the hard drive fails and must be replaced? Only put in a new ssd and install the code from the jjp website?
#8239 30 days ago
Quoted from LTG:
It worked. You are the man!
#8240 30 days ago
Quoted from ClarkKent:
Yes to both.
#8241 30 days ago
Boom new code... cant wait.. love jjp and di
#8242 30 days ago
Woohoo
Can’t wait to see what’s in it!
JJP rocks
#8243 30 days ago
Quoted from GrimDog:
Awesome news! Can't wait, great to hear that Dialed In is getting another code update
#8244 30 days ago
Finally, I game I didn’t sell gets some new code. Must be some interesting stuff to make it stream-worthy. Still rocking 1.57, feels perfect as-is but right on!
#8245 30 days ago
If I'm running 1.57, what will I need to do to go directly to 1.70?
Thanks in advance.
#8246 30 days ago
Quoted from dirtbag66:
Too early to tell, it isn't up yet. Could be a full install, could be a delta.
You have to do a full install of 1.60, and then a delta of 1.61 to be up to date.
#8247 30 days ago
I don't think the ball should be stopped for the spinner shot since that's not what spinners do.
This shaker is extremely anemic to the point I barely notice it's there. Is there a way to make it stronger?
Rob
#8248 30 days ago
Quoted from Rob_G:
Settings - Coils - General - Maximum Shaker Strength
#8249 30 days ago
Anyone else ever get the "participation award"? I had a ball where I hit nothing, no ball save and saw on screen that I was awarded 800 points as a participation award lol! Nice touch.
#8250 30 days ago
Wonka has the same thing but it’s off by default. If you set wonka to allow zero bonus you get cute clips instead of the default minimum one wonka bar.
Gweem's Mods
12,000
Milford, CT
7,800
Sale Pending!
Austin, TX
$ 399.95
