Quoted from RipleYYY:on factory setting, how is the outpost/right outlane position ? i suppose at the middle ?
on mine its close at max (previous owner), and i want to play as evbd else
tanx
Yes, middle.
tanx
Yes, middle.
What are people using for headphones? I have some old shitty ear buds that work well but I want some quality headphones. Just went through 3 brand new pairs today. All sounded like shit. Completely muffled and static. Put my $5 ear buds back in and they sound great.
I want headphones so other people can use them too. Just tried 3 different ones ($100) range. Surprised how bad they all sounded.
So I guess 1.60 was released on the 12th?? Not sure how I missed this. I haven’t read any posts about it here. I’ve been running 1.57 for a month now and loving it.
JJP website says..
== Version 1.60 December 12, 2018 ==
== 1.60 ISO image MD5 checksum: 69e5af7d43af7f8455ca048c40584af8 ==
- NOTE: This is a FULL INSTALL release
=== Game Code
* Fixed ability to cancel Disaster Mode intro phone call by hitting both flippers
* Fixed occasional game reboot when multiple high score champ entries made
* Fixed trap door updater to close door when awards are not available
* Adjusted usage of drones
* Polished up some lamp, speech, and music choreography
* Fixed airplane banner and UFO animations
=== Core Code
* Fixed UK pricing presets
=== OS
* Support for newer motherboards”
I’m curious about the drone adjustments. Awesome!
Junky
Quoted from ClarkKent:Where to bend exactly? It's only slightly rubbing on the upper corner of the phone when moving the glass, nothing big.
And the yellow flash of QED is also very slightly touching the glass when moved to the right position (yellow flash bends back a little bit when reaching that position). Like this:
https://www.dropbox.com/s/rm60oszi19dbsiy/DIShield.mov?dl=0
Checked the playfield underneath but it's correctly in the support rails, slope is also correct (bubble at the second marker). Weird.
If both are touching, your PF is too high. Pull the brackets off the machine, put them in a vice (protected for scratching) and bend the hooks up about 4mm. Reinstall and enjoy your game. If the phone is still touching, you should be able to just grab the phone and gently adjust it downward. I've done the phone adjustment myself, but I udjusted mine upward.
Quoted from imagamejunky:So I guess 1.60 was released on the 12th?? Not sure how I missed this. I haven’t read any posts about it here. I’ve been running 1.57 for a month now and loving it.
JJP website says..
=== Game Code
=== Core Code
=== OS
Junky
Interesting. I wonder why this is a full game install instead of a delta upgrade.
well, quite simple, this is a fresh file available, as 2 days ago i've dowloaded last version for my just arrived DI, and it was 1.57, no 1.60 on that page
With 1.60 you can disable disaster mode intro with flippers. Can we disable this new ability in the settings ?
This sounds fool, but I want (and my children too) to see animations.
Quoted from gliebig:What are people using for headphones? I have some old shitty ear buds that work well but I want some quality headphones. Just went through 3 brand new pairs today. All sounded like shit. Completely muffled and static. Put my $5 ear buds back in and they sound great.
Grado sr80
Installed the new code (v1.60) and played a few games. I noticed some animations on each of the three screens were choppy, and the theater animation has a line on the far right side "out" (not an image but a line of color). Anyone else see this?
I finally found a way to make this game a rock-solid player. I took the post rubbers off on either side of the sim hole and replaced them with ones I ground down on my grinder. They widen the shot by about 5mm, which makes a HUGE difference. Now I can turn sim memory off. The shot is still very difficult, but the bounce rejects are cut in half, and roll ins have increased by about 20%. I checked with a ball, and you could go more, but I think 5mm feels right.
Quoted from Nokoro:Interesting. I wonder why this is a full game install instead of a delta upgrade.
I believe the “support for new motherboards” includes drivers which are installed in the OS and not just the game code - and which requires a full install.
Any other ideas? So I tried some Velcro tape on the ball trail for the right ramp, but on fast shots it bounces back quite often.
In this pic, you can see a vertical "ball trail" on the left of the left orbit exit ->
Which tells me that the ball is getting airborne from the ramp leading up to it. The metal flap in front of the front is ever so slightly raised a bit, which could be a problem though I don't know how to make flush since its riveted into the ramp...
Quoted from Gogdog:Any other ideas? So I tried some Velcro tape on the ball trail for the right ramp, but on fast shots it bounces back quite often.
Try lowering the power on the left flipper slightly.
Quoted from Shredso:2nd, is this a broken post or is something missing?
Metal post, no sleeve.
