(Topic ID: 177016)
Dialed In Owners and Fans Club
By goren1818
2 years ago
  • 9,055 posts
  • 494 Pinsiders participating
  • Latest reply 15 hours ago by Mageek
  • Topic is favorited by 165 Pinsiders
There have been 1,088 images uploaded to this topic. (View topic image gallery).
22 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 9055 posts in this topic. You are on page 118 of 182.
#5851 10 months ago
Wow 34 new posts today I thought the code dropped, guess not.....
#5852 10 months ago
Does the picture of my phone look like it's defective? I replaced it about a month ago,and it's been working great . While playing tonight,the screen started to act up.
I shut the game off,and when I restarted it,the phone was okay.This is the third phone that's been installed on my Dialed In.
#5853 10 months ago
Quoted from pb_lawww:
Not sure which opto you are talking about. Right orbit has switch 52 as a rollover for right orbit enter and as a second switch the train two ramp made switch 47. switch 47 is the one i am talking about witch was not always registered at fast balls in my game. The ball was flying over the leaf. Bending it up helped and now even very fast balls sre registered.
Ahh brain fade. I adjusted switch 47 now it registers every hit. Thanks!
#5854 10 months ago
Quoted from OnTheSnap:
Happy I was able to help (even if my description typed via mobile is hard to understand ). I remember how annoying it was when the right orbit / ramp was not registered. imho everything must work 100% to make sure the game is fun.
Lars
#5855 10 months ago
Lars
You right this game needs to be
Dialed In!
#5856 10 months ago
Quoted from Nokoro:
Question: Two of my drones are acting up in that the propellers don't spin. If I give them a couple of rotations by hand, they spin again, but only for a few times, and then they seize up again. Reading other posts, it seems that these drones are a common problem. I'm worried that if I get new ones, the same thing will happen eventually. Is it worth it for me to put a ticket in? The drones are cool, but I'm not sure I want to go through the trouble of replacing them only to have the new ones fail as well.
up to you, they are cheap toy drones. they will all break eventually.
#5857 10 months ago
Quoted from Marvin:
Are there any replacement drones to buy that are more long term reliable?
#5858 10 months ago
Quoted from Nokoro:
Not sure about anybody else, but I can't even tell the drones do anything while playing. The only time I notice the propellers is if I'm testing something with the glass off. I could see buying a new set to just save until you want to sell the game so that you can have them working and not take a ding on the price from some complainer -- but I can't see spending money on new ones to just burn them out again. Hell, maybe I'll go unplug mine so they don't wear out and then plug them back in if I ever sell it.
#5859 10 months ago
Quoted from JayLar:
I've read in this thread somewhere that JJP replaces some of the components inside of them (from whoever they get them from) to make them more reliable before sending them off to us. I don't know if they did that from the start, or sometime after launch as a fix. I got my DILE last December (2017) and haven't had a problem with any of my drones ... yet.
15
#5860 10 months ago
the drones are available (banggood, ebay, etc.) just search for "cheerson cx-10a". BUT: the circuit board inside is completely different. So you can only use spare parts as the plastics etc. or fly the drone you know from inside your pinball machine.
Normaly only the motors wear out. So no need to replace the whole drone. The spare motors can also be found in ebay for small money. Search for "CX-10-005" or just "cheerson cx-10a motor".
If you need to replace a motor, check first which one is broken. As the motors are in sequence, if one is broken, all four stop working. Moving the blades one after the other while running in test mode makes it easy to identify the broken motor.
#5861 10 months ago
This should be a key post. Thank you!
#5862 10 months ago
Quoted from JayLar:
No, these are very cheap toys. look at any hobby site, retail these are inexpensive micro drones. they are not made to work forever. I don't even know why they hooked them to power. Just having them unmoving is fine.
#5863 10 months ago
Ahh but they have clockwise and counter clockwise... guess it don't matter as long as they spin.
#5864 10 months ago
Quoted from Marvin:
There is a setting to disable them, it's under game settings and it's called "Drones physically active" Just set it to NO.
