(Topic ID: 177016)
Dialed In Owners and Fans Club
By goren1818
2 years ago
  • 9,055 posts
  • 494 Pinsiders participating
  • Latest reply 20 hours ago by Mageek
  • Topic is favorited by 165 Pinsiders
There have been 1,088 images uploaded to this topic. (View topic image gallery).
22 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 9055 posts in this topic. You are on page 161 of 182.
#8001 88 days ago
Does the flipper lift up from the playfield? Should move 1/16th of an inch sounds like to tight to the bushing
#8003 88 days ago
Quoted from nitrojcrawf:
The flipper is not rubbing on the playfield, it is above it, doesn't have the up and down "play" or wiggle that the other ones do though if that makes sense...
#8004 88 days ago
Quoted from pin2d:
When I took it off, there is still resistance for some reason...
Does the flipper bat/shaft move up and down a tiny bit. So the pawl isn't binding on the nylon bushing the shaft rides in ?
#8005 88 days ago
It needs some up and down play.
#8006 88 days ago
Quoted from LTG:
It doesn't seem to move up and down at all.
#8007 88 days ago
Quoted from LTG:
How do I check this?
#8008 88 days ago
Quoted from pin2d:
http://www.performancepinball.com/uploads/1/7/3/2/17325106/1919440_orig.jpg
Basically the flipper bushing sticks through the playfield. If it is too tight the flipper won't rotate correctly or in your case return. You may have to loosen the pinch bolt and re adjust. You can adjust the top or bottom side. A couple business cards will work too if no flipper gauge.
#8009 88 days ago
Quoted from pin2d:
#8010 88 days ago
Look at you. You one up'd me...lol
#8011 87 days ago
Back in business, thank you everyone!! It was sitting on the nylon bushing apparently. Odd that it just started doing this, but fixed now. Thanks again, I'm off to get to Showdown! (More realistically Chaos in QC )
#8012 86 days ago
Q: I was in Fire mode yesterday and required to hit the left ramp. Since Lock was lit Betty kept her arm down and therefore I could never hit the ramp made switch to progress in the mode (unless I locked the ball). Bug or intentional ? Running V1.61
#8013 86 days ago
Quoted from Mageek:
You should still be able to make progress in that mode with Betty's arm down. Check in switch test to see if it's registering with a ball.
#8014 86 days ago
Quoted from FatPanda:
I assume the first switch registers fine since I have no issues otherwise, but I'll check it. Normally a ramp is not counted until you hit the second ramp made switch which is not possible with her arm down.
#8015 86 days ago
Finally was able to pick up a Dialed In LE! I’ve been chasing this title for over 2 years and the stars finally aligned Babee!!!!! Had a great game with settings set from previous owner with the SIM cards carrying over from ball to ball, this may be factory setting on the new 1.61 code. Not sure. What a masterpiece! Congratulations to the JJP team on creating such a fun pinball. This one will be bolted to the floor next to Funhouse and Roadshow!
I have a early build with playfield #67 and can’t get the backglass off, I don’t think the previous owner ever took it off in 2 years. Any tips greatly appreciated!
#8016 86 days ago
Loosen the torx screws up there on the speaker panel, there are two of them, then you can more easily manipulate the lock if it won't unlock all the way. Worst case, have someone hold the speaker panel and take those screws out altogether but remember that the speaker panel will still be attached by the wires and that it will want to fall down without those screws so have someone help you.
#8017 86 days ago
Quoted from Kingpin22:
I have a early build with playfield #67 and can’t get the backglass off, I don’t think the previous owner ever took it off in 2 years. Any tips greatly appreciated![quoted image]
My back glass wouldn’t open when I picked it up new. To avoid damaging the glass in future, when we opened it we removed the part of the lock that swings around. The glass sits in place nicely unlocked. Don’t want to scratch it from behind.
#8018 86 days ago
Quoted from TOLLS:
Check your wood supports in the backbox, where the finger is pointing. You may have to cut the notches back farther, or cut them in if not there.
