(Topic ID: 177016)
Dialed In Owners and Fans Club
By goren1818
  • 9,901 posts
  • 535 Pinsiders participating
  • Latest reply 19 hours ago by LTG
  • Topic is favorited by 191 Pinsiders
There have been 1,216 images uploaded to this topic. (View topic image gallery).
22 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 9901 posts in this topic. You are on page 124 of 199.
#6151 1 year ago
Quoted from clg:
Working from memory here... Did you check the fuse in the front bottom right of the cabinet by where the game power swtich is? It unscrews from the top of the silver box
You just beat me to it, yep there is a fuse there. Check that one being there seems to be no power at all.
#6152 1 year ago
Quoted from clg:
Yep just checked and looks fine. Starting to get nervous here...
#6153 1 year ago
Quoted from JayLar:
Don't look, always use a DDM with continuity to be 100% certain.
#6154 1 year ago
Quoted from DeathHimself:
I think I am gonna call my techie...
#6155 1 year ago
Quoted from JayLar:
For the hell of it if you have one, the power cord is a very common cord used on computer's, DVR's etc.... If you have one try swapping the DI cord and try powering up the machine, just rule out the power cord itself didn't go bad.
#6156 1 year ago
I had one of the cables unplug from inside the cabinet from where the power comes in. Just lifting the playfield something caught on it. You might want to check there.
#6157 1 year ago
I added a beautiful HUO DILE to the collection last week. I noticed this grounding wire not connected to anything. I'm assuming it goes right on with the other there but don't want to connect it without someone confirming. Anyone able to help?
Also, anyone else have trouble getting the playfield back in place after lifting? It almost seems like the rails are installed too far forward, by about 1/2".
#6158 1 year ago
I can't help with the spare yellow connector but DI is notorious for being difficult to reseat.
Basically the tube with the wires going from the playfield to the backbox bumps against the back of the playfield.
Just give it an extra push and it will go just fine.
#6159 1 year ago
Quoted from play_pinball:
Did you remove the packing foam at the back end of the playfield during set up?
EDIT: Never mind. Just noticed you bought HUO not NIB. Sorry.
#6160 1 year ago
Yes, it gets bolted on there. Turn game off. Remove the nut, slide it on, replace the nut. Tighten it.
#6161 1 year ago
Thanks Lloyd!!
Quoted from Nokoro:
Actually, I did have to remove that but it didn’t make putting it back in place any easier. I saw the notice to remove it but ended up putting it back on. When I had it off I managed the slide the pf off the rails and it was a nightmare getting it back out! Fortunately zero harm done in that process.
#6162 1 year ago
When you go to set the playfield down and it is tough to get down (not just back), open the coin door and make sure that the wire loop from the coin door isn't holding it up. I had that problem and had to tie wrap that wire better. Also pull back the plunger a bit while you are lowering it as the tip might be holding it up a bit. The playfield is a tight fit all the way around - even the sides.
#6163 1 year ago
My TZ is just as tough to seat after lifting the PF. Must be a Pat thing
#6164 1 year ago
Thanks for the suggestions. I did have the door open and thought about the plunger since that’s common on some of my older games, but it wasn’t in the way. I think it really just is that cable tube in the back. We had to pull it to the side. It’s that final 1/2” to get it back in place that’s a true squeeze.
#6165 1 year ago
All my B/W games are easy as pie to seat. I contacted jjp about this and was told it was a design issue and is now considered as functional. It had something to do with clearance.
If you open the coin door and use the rails, its easier to seat.
It is definitely annoying.
As an aside, Capcom has the best pf access system.
#6166 1 year ago
I'm having an issue where the e-clip on my shooter rod is brushing against the top of my automatic plunger and messing up my plunges. I can loosen the shooter housing and move it back and forth but not up and down, so I'm having trouble correcting this. Anyone have this issue and know of a solution?
#6167 1 year ago
Quoted from JayLar:
No the machine doesn´t start at all, nothing happens when switching on. Have checked the wall socket and it works. This might sound strange, but I believe the fuse might have looked like in the picture before this happened, I just didn´t change it as the game worked just fine. So my guess is that it is something else that´s wrong. What happened was that I started up the machine and after a couple of seconds it just shut down and won´t start anymore - zero power.
jaylar Have you spoken with Frank at JJP? I had the same issue, no power going to the game. Turned out the power supply crapped out...and let me tell ya, it was a bitch swapping it out.