#5865 10 months ago
Just an FYI on the drones just got a note from JJP stating the following: "We are currently experiencing a high volume of drone motors failing, we are currently working on trying to solve this problem, that being said, these drones being sent may or may not later down the line, fail again unfortunately."
#5866 10 months ago
Not sure if it was posted before.
When you do replace the Drones, JJP needs you to now send back the bad drone. Steve mentioned it could be the boards in the drone and they are looking at (and maybe refurbishing?) those that are sent back
#5867 10 months ago
Quoted from KellerDj:
I wonder if the phone LCDs are having issues, too? I've gone through two of them. Seems odd to me that this would be such a troublesome part.
#5868 10 months ago
They are refurbishing the drones that get sent back
#5869 10 months ago
I would like to repeat my question:
Is there a known way to reset highscores (at least manually delete the daily highscores) without loosing the Grand Champion?
#5870 10 months ago
I have trouble with my phone but more trouble with the theater screen. It seems to go on and off all the time. That made me think a loose cable but I have reseated everything multiple times and my local tech looked it over and said it looked good as well. Wondering if I need a new video card and cables
#5871 10 months ago
Quoted from Pale_Purple:
I'd try cables first, assuming your video card is in tight, and only the phone is hooked to it, theater hooks directly to motherboard.
#5872 10 months ago
Quoted from Nokoro:
I just replaced all three of my drones; I figured it was worth doing once in hopes that the newer ones might last a while. The top one is easy to replace - I might do that one again - but the bottom two are enough of a pain that I probably wouldn't bother replacing them a second time.
#5873 10 months ago
My theater goes off all the time,I thought that was normal. So it's supposed to show a video ,at all times?
I did replace the video card, and I'm still having issues with my phone.
#5874 10 months ago
I don’t know if it’s supposed to have video all the time. Mine will dim the brightness and go out all the way often. Hit a ramp and it should play the subway/train animation is a good way to tell if your theater is displaying video correctly. My phone screen goes out from time to time but the LEDs around it usually work. This happen much less often, the theater issues have been almost every game. Of course it seemed to work for the 30min it was on with my tech.
#5875 10 months ago
The theatre goes off by design. It only plays animations at certain times.
#5876 10 months ago
Quoted from crwjumper:
Thank you.I think I'm going to just call JJP,and see if I can get this phone issue resolved.
Something I saw for the first time yesterday. I was still in a mode,and Mike Banter/? announced, things we're back to nearly normal,but I still had a lot of time left in the mode.
#5877 10 months ago
Can people who have recieved manuals tell me when they bought the game.. I was one of the first UK back in Oct/Nov 17 and not heard yet of manuals being sent out
#5878 10 months ago
Code Update????
#5879 10 months ago
Quoted from Pinhead1982:
If you haven't yet, you need to enter a support form on the JJP website and for case type select DI manual.
#5880 10 months ago
Mine was one of the first ones and I had to contact my distributer. My manual has a pretty severe printing flaw. They offered to replace if I payed half shipping, which turned out to be hella expensive. Going to keep the flawed one. Still works I suppose.
#5881 10 months ago
Thanks all for the responses about the drones. It sounds like it may not be worth replacing as the new ones will likely fail at some point. I think it is a cool toy, but I also don't really notice them going off during game play. I may call Frank at JJP just to hear his thoughts. I'm also wondering whether I should put in a ticket just so they have a record of when my failed in case they come up with a more permanent fix. However, even if they get more robust drones, I just don't see these as parts that will last for a lengthy amount of time.
#5882 10 months ago
Quoted from Nokoro:
As per Frank, JJP is currently working on a more permanent fix. I’m on my third set of drones now. My recommendation is to contact Frank and have current replacements sent to you for the time being.
#5883 10 months ago
My game was built in April 18. So far 2 drones (bottom & middle) have gone out. Replacements are on the way to me.
#5884 10 months ago
Quoted from check_switch_26:
I don't have a firm release date yet. I'm aiming to have new code posted early next week. I'm still waiting on a few items.
--Ted
Hi Ted,
do you have any updates on the release plan?