#8019 86 days ago
Carry-over is not factory, you scored well by playing a nerfed game
#8020 86 days ago
Quoted from Marvin:
True it’s not factory but as a newer owner these kinds of scores still baffle me. Haven’t gotten above 800,000 yet. Struggling with scoop rejects. Not from the cliffy - they reject by hitting the metal sides of the scoop mech itself.. that hole is damn tight. Wondering if I can remove the mech and bend the sides out wider..
#8021 86 days ago
Move the scoop back. Somewhere buried in here is a post with a few pictures a gentleman posted showing the process.
#8022 86 days ago
Quoted from Mbecker:
even from a right-reverse shoot ?
#8023 86 days ago
and OK, carry over SIM cards is not factory, but let's admit this is the way it should be, as it its more than hard enough already (never reached showdown)
about the backglass, mine was also blocked... the previous owner did forget to replace the 2 wood-blockers, than the TFT screen free ityself during transport to my home, and was pushing on the glass :/
i finally (sweat...) get it by pushing just enough in the backbox, but for sure i know now that i was lucky to not break/damage the BG
than listen to the guys above, much better than doing (stupid) thing while under hurry
and good score already, have fun with DI, for sure one of the best pin on the market
-2
#8024 86 days ago
Quoted from RipleYYY:
no, it shuldn't be that way out of the factory, the game is too easy that way.
#8025 85 days ago
Modes and SIM cards are huge. I would say they net more points than any MB or other aspect of the game. Even getting just 1 SIM card will double the scores on the next mode. And it gets exponentially higher with each SIM card 3x, 4x, etc.
Get your phone scoop adjusted and perfect, and I would recommend (again) a Mantis protector over a Cliffy protector.
#8026 85 days ago
Quoted from Marvin:
If it is, either you have it set up too easy or you should be competing with the pros.
12
#8027 85 days ago
You know what I say? If someone wants to set there game up so that they score 50 million on it every time they play, so be it. It's their damn game! Let them enjoy it how they want. We aren't competing with one another. Whether it's "nerfed" or "factory settings", who cares?
#8028 85 days ago
Quoted from Marvin:
+1 with Tranquilize above...
are you Keith Elwin ?
-2
#8029 85 days ago
This is exactly the problem with carryover, you get huge multipliers even if you fail to collect the sims since you get extra chances at it. This makes the game way too easy to score on.
#8030 85 days ago
Quoted from dirtbag66:
They totally can do what they want to their game, if they want to rubberband the outlanes and play with the glass off go ahead. Never said they can't.
#8031 85 days ago
not at all, just an average Marvin, who likes a challenge. Scoring high by making a game easy isn't as fun.
#8032 85 days ago
Quoted from Marvin:
It still makes it difficult. I've played it both ways, and I can't say that I perform better one way vs the other. As a matter of fact, I had a game where I had carryover set up, but collected the 6 SIM cards that I collected that game on one ball. For me, that was a "once in a blue moon" ball. Would I have done as well if they were spread across 3 balls? idk. I haven't been able to get as many cards since, and it's still set to carry over.
Whatever your cup - set it up how you like it. Whether it's extra balls on points instead of replays, loose tilt bob, closed up outlanes, 5 ball games etc, doesn't matter what other people think about how you set up your machines. For me, I think I'm doing the game a disservice by setting it up too easy but if JoeBlow wants to do it, doesn't bother me any.
#8033 85 days ago
Quoted from Marvin:
I love a challenge too,and this pin has it in spades!
#8034 85 days ago
With my skill level, I'm on Team Carryover
#8035 85 days ago
Quoted from Marvin:
yep, OK, but saying its "too easy" !?
not sure what is average when you're talking about you...
i'm right now ranked 506 (and call myself a good player), i dont feel DI being too easy with SIM carry over (on factory settings of course)
my hiscore is (only) 7.3M, with D-I-A-L-E-D collected, while I-N letters were blinking/ready to collect...