#6168 1 year ago
Quoted from Nokoro:
You're playfield hooks may have bent down due to the weight of the playfield and shipping.
#6169 1 year ago
Quoted from bigd1979:
Thanks. I've never had that happen before. What's the best way to adjust them or bend them back?
#6170 1 year ago
Quoted from Nokoro:
They should be flat going up and down where the playfield/apron is. Best remove them to bend them if need be. Then they are easier to work on.
#6171 1 year ago
Quoted from Nokoro:
Yeah, take them off and use a vice to get them back to square. Also, be sure to use the pf support!
#6172 1 year ago
Hmmm. The hooks seem ok, but the metal seat they sit in may be slightly off on the side near the plunger. I'm not sure how to remove or take care of that.
I came up with a lazy man's solution and added a small amount of weather stripping to lift that side just slightly (see last picture). So far it works like a charm. Anything wrong with this approach? Thanks for all the help so far!
IMG_0287 (resized).JPGIMG_0288 (resized).JPGIMG_0289 (resized).JPGIMG_0290 (resized).JPG
#6173 1 year ago
Quoted from Bigbossfan:
I´ve gone through all the fuses again and believe it´s the fuse in the front bottom right of the cabinet where the game power switch is. Gonna go buy a new one tomorrow. Just to be sure - is it a 5 A 250 V fuse and should it be slow or fast?
#6174 1 year ago
Picked up a DILE this morning. I have a lot to learn and read Without reading this whole thread (which I will) any quick tips for a new owner? This is my 1st JJP.
#6175 1 year ago
Quoted from JayLar:
According to the manual if you are using a 5A 250v, it's a slow blow fuse 1.25" 3AG size
#6176 1 year ago
From my experience as a first time JJP owner. I found it best to play the hell out of it and seek answers to the questions that come up on the way. It’s a complex beast. Great journey. Enjoy. It just gets better the more you learn.
#6177 1 year ago
According to the manual if you are using a 5A 250v, it's a slow blow fuse. If you are using a 10A 125v, that also is a slow blow. It's the larger 1.25" size fuses
#6178 1 year ago
Quoted from Nokoro:
Next thing i would do would be to loosen all of the screws that hold the shooter housing in place. pull the bottom of the housing out, stick a flat washer between the inside of the bottom area of the housing and the cabinet itself. tighten the housing screws back down (starting with the bottom one). This will cause the shooter rod to tilt down slightly and should alleviate the issue of the c-clip hitting.
#6179 1 year ago
Quoted from KingPinGames:
I wouldn't recommend this as it will create ball spin, which will create other problems with the right loop/ramp.
#6180 1 year ago
Quoted from Nokoro:
Looks like you have a bent lockdown housing. Looks like a factory QC issue to me as the latches should have bent before the entire housing, but who knows. You'd have to take that out and bend it straight.
The only issue with your solution is PF leveling. If your PF is level in relationship to the cab, that would work. I would pull it and fix it or contact JJP support to get a new one. Should't be too hard to fix if you have some shop tools.
#6181 1 year ago
Got a new fuse for the power switch today and now the game is working. All good!
#6182 1 year ago
Quoted from Tranquilize:
I’m still level after my solution, but perhaps I should do what you say. How do I get the thing out? There are bolts through the front of the cab that hold it in, but the bolts have round heads and no grooves for a screw driver. I’m not sure how to turn them. I’m also not sure I have the tools for this so I may have to call JJP.
But perhaps since I’m level and have a solution that seems to work, I just leave it alone and watch it to make sure it doesn’t get worse . . . .
#6183 1 year ago
Quoted from tadowhere:
If it was a NIB game there's a ton that I would say, but judging by the way you wrote your post I'd say it's used, correct? If that's the case, most of the bugs and issues were already worked out for you. As far as settings goes, I would make it so sim cards carry over from ball to ball. I also have pinstadium in mine. It lights it up so nice and the QED guy makes the flashers go crazy. It's seriously awesome. If you're looking for a nice add-on, that would be the one I would recommend.
#6184 1 year ago
Quoted from MEuRaH:
Also all the key fixes are pinned at the top of the thread as key posts. It should take you
15 minutes to read
#6185 1 year ago
Yes it was used. Thanks for the info! I lifted pf to put cliffy's on and this dropped out of the left side into cab, any ideas on what it is/for?
#6186 1 year ago
This is the trap door flap. They can break off.