Quoted from Shredso:New LE owner here. 2 questions. Are you using stock flipper strength? Mine feel a little weak. It's a HUO games bought less than a year ago, shouldn't need a rebuild yet.
JJP flipper strength varies a lot from home to home. It even varies throughout the year as air conditioning takes away power. The flipper strength, like the strength of all coils in the game, is very adjustable. Don’t hesitate to bump it up to a level that suits you. I often readjust a few times each year.
Quoted from LTG:Metal post, no sleeve.
Just to make sure we are talking about the same spot, there is an empty female thread on the bottom left corner of the "Hurry Up" insert. This is between the outlane and the left inlane. I just checked the manual and I only see the post directly under it.
Quoted from Shredso:Just to make sure we are talking about the same spot, there is an empty female thread on the bottom left corner of the "Hurry Up" insert. This is between the outlane and the left inlane. I just checked the manual and I only see the post directly under it.
That hole. You can move the post near it to that spot to change the ball drain, if you want.
It's called the pussy hole. If you want to be a pussy, move the post to the pussy hole.
Quoted from mtp78:Any news on 1.60..... ?
You mean the one available for download from jerseyjackpinball.com under Support - Downloads. Change log is there too. Along with full instructions.
Quoted from lancestorm:Grado sr80
I'll check those out. Anyone else have issues with headphones? Odd that my carp earbuds sound great but the headphones have all been terrible. Could it be an issue with my game?
Quoted from Nokoro:Try lowering the power on the left flipper slightly.
Yeah, unfortunately I already have done that (to make things like the theater shot easier). Hopefully there is some other thing I can try before I resign to just accept fast right ramp shots have a high possibility of backfiring.
Also...got the crazy bob thingverse holder installed today! Big thanks to a local friend for 3d printing it for me ->
Only thing I needed to do was drill a hole on the bottom for the screw. I'll still need to go to Ace and pick up a slightly longer screw, though the original can hold it but its just half threaded into the nut.
I also needed to Dremel out the hole for the LED cables. I'll use double sided tape near the bottom to make sure it doesn't move from its position. If I ever see a ball catch at the top I'll just add a tiny bit of foam to prevent it from happening again.
Quoted from Gogdog:Yeah, unfortunately I already have done that (to make things like the theater shot easier). Hopefully there is some other thing I can try before I resign to just accept fast right ramp shots have a high possibility of backfiring.
Hmmm. Maybe a longer strip of Velcro tape. The trick is to slow it down enough so it doesn’t jump or bounce back.
Quoted from Nokoro:Hmmm. Maybe a longer strip of Velcro tape. The trick is to slow it down enough so it doesn’t jump or bounce back.
Wouldn't that also negatively affect every other shot too like slower shots now not making it because it slows down too much, or the auto plunger now not making it, etc?
Quoted from Gogdog:Wouldn't that also negatively affect every other shot too like slower shots now not making it because it slows down too much, or the auto plunger now not making it, etc?
I think it is a balance. You want to find the sweet spot between slowing down the really hard shots and not the others. Also, the auto plunge strength can be adjusted to compensate.
Maybe the modcouple could make some sort of plastic cover that could go over the ramp flap to stop the ball from going airborne.
Quoted from Tranquilize:If both are touching, your PF is too high. Pull the brackets off the machine, put them in a vice (protected for scratching) and bend the hooks up about 4mm. Reinstall and enjoy your game. If the phone is still touching, you should be able to just grab the phone and gently adjust it downward. I've done the phone adjustment myself, but I udjusted mine upward.
You mean the two rails at the left and right of the cabinet on which the playfield rests? Or the ones on the playfield? I do not fully understand - do you have a photo or simple drawing what to do?
On the other side I wonder if it wouldn't be easier to shorten the flash a little bit and bend the phone a little bit downwards (but apart from that the phone is really no big problem as it is only rubbing slightly one the glass when removing it).
Quoted from Pinballpal:Maybe the modcouple could make some sort of plastic cover that could go over the ramp flap to stop the ball from going airborne.
that would block the ball coming around the jump from the left orbit
Here's my analysis/solution...has been working great for nearly 1-year now
https://pinside.com/pinball/forum/topic/dialed-in-right-orbitramp-ball-rejects
snaroff
I updated to v1.60 this morning, and I'm seeing new issues.
I've never had problems with my drones before, but now they're mainly just off. Every 3-4 hits to the drones area, and the top drone will spin about one revolution slowly. The other two drones do not work at all. Again, they were fully operational before the update.
The other thing I've found was the main display's animations are kind of choppy. It feels like a lower frame rate.
Any one else experience these issues?
Quoted from Indusguys:I don't think I will be updating until bugs are ironed out.