#8036 85 days ago
I hear you,6,5M is my High after a year of owning.Dialed collected
Armageddon rocks in Pat Lawlor style
-2
#8037 85 days ago
7.3M on dialed in is an absolutely huge score that's the point. The shots are not easier, you're just score inflating by doing carryover. Your score are meaningless when you do that. You can't even consider your scores against other people since you are playing an inflated version.
#8038 85 days ago
Don’t give a cr ap what other people score.
#8039 85 days ago
Score comparisons count and are relative only to the pin being played. I've played our DILE for a year and a half and have only been able to get as far as lighting the "A". My wife has achieved about the same level. I played half of the disaster modes only twice to achieve that mode. We've moved on to regularly playing JJPOTC more than DI now (for about the last 5 months) and are having a blast with that. Wonka is ordered and will arrive in a couple of months. After seeing other people turning on the Sim carryover and feeling more accomplished and getting through the game further, we want to progress further in the game to see those modes also.
That is what game setting adjustments are for … to adjust to the player level for their personal enjoyment. Our friends and relatives never achieved 1 Sim card (in 5 pinball parties held). We need a "second honeymoon" with this pin to keep the interest in it and to play it more often. Last weekend I changed our settings for Sim carryover, which is more justified in my mind than changing some of the other settings. This will hopefully pull us back in for some interest and friendly competition. I'm not a tournament level competitive player. If we start to regularly achieve the final mode, then we will adjust. But that will require us to "play better". We need to keep some interest in playing this pin while new ones come in. Are the modes fun? Of course they are … so we need to get to them. The high scores on our pin will only relate to the others that play it, and not to other people's pins or location pins.
#8040 85 days ago
Quoted from KingBW:
Wait, you can light the “A”???
#8041 85 days ago
Quoted from Nokoro:
D-I-A is as far as I have been able to achieve (3 sim cards). I've lit that sim card a lot, but usually drain before hitting that hard shot.
#8042 85 days ago
Quoted from KingBW:
Yeah, I was just having a bit of fun. I get the A about 1 in 50-100 games. DI is a very hard game under default settings.
#8043 85 days ago
Quoted from Nokoro:
Exactly! That’s why I’ve already turned on sim carry over. It’s not About trying to inflate my final score —- it’s about being able to have a shot at one day completing all the damn letters and playing showdown.
Had two 500k games to start and then put up my first 1mil+ game today. Hoping they continue to get better.. collecting all those letters still seems impossible
#8044 85 days ago
A backhand? I can hit those 90% now — figured out the sweet spot. But from the left flipper they are very very difficult and iffy..
#8045 85 days ago
+1 for team carryover - it is a nice feeling knowing that sim card isn‘t lost forever after a drain.
#8046 85 days ago
nice than
same here... shoot from left flipper have to be perfect, else its a reject
#8047 85 days ago
Quoted from KingBW:
you get to exactly the same number of modes with carryover on or off, you collect more sim cards (score inflate) with carryover. playing 5 modes and collecting one card is the same number of modes as playing 5 with carryover and collecting 4 sims.
#8048 84 days ago
Quoted from Marvin:
I think he was referring to the mode he hadn't yet played, Armegeddon, the one which requires collecting Sim cards.
#8049 84 days ago
Quoted from RTS:
heu...
armageddon is not a mode (as a mission), but a wizard mode
and the (big) wizard mode requiring collecting SIM cards is not armageddon, but showdown...
than, to be clear :
playing modes only, and you 1st get CHAOS (mini-wizard), than after ARMAGEDDON (wizard)
playing modes, finishing them and getting SIM cards, you get the SHOWDOWN (big wizard)
#8050 84 days ago
In theory you can light SIM cards by completing modes and a handful of other ways too.
In practice I have only lit SIM cards by completing modes (proper or Big Bang)
Anyone ever light a SIM card other than completing modes? If so have your incorporated this into your game strategy? Any suggestions for someone that is jonesing for more SIM cards (aside from carryover)?
$ 76.95
7,500
Charlotte, NC
$ 239.00
Tilttopper
