New! Dark mode!
(Topic ID: 177016)
Dialed In Owners and Fans Club
By goren1818
  • 11,023 posts
  • 581 Pinsiders participating
  • Latest reply 3 hours ago by Tranquilize
  • Topic is favorited by 207 Pinsiders
There have been 1,354 images uploaded to this topic. (View topic image gallery).
23 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 11023 posts in this topic. You are on page 157 of 221.
#7801 1 year ago
didnt remember... armageddon may be
#7802 1 year ago
Quoted from drizzt76:
Does anyone know what lights the "special" in the outlanes? What does it do? Thanks!
Spell "dialed" and special will be lit. I think it rewards points.
#7803 1 year ago
Quick question for the Dialed In crew:
Do all versions of the game include a RCA jack for external speaker? Going thru the 'Compare' sheet at JJP, seems like the standard version contains most the key elements as the LE (i.e. no playfield toys were removed) and I didn't see any indication of the RCA connector being removed. Seems like most of the upgrades were cosmetic.
#7804 1 year ago
Quoted from mbwalker:
Only WOZ had that. Not sure about Yellow Brick Road one since the cabinet change for boards in the head.
#7805 1 year ago
Thanks LTG! Glad I asked. DI is on the short list for the next pin.
#7806 1 year ago
Easy to hook up anyway, people here have done it and can help.
#7807 1 year ago
Quoted from LTG:
I have done it on most my pins using a PAC SNI-35 which is essentially takes a balanced high level input to a low level unbalanced output suitable for (in my case) a mixer for the subs.
I thought all the JJP pins had the RCA output. No biggie, just would have been nice to just to plug in an audio connector for a change.
#7808 1 year ago
Hey guys. Love the game, but one pf my light boards simply does not work. Fuse is good.... what do I do? I wiggled the connection and it worked for a second, but now nothing.
I assume it is part 1735, if that helps? The one that leads to the apron light board (which also doesnt work by proxy).
#7809 1 year ago
I figured it out. Cold solder joint under the cat 5 cable.
#7810 1 year ago
Has anyone here NOT taken the mylar off their magnets?
#7811 1 year ago
Quoted from jorant:
I have not. I haven't had any issues.
#7812 1 year ago
Quoted from jorant:
I just bought a game that shipped with mylar on the magnets and has a few thousand plays since then. It doesn't affect gameplay but is pretty torn up on the magnets themselves so it's a bit of an eyesore.
#7813 1 year ago
Quoted from jorant:
The ball will shred the Mylar, so it's either coming off neat and clean or shredded.
#7814 1 year ago
Quoted from Tranquilize:
So weird that they made them like this. I'll remove them right away. What a pain!
#7815 1 year ago
Quoted from mettle64:
Pictures, please?
#7816 1 year ago
I removed the mylar on my magnets once they started getting torn up. Was looking pretty ugly.
#7817 1 year ago
Turns out my light board is still bad after all. Nothing I do fixes it properly. How do I get this replaced??
#7818 1 year ago
Quoted from jorant:
If under warranty - jerseyjackpinball.com - Support - Help Desk.
Under warranty or not, call 732-364-9900 during business hours.
#7819 1 year ago
Quoted from RipleYYY:
i dont think we have to create a separate topic, as DI code is not Ghostbusters...
but in the same time, these few codes post are in the middle of all others...
we all know Ted is on pinside, and so on this topic, but he may just not read all just because he has something else to do
i had some direct mails exchanges with him already, i'm OK to summarize all latest ideas to simply submit them
well than, something else you wanna say about the code ?
- making the 3 BOB targets "rotating" with the left flipper button (as in CAPCOM PINBALL MAGIC) ... lower B is/seems actually impossible to get with a direct shot
- making ball search routine starting with the QED guy
- spinner in the theatre not always spinning (magnet activity) because of the various situations (not sure something could be done here)
- set up/maximise/change the possibility of looping again and again the left ramp (right flipper shot, left flipper pass) whith the 10.000 hurry up... i did this as skillshot while starting a game, my record is now 35 or 36 (see pic somewhere above)
- theatre multiball : when ready and shooting it to start it, cut the magnet sooner, to avoid having a second ball shot in there and having the 2 balls "glued" to the magnet (lets admit it's possibly my balls (oups) fault, being magnetized !?) ... sometimes i even can put a 3rd glueing there too, sometimes it helps to free the 2 others
nothing more ? sure ?? really ??? ... will wait till next WE then mail Ted
#7820 1 year ago
My sound is all staticy and jjp sent me a noise filter. Question how do i get the moniter out of the way? Looks like 2 screws on either side of it. I thought it would swing out or something but it's in there solid.
#7821 1 year ago
It’s on a big pivot arm. Unlatch on each side, then pull forward and pivot. Do this with game power OFF
#7822 1 year ago
Quoted from Marcdaddy:
In small wooden blocks ? Loosen, turn the block. Then this -
Quoted from Pinballomatic:
Once the wood block is turned, pull the latches up. When finished, I would turn the wooden block and retighten the screw. So the latches are locked down.
#7823 1 year ago
Quoted from LTG:
Here's is what I got.