Ditto staying at 1.57 until refinement has been achieved. v1.57 has been awesome and I'm content with it
1.6 looks good to me (no choppy animations). The readme says "Adjusted usage of drones", but I can't say I noticed any big change.
The only difference I've noticed (in 2 games played) is more drains from the The Quantum Theatre magnet...probably the result of losing some tweaks to the default settings.
The change log for 1.6 is really short, so it's unlikely there is much to freak out over. I have to imagine any 1.6 bugs will be squashed in a minor update, so doing a 1.6 full install seems like a requirement at some point.
snaroff
Quoted from Allibaster:I updated to v1.60 this morning, and I'm seeing new issues.
I posted the issue with the animations a few posts back but no one in this club responded. I'm seeing this also.
I’ve played about 20 games on 1.60 and thought I would chime in with my thoughts.
If you’re hesitant about updating, don’t be. It’s fantastic.
-I see no issues with any animations.
-Transitions during gameplay seem somewhat smoother to me.
-The drone propellers seem to be spinning less frequently than before during a game but they work fine during test mode. I’m assuming this was changed to try to stop the little motors from burning out because SO MANY people have had to replace them. I’m on my third set now myself.
-I had to adjust the value of the theater magnet timing to make it throw correctly. I’m at -150 now.
-When you have qualified but not collected more than one SIM card you will see the correct amount of flashing DIALED IN letters. Before only one letter would flash at a time. I like this change.
-When you flip to cancel the beginning of multiball you will still hear “now you’re dialed in” and see the white LEDs flash. I like this too.
-I think some new disaster mode animations and audio were added. I’ve seen a few new ones.
On a completely unrelated side note, I noticed in the settings that you can adjust how aggressive you want the magnet behavior during multiball. I’m sure it was there before but I didn’t see it. The default is EASY. I changed mine to DIFFICULT and I love it! It makes the magnets A LOT more active during MB. Awesome!
This A+ pin keeps getting better.
Quoted from snaroff:Here's my analysis/solution...has been working great for nearly 1-year now
snaroff
I like it! Two questions:
1. Any reason why I would need to buy the vinyl electrical tape vs just normal black electrical tape? Is the vinyl stickier, or thicker or ?
2. A bit hard to tell from your pics on your other thread...but do you have some tape actually on the metal flap or is it entirely just in front of the flap?
Has anyone’s phone gone to a white static? It doesn’t happen when the game is just on, but it happens during game play. The only way to fix it has been to power off and on.
Quoted from ClarkKent:You mean the two rails at the left and right of the cabinet on which the playfield rests? Or the ones on the playfield? I do not fully understand - do you have a photo or simple drawing what to do?
I mean the two brackets (hooks) that hold the pf to the lockdown bar bracket. Pull the pf up on its supports, take the screws out and bend them in a vice. Screw them back on and yer done. I would bend them at the corner of the L so that the hook is about 4mm higher. I'm pretty sure W/B have a slot instead of a hole on the brackets so that you can adjust them. Maybe I'm remembering wrong though. I've put some bad things in my brains over the years.
Quoted from Gogdog:I like it! Two questions:
I happen to have vinyl/blue around and it seemed to do the trick. Color doesn't matter, but whatever tape you use should be on the thicker side and slick/smooth (i.e. no texture).
There is no tape on the metal flap...just in front of the flap. The idea is to make a smoother transition so the ball doesn't "skip" on the thick flap. JJP seems to like thick flaps, but they cause problems like this. The "best" solution is to remove the thick flap and install a thin flap. Unfortunately, that would involve more surgery to the ramp and access to a riveting tool (which I don't stock).
Good luck, and let me know how it goes!
snaroff
Quoted from gliebig:I'll check those out. Anyone else have issues with headphones? Odd that my carp earbuds sound great but the headphones have all been terrible. Could it be an issue with my game?
Just.tried my 5th set of headphones. I got zero sound put of them. Plug in ear buds and it's perfect. Am I missing something? I can't figure out why I get none or shitty muffled sound when I use headphones.
Edit: just returned the latest $180 pair and bought the cheapest ones they had. $29. Works fine. Not the best sounding but they work. Would still like to get a nicer set to work. Arrrgggg
Redownloaded and reinstalled V1.60 and there's definitely reduced framerate/slow down of animations. Just seems as if the system cant process the information fast enough, like when you have an old computer. Hope they fix this soon, or reupload v1.50 so that we can get back to v1.57 until they put out a smoother code.
If anyone has v1.50, I would appreciate a link!
This page was printed from https://pinside.com/pinball/forum/topic/dialed-in-owners-and-fans-club/page/131 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
