I hope the new code makes it easier to progress in this game. As it is now it is way too hard...
Quoted from FatPanda:Tweaked the magnet settings for the new balls. I set the value to -102 and the magnet toss works perfectly now. It needed a little more oomph to get the non-magnetized ball back around the orbit. All is good! Plus, it mitigates SDTM drains from the Theater and is a good way to feed the upper flipper at times. Please dont remove it Ted!
Oh, things are way past the point of being able to remove that functionality.
--Ted
Quoted from check_switch_26:Oh, things are way past the point of being able to remove that functionality.
--Ted
I like the sound of that Can't wait to see the stream and play with the new updates!
I love the magnet when the throw back works right. I put new balls in it last week, I might need to take it off of "experiment lab" or whatever and try it again since people are getting different results from different sets of balls.
I love the theater magnet too. My only slightly quibble is that it would be great to get the theater modes to behave more like the physical devices they are replicating. For example, don't have the bash toy catch the ball for so long. Same with the drop targets. Again, just a slight quibble . . .
Quoted from Nokoro:I love the theater magnet too. My only slightly quibble is that it would be great to get the theater modes to behave more like the physical devices they are replicating. For example, don't have the bash toy catch the ball for so long. Same with the drop targets. Again, just a slight quibble . . .
The "hold" time is there to increase the chance of the ball bouncing off the back of QED and avoid a drain. It has been further refined in the next release. (Life is full of compromises.)
--Ted
Quoted from LTG:You can try turning the connector 180 degrees and plug back on. Be sure it is plugged into the board in the backbox too.
Is the connector that your saying to rotate,180 degrees,the connector right above the "Volume control
Is the headphone jack that has to be rotated 180 Deg. directly above the "Volume control Switch"? I'd just like to make sure,before I make this adjustment. It wouldn't hurt my feeling if you point to it with an arrow,
Quoted from ralphs007:the connector right above the "Volume control
Quoted from ralphs007:"Volume control Switch"?
Yes.
Page D-109 in the manual, J101 is the only one of the two that you can turn around.
Quoted from LTG:Yes.
Thank you. Now my headphones are working like they should.
What about ball parking in the groove of the Moving Target Sculpture till the system starts the search for balls?
How often does it happen in your DI?
Quoted from waynetrane:What about ball parking in the groove of the Moving Target Sculpture till the system starts the search for balls?
Every once in a while. Not too often. If it happens too often for you, perhaps check the pitch of your game.
Quoted from Nokoro:Every once in a while. Not too often. If it happens too often for you, perhaps check the pitch of your game.
Yes - ^^^ what he said ^^^
Mine was getting stuck maybe every 10th game. My pitch was at about 6.7 degrees. I dropped it to about 6.3 degrees when I rearranged my pins and it only got stuck there once in about a hundred games or so. For mine, lowering the pitch helped that out - which seems backwards, but it worked. Adjust it a bit in one direction, and if that doesn't help, adjust it the other way a bit.
Long time fan and just picked up this beautiful LE yesterday! This is one fast silky smooth game. We’re still figuring things out but that’s half the fun, plus I stink - 937,000 is my best so far on stock medium settings. Tonight I’m gonna look for the best deal on mirror blades, and maybe some better flipper rubber. Everything seems to work perfectly, although the upper flipper shot seems inconsistent, or just has to be perfect to make it up to the subway - again I stink!
Can’t wait to see the new code!
Quoted from Hogbog:Friday 10/12/18 at 3pm central: Live stream of POTC from the guys who made it.
Come check us out!
https://www.twitch.tv/jjplive
Be sure to subscribe to receive notifications in case we play unannounced again....
Oh, and a bonus stream Monday 10/15/18 @ 3pm of NEW CODE....FOR DIALED IN!!!!!!!!!! Hold onto your butts!
E
New code stream day!! Sadly, I will miss the live stream...stupid work!
Is there a collected 'common issues with DI and fixes' thing like somebody did for ... some other game that is escaping me at the moment?
I have the theater guide with the harsh edge I'd like to fix, but I'm not sure about the best way to cleanly re-shape it. I kind of want to adjust my lock ramp to come down farther left than the dangerous point it does now, but with how the ramp edge goes over the nut it's not just a simple move and tighten down affair -- has anybody done an adjustment there? Bent the ramp? something else?