Check to see if yours is broken off. It likely is, unless someone already replaced it and this was left in the machine. Contact JJP to get a replacement by getting the full trap door (not the full mechanism) with the flap already riveted on.
#6187 1 year ago
Just wanted to say I have this same issue, the hooks have never lined up and I have to slam the pf around to get it to settle. I’ll be following your search for a solution
Quoted from Nokoro:
#6188 1 year ago
Quoted from DANGERTERROR:
Have you looked at your latch mechanism to see if it seems bent like mine? I’d be curious to know.
Right now, I’m leaning to my lazy solution with the weather stripping while keeping an eye on the latch mechanism unless anyone thinks I shouldn’t for some reason.
I’m also curious how I would even get the thing out given those bolts with the rounded heads. Is there a tool for those bolts?
#6189 1 year ago
If you mean when you seat the PF after raising it, the seating issue is a design quirk. There is no solution except to get used to finding a good way to get the PF seated. Open the coin door and use the rails to help.
#6190 1 year ago
So how good do you think the speakers are on DI? Any reason to upgrade?
#6191 1 year ago
Quoted from JayLar:
No.
#6192 1 year ago
Quoted from JayLar:
I had briefly considered this when I got the machine. I found that the aftermarket guys (Flipper Fidelity and Pinball Pro) don’t make speaker kits for JJP. Not sure why. Maybe JJP uses better quality speakers in their machines than other manufacturers?
I doubt that it would make that much of a difference anyway. It doesn’t have a great soundtrack like some of the music pins so I just stuck with the factory setup.
#6193 1 year ago
Quoted from JayLar:
I've been told an external sub on Dialed In is a good upgrade for the audio. It's on my "to do" list.
#6194 1 year ago
Quoted from Allibaster:
In my book a Polk PSW505 per game is a basic pin ownership ground rule:
amazon.com link »
Certainly recommended for DI too.
I haven't felt the need to mess with the Dialed In stock speakers, and I've got FlipFids or PinPros in all of my older games.
Sheesh--at the default volume of 26, standing at the lockdown bar I'm more than good volume and clarity-wise, and I'd expect most folks would be too.
#6195 1 year ago
Quoted from PsychoPsonic:
amazon.com link »
I second this - a Polk subwoofer on a DI adds something, but the speakers themselves are just fine.
#6196 1 year ago
I ordered a new bluetooth dongle and still get the error in test report. I really have no use for the dongle, just don't really like the error. It started when I unhooked the dongle to update to the newest firmware. I am sure the cable works as it has no problem updating firmware on a USB drive, just won't hook up to either the old dongle or a new one. Any help would be appreciated.
#6197 1 year ago
My hooks had problems the first time I got the playfield out. It took so much force I was concerned I was going to break the game. They were bent (almost fished hooked) after bending back it's easy to get in and out now.
It's a really heavy playfield it seems. I wonder if shipping is putting weight on the hooks when it is shipped vertically?
#6198 1 year ago
Anyone got the specs for the tweeters? I exchanged one of the speakers because I thought it was cracked, but seems to be the tweeter (doh!). The manual doesn´t say much about it.
#6199 1 year ago
A 10 inch Polk is more than sufficient
amazon.com link »
I also agree that a sub for every modern pin is almost requirement at this point, especially at that $99 price point. Completely worth it for DI as well. The bass drop when you complete one of the goals for QTMB is pretty awesome, and is a good audio indicator that you've completed something.
#6200 1 year ago
Quoted from JayLar:
They’re actually great sounding stock speakers IMO. You should DEFINITELY add an external sub though. I use big 12” subs on all my pins. They add a lot to the audio. And as a bonus, JJP games are the easiest to add subs on. The audio out jack on the PC can be “Y’ed” and sent to the sub. Easy Peasy.
Quoted from Yoxxy:
Try connecting your BT dongle directly to an open USB port in the backbox and see if it’s recognized. That will tell you if it’s the dongle or the usb extender that’s the issue. My problem was the extender. And this problem began after the latest update also.
For those having playfield seating issues, my suggestion is to lower it down and then reach in through the coindoor. Grab the rails and push forward while using fingers/wrists/forearms to push back against the coindoor opening. The playfield should slide forward allowing the hooks to drop in place.
Junky
$ 9,000.00
Operation Pinball
$ 21.00
Milton, ON
6,400
Fredonia, NY