Thanks,
Lars
#5885 10 months ago
Quoted from MEuRaH:
Have had my machine for almost a year now, have had no issues with the drones. Disappointing, but glad they are going to fix. It's still a functioning toy that should always work. Especially for an $9000.00 machine.
#5886 10 months ago
I have a very early LE and the drones have never been a problem.
#5887 10 months ago
Just got my dialed in and the shooter rod hits the auto launcher what should I be adjusting to fix this?
#5888 10 months ago
I had drones failing almost every week since I bought the machine in March 2018. The first few I was replacing with new drones, but at some point I startet to just exchange the motors by myself, as it was too much effort to order replacement drones and also replacing a drone is more effort than replacing a motor...
Nevertheless: I replaced more then 25 motors in this timeframe...
Questions are:
- is this just a problem of the motors itself? did I just get a bad charge?
- is this a problem of the drones circuits?
- is this a problem of the power driver board?
I think the small motors are not made for the lot of on/off sequences with full power and just wear off. But it seems odd that some do not have a single motor failing during thousands of games while others have broken motors almost every 50 games or so.
During the last few weeks I had only one motor failing, so maybe it is really just motor related. Nevertheless I think a smaller voltage for the motors means less hard usage during off/on cycle as well as less speed and therefore less wearing. As the drones are powered by unrated 12V (in my case slightly above 14 Volt) this might be the difference.
Could someone who's drones are not breaking at all measure the peak voltage during drone test, please?
To check this, I added a resistor in one of my drones motor circuit (I know this is not the best way, as the voltage drop is changing due to different resistiance of the motors, maybe a Z-Diode would make more sense here - but for a first check this should do the trick...). Up to now the drone did not fail anymore, but neither did the others without the resistor...
#5889 10 months ago
Quoted from koops:
I would have to guess and say either the shooter rod or the auto launcher is the culprit.
#5890 10 months ago
Questions are:
looks like you tried a resistor
#5891 10 months ago
Quoted from koops:
You should try to adjust the shooter rod. Open the screws and set it to a good position in the cabinet and tighten the screws again. Be careful not to damage the decals.
If this is not enough, you can also bend the auto launcher a bit.
#5892 10 months ago
Quoted from msj2222:
maybe try adding a resistor inline to see if reduced voltage saves they motor
This is what I did in one of the drones (see last paragraph)...
#5893 10 months ago
Quoted from DeathHimself:
I understand they can be turned off. you missed my point, They are not functional to the game, there was no reason for them to put in a part that was going to be this unreliable. These drones are known to be cheap and break easily. They could have simply mounted them for looks with no power which is how they all will be eventually anyway. If would be different if they pushed the ball around with the thrust.
#5894 10 months ago
Bingo! That was it thanks!
I’ll have to do my hobbit like that also as it occasionally touches.
#5895 10 months ago
does anyone know from what production date DialedIn LE has all the updates from factory ?
#5896 10 months ago
Quoted from Marvin:
I understood your point and agree 100% just pointing out for some who may not know and who currently don't have a drone issue, and like you said they are not required to spin for game play that they can be disabled and still have a 100% working machine when they choose to enable them or when there might be a fix down the road. It seems the voltage might be a bit too high for the motors hence the short life performance but waiting to see what JJP R&D comes up with. Until then I have mine off.
#5897 10 months ago
Quoted from KLR2014:
I got mine in January of this year and they still hadnt done some updates like the real cliffys. If I had to guess I would say May or later.
#5898 10 months ago
Quoted from estrader:
I think if you contact Frank they’ll sent you Cliffys
#5899 10 months ago
Quoted from romulusx:
Just fill out a form on the JJP website. I have the Mantis scoop protector installed, and I'm not sure if I want to install the Sim card hole cliffy...it's hard enough to hit without one!
#5900 10 months ago
Quoted from Marvin:
Personally I like the toys that function, anyone can bolt happy meal toys in a machine. I get that its a little frustrating that they tend to burn out but I am confident that JJP will come up with a simple fix(inline resistor) that will make them reliable. So just turn them off til then
$ 399.95
$ 239.00
Tilttopper
6,800 (OBO)
Woodstock, GA
$ 189.00