Do loosen screws?
Screenshot_20190525-131254_Messenger (resized).jpgScreenshot_20190525-131259_Messenger (resized).jpgScreenshot_20190525-131302_Messenger (resized).jpg
#7824 1 year ago
Red circle/arrow points to screw you loosen to turn wood block. I don't see one on the right side in your picture. Yellow arrow points to latch you pull up, one each side.
#7826 1 year ago
UPTODATE
- erratic coils power in 1.61
#7827 1 year ago
Guys I'm new to Jjp and have a question, My subwoofer seems non existent. I hear high treble coming out of it but really no bass. I looked in the setting but do not see and Treble/bass adjustments like my Sterns. Is this correct? Thanks.
#7828 1 year ago
My suggestion would be to only show the spinner when it's the only Q-mode lit - that is, when it's going to actually _act_ as a spinner.
When some other mode is lit (like Train Bash) that's going to stop and "reject" the ball, _that_ mode should be showing on the display, instead of the spinner.
I am really, _really_ tired of the random coil strengths. Reverting from 1.61 to 1.60 made it _somewhat_ better, but it's still an issue; from the phone, for example, I get everything from hitting the wireform above the scoop to not getting out of the scoop at all.
#7829 1 year ago
There are no settings for treble and bass. Just sound mixer options. I’ve been wanting to add a sub to mine...especially for the Big Bang effect! If you put it up passed 25, you get some decent bass out of it
#7830 1 year ago
#7831 1 year ago
I've had that happen on Baywatch with a 6 ball multiball. I couldn't nudge it free and had to take off the glass I miss that game.
I knew I had a pic of it somewhere...
#7832 1 year ago
Quoted from FatPanda:
"round" nudging was enough here, only a warning was lost...
#7833 1 year ago
I knew I had a pic of it somewhere...[quoted image]
respect ! lol
#7834 1 year ago
My shooter rod black ball/handle cracked apart....again. Its the second time this happened. This one only lasted maybe 30 games. Anyone else have this problem and is there a premium aftermarket shooter rod to replace it with?
#7835 1 year ago
Two shooter rod handles? You've got the barrel spring installed right? Seems really odd. Modfather has shooter rods available, as well as many other places. I recall a candy color shooter rod offered at some point but not sure as I'm not into modded rods...
#7837 1 year ago
Been a few weeks since accepting my DI LE.. Attempted to connect my android phone to just check it out, but was un-able to get it to work. My phone sees it then asks for the 4 digit security PIN.
Is their a default pin when this occurs ? I tried 0000, 1234 and no dice.
#7838 1 year ago
I'm going to order one. The springs are correct. Honestly looking at it I don't know you could screw it up. Thanks!
#7839 1 year ago
Check your assembly of the rod and housing according to the manual. Sounds like they may have a assembled it incorrectly at the factory. That shouldn't be happening, let alone so quickly.
#7840 1 year ago
Quoted from drained:
I've gotten the app to work twice. Every time since, nothing.
The thing that's frustrating is JJP used this feature to help hype this game up. And now it doesn't even work.
#7841 1 year ago
Quoted from dirtbag66:
it's kind of meaningless, it worked for me using my android phone, but I never used it. All you can do is flip with it, not very fun and just gimmicky.
#7842 1 year ago
Quoted from Lermods:
After the very first code update, it work flawlessly and it was super fun if playing with more than one player. The utilization of bang and lack of nudging changes the game completely. Standing further away from the machine or beside it is super fun too. The issue is that there are so many freakin' phones and different handling of bluetooth. I really wish they could put some resources toward it as I, for one, miss it dearly. Seeing the jaws drop when people first see it is worth it.
I can get mine to work if I reboot/recoonnect cycle my phone. After I get it to connect, it's laggy enough that it's not worth it
#7843 1 year ago
I have a big need/want for the phone app to work correctly. My best friend has one paralyzed arm, but loves to play pinball. This was one of the main reason I bought a DI. It worked 1 time, and now just get spinning wheels trying to connect. My friend uses his knee for the left flipper. Does pretty good with it, but the app for this game would be better for him. I also wish that JJP would spend some time to fix it or help us.
#7844 1 year ago
Awww, how cute.
#7846 1 year ago
Quoted from KingBW:
You're a good friend!
#7847 1 year ago
I have the chrome candy rod and it looks great. But I agree with the others. Before you get another, figure out what is causing them to crack. That’s not normal.
#7848 1 year ago
UPTODATE
ok, just mailed Ted...
#7849 1 year ago
The dongle may not be working
#7850 1 year ago
Updating code on DI hasn’t been smooth on my example either.
Last time I updated, it did turn out to be the dongle.
JJP promptly sent me a replacement dongle and sure enough it immediately rectified the issue.
I do feel JJP’s customer service has been exceptional.
Each time I’ve had an issue, they’ve been very responsive to resolve the matter.
Once, when there was a delay on the replacement of my defective phone, they even sent me a t-shirt as a thank you for my patience.
Very impressed.
12,500
Milford, CT
$ 50.00
7,500 (Firm)
Miami Beach, FL