I think I finally have my trap door working well. I tried all the basic advice I'd seen from others, but was still having issues. In the end, the screw on the bottom of the drop coil on mine was loose so the coil would rotate and the catch/release would get screwed up.
Quoted from epthegeek:Is there a collected 'common issues with DI and fixes' thing like somebody did for ... some other game that is escaping me at the moment?
Quoted from brucipher:New code stream day!! Sadly, I will miss the live stream...stupid work!
Can't believe we have to wait until THURSDAY to check out new code... sigh.. guess I'll have to play my Hobbit, which just got ANOTHER awesome update! JJP is on fire!
Who is streaming the new code, where, what time? I guess it sounds like it won't be released to the rest of us until this Thursday?
Quoted from pindude80:Who is streaming the new code, where, what time? I guess it sounds like it won't be released to the rest of us until this Thursday?
Chicago JJP today 3pm CDT - https://www.twitch.tv/jjplive
They will be testing at Pinball Expo later this week. If all goes well, released sometime after that.
Quoted from LTG:Chicago JJP today 3pm CDT - https://www.twitch.tv/jjplive
Hopefully MINUTES after that!
Just received my DI manual and wow, very impressive.
It’s massive and extremely well laid out.
This manual is in a whole different league from any other I’ve seen.
Quoted from estrader:Anyone watch the twitch stream and care to share new info about the code updates?
I watched the last 30 minutes.
Jackpots were slightly increased on multiball modes, and seemed to increase incrementally with time and/or succession of jackpots. I watched super jackpots go for 25k to 50k regularly.
Selfie mode was 1k per selfie. You can get 100k if activated in a multiball mode.
No change in the lottery mode.
I think the sounds were different on the pop bumpers (massive difference) and maybe some other standups.
Theater multiball! Not sure how it was activated, but it was fun to watch.
The biggest change that I could see was the change in point values for specific things in the game. I watched one of the two guys get 700k and he didn't complete a single mode. He also tilted out of a bonus that would have been worth 250k, which is insanely high, so I think bonus values increased too.
I liked it. Everything was evened out a little bit. Multiball modes were worth doing, thank god.
Quoted from Rdoyle1978:Check it out yourself!
https://www.twitch.tv/videos/323121671
Lots of cool stuff from what I'm hearing and seeing so far. Theater mulitiball sounds very cool, looking forward to playing it. Also, the changes to scoring with the Bob modes is a nice modification and will help make them more valuable (as well as make it easier to obtain SIM cards from them). The additional animations for the phone will really help give the game a complete feeling.
Wow the new code really adds another level to strategy.... the new multiball sounds awesome and will b icing on the cake of a allready awesome game and code. Plus the new values for everything else including bob modes and mb and the animations and lighting are just bonuses.
I watched for a while and have an question on my observation at least. The theater shot seemed only to catch and release now with no toss backwards, did anyone else notice that or was it still as before but I missed it?
Quoted from DeathHimself:I watched for a while and have an question on my observation at least. The theater shot seemed only to catch and release now with no toss backwards, did anyone else notice that or was it still as before but I missed it?
They may have the toss turned off or not adjusted correctly after the code update?
Quoted from ThePinballCo-op:I watched the last 30 minutes.
I'll have to watch a little closer - some of those changes seem pretty subtle - maybe I wasn't paying close enough attention? The stacking of MBs seems like a huge update
Quantum Theatre MB looks really cool. I couldn’t quite follow all the rules. It sounds like you have to activate every theater mode and then hit the theater in that mode a couple of times. I think this will be hard for me, but I have never played the game just focusing on the theater modes, so maybe it is more doable than I think. Either way, it is nice to have another option for how to play other than just advancing through the disaster modes. All in all, looks like a pretty great code update.
I have yet to see it. Will check out soon. Wonder if the first mb is still a give me or if you can turn that off/make it harder.
I guess with the scoring rebalance it's it doesn't change it will stay be worth playing
Quoted from delt31:I have yet to see it. Will check out soon. Wonder if the first mb is still a give me or if you can turn that off/make it harder.
Watch the first 5-10min of the twitch stream and most is explained... its looks like a great update especially making the skill shots and new mb a new wzy to blow up the game. Also the regular mb is more valuable depending on sim cards and where the atrack is .... so many new details. Gonna make a great game ...amazing
Quoted from imagamejunky:New code looks great!
Anyone know when it will be available for us? (Besides after expo)
Junky
Right after Expo,if update is bug free
So it looks like the phone animations are still not complete. I do appreciate the rest of the work done on the code but if the phone character animations are still not done it makes the game feel incomplete.
Quoted from Spankey:So it looks like the phone animations are still not complete. I do appreciate the rest of the work done on the code but if the phone character animations are still not done it makes the game feel incomplete.
If you watch the Twitch video you'll see were Eric and the crew do say numerous times that the
remaining animations are being rendered and will be included in update!
Quoted from romulusx:If you watch the Twitch video you'll see were Eric and the crew do say numerous times that the
Might have missed that during the beginning stuttering. Saw the animations still not working later in the video.
Quoted from Spankey:Might have missed that during the beginning stuttering. Saw the animations still not working later in the video.
The game they were playing on wasn't fully loaded with the new animations yet due to them still processing/rendering elsewhere.
Anyone here have a standard version? It's already hard to justify 8k.... that extra grand doesnt seem worth it. Your thoughts?
Edit: Nevermind. I searched the thread and got my answer lol
Quoted from Doctor6:Anyone here have a standard version? It's already hard to justify 8k.... that extra grand doesnt seem worth it. Your thoughts?
IIRC, you get the PC armor, Shaker, Volume/Headphone jack, and Invisiglass for the extra 1K. I think it's worth it. On the secondary market, there are plenty of DILE's going for 8-8500 right now, if that's an option for you.
Quoted from FatPanda:IIRC, you get the PC armor, Shaker, Volume/Headphone jack, and Invisiglass for the extra 1K. I think it's worth it. On the secondary market, there are plenty of DILE's going for 8-8500 right now, if that's an option for you.
And the ramp LEDs for the 2 ramps in the upper left, and the lit back panel.
Shaker is on all versions.
The new code will add much more incentive to take the skill shot for Theater Holds (spider, kilowatt, drones, subway), and give purpose for shooting for those during regular gameplay to get QT multiball (You need two shots from each QT mode to qualify it). I always ignored those and the left side hurry up because I felt they weren't worth enough. Also really didn't care for UA MB that much since it wasn't worth much, so really glad to see that values are being bumped for UAMB and that the Theater modes are actually worth going for now. Can't wait to play the finished code when it becomes available.
Also got my manual yesterday too. I told my wife what was in the box, and she was like, 'are you serious?' lol
I'm not sure if I should display it or leave it in the box?
Quoted from Doctor6:Shaker is on all versions.
Ok, wasn't sure as I bought mine on the secondary market.
Quoted from FatPanda:Ok, wasn't sure as I bought mine on the secondary market.
I think the upgrade on DI to LE is a no brainer.My wife and I took all of 5 minutes on that decision,it takes us 10 minutes to decide where to eat!
Quoted from romulusx:I think the upgrade on DI to LE is a no brainer.My wife and I took all of 5 minutes on that decision,it takes us 10 minutes to decide where to eat!
It's nice to have the option for the Standard. I don't care about the extras other than maybe the ramp lights. I picked up my Standard for $6400. Hell of a deal. LE extras weren't worth it for me, even at second hand prices.
Depends on the person. I play in low-light, I don't need the invisiglass. I crank the volume, I don't want headphones. Both have the shaker. The coating is nice, and the extra lighting on the ramp is awesome, but I didn't wanna pay the extra 1k on it so I got the SE and used the money I saved to buy the pinstadium lighting instead. IMO, SE & Pinstadium & ~$700 > LE.
Again, depends on the person. If you have a well-lit & good-looking arcade room and you wanna keep it looking that way, the $1k is totally worth it.
This page was printed from https://pinside.com/pinball/forum/topic/dialed-in-owners-and-fans-club/page/112 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
