(Topic ID: 177016)
Dialed In Owners and Fans Club
By goren1818
2 years ago
  • 9,055 posts
  • 494 Pinsiders participating
  • Latest reply 15 hours ago by Mageek
  • Topic is favorited by 165 Pinsiders
There have been 1,088 images uploaded to this topic. (View topic image gallery).
22 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 9055 posts in this topic. You are on page 101 of 182.
#5001 1 year ago
Major problem. Thought I'd post here before contacting JJP. A few days ago, I noticed that when the pin was turned on (not being played), the machine would shut down on its own (yes with the power switch on). Figured maybe a short somewhere. Lifted the playfield looking for any disconnected wires, but found nothing. Waited a couple of minutes powered it back on, and all seemed well. Played a game, no issues. Walked away and noticed about 5 minutes later, same thing, pin had no lights, nothing on the display etc etc. Turned the switch off. Tried turning it back on. When I turn it on, the light in the backbox flashes on for a second, then nothing. I'm thinking maybe a blown motherboard??
#5002 1 year ago
My DI LE came with two silver drones and one black drone instead of having a white drone in the mix. Anyone else have that? Wondering if it was a factory error. Not too concerned. Maybe it raises the value of my pin, like that stamp with the upside down airplane on it.
#5003 1 year ago
Quoted from Nokoro:
I had two drones go bad (two silver ones). Was told by JPP the drones are randomly chosen when the game is built, and he couldn't specify which color drones I would get for replacement.
#5004 1 year ago
Quoted from Nokoro:
Maybe a bad white one was caught in testing and the tossed what they had available in there...
#5005 1 year ago
Quoted from delt31:
Guys just a reminder that if you have a newer DI make sure you change the color settings on the display. When I originally had my DI last year JJP replaced the display due to a dead pixel. I noticed that the screen out of the box didn't have the same pop as my original.... Reds especially. Fast forward and I'm back with a Feb build and same thing with the screen.
I went into the screen settings and bumped the contrast from default 50 to much higher and changed the color settings too and now it's much more vibrant. I'm an oled guy so I like a saturated picture!
I'm looking forward to the code update. I said it when I owned this last year and I still say the same thing now..... Smoothest shooter out there. Each owner should be given a stick of butter when you buy this game. Unbelievable.
Where are the screen settings to adjust the monitor?
#5006 1 year ago
Quoted from Ilushka85:
Just got my DI CE!
Damn, you have quite the collection.
Did you buy the DI CE #21? Or NIB?
#5007 1 year ago
Quoted from kharri:
Not sure where the phone settings are? There are two PCBs inside the phone. One is the controller for the LCD and the VGA cable connects to it.
The other PCB is for the LEDs surrounding the phone. The Ethernet cable connects to it along with a power connector.
You know what, I am sorry - I am getting confused with Houdini. It also has a small LCD on the playfield, but includes a ribbon cable-connected set of buttons which can adjust it- that’s what I was referring to
#5008 1 year ago
Quoted from MEuRaH:
Bought the 21 with everything that was on it already it wasn’t a horrible deal compared to nib le and looks a hell of a lot better with the rad decals and the ce trim.
#5009 1 year ago
Quoted from Rdoyle1978:
I hear the early versions shipped with a board to adjust the phone lcd
#5010 1 year ago
Quoted from kharri:
That’s kind of cool. Means each game is a bit different. I just noticed that one of my silver drones has a gold swirl on it and the other has a white swirl. So even the same color drones can be different from each other.
#5011 1 year ago
I have noticed from other pictures that the drone colors are random...mostly I see 2 silver with a black or white. Mine came with one of each. I have had 2 go bad and they have been kind enough to send a replacement to match.
#5012 1 year ago
Quoted from Nokoro:
And if you want to be different, go buy a couple from Amazon and replace them.
#5013 1 year ago
Twice today, I’ve had the ball get wedged behind the trap door and under the playfield. I’ve owned the machine for a while and have never had the issue. I’m wondering if some kind of piece came off that stops the ball from going too far back where it doesn’t drop in the subway.
Anyone else had this problem?
#5014 1 year ago
Quoted from kharri:
Settings are on the monitor - you need to pull the monitor out and then adjust from there (just like you would on a stock TV).
#5015 1 year ago
Quoted from foobeer:
Nothing missing. Usually the ball drops into the bottom of the cabinet.
My cure : Holding the playfield up with my right hand, I gave the bracket holding the big coil a tug towards the front of the game. End of problem.
#5016 1 year ago
Quoted from JayLar:
Got the Cliffy protectors for the inlanes. Anyone else have problem with the ball getting stuck? I've tried bending down the metal spring which helped but still have balls getting stuck from time to time.
Mine came last week,but I haven't put them on yet.Did feathering the front edge of the protector work for you?
#5017 1 year ago
Quoted from ralphs007:
Haven't tried that yet. A bit hesitant removing them. Tried putting tape over the edge but didn't help.
#5018 1 year ago
Quoted from JayLar:
On mine there were a few times the ball was stuck on the left lane. It wasn’t the Cliffy causing the issue though. The rubber ring around the slingshot was fat enough to hold the ball. I stretched the ring and this seemed to have made it slightly smaller which no longer held the ball. Thought you might want to try this.
Junky
#5019 1 year ago
Quoted from imagamejunky:
Junky
OK, I´ll have a look at that thanks.
#5020 1 year ago
Anyone tried the plastic protectors from Mezelmods?
https://mezelmods.com/collections/dialed-in-pinball-mods/products/dialed-in-pinball-plastic-protectors?variant=46378502472
Are they worth getting? What´s the difference aesthetically?
#5021 1 year ago
Quoted from JayLar:
I have them. I went with the Blue/Red kit. Blue on slingshots and red on lane guides. They add a little bit of color to the bottom of the playfield but they don't stand out much. If you are specifically looking at them you will see the difference they make, but if you aren't looking for it you probably won't notice they are there.
#5022 1 year ago
Junky
I had the same problem.Stretching the rubber ring only works for a game or two,and then the rubber returns to its original position.I ended up filing the inlane post,and now it's working like it should. After I filed it,I polished it with Mothers Mag/aluminum polish.
#5023 1 year ago
A few questions:
1) How do you stop MB from occurring after two balls only? Is there anyway to change the default setting so you don't need to manually press the two flippers right away?
2) What is the best way to get the SIM card - best shot?
3) Is the "subway" shot the jackpot ramp that you hit top right flipper to left ramp?
4) What does overcharge do?
5) Best way to get the phone scoop to shoot just a little more to the left?
#5024 1 year ago
Quoted from delt31:
A few questions:
1) flipper cancel RIGHT away. I do not believe you can disable it
2) bank off of standups but really there’s no guarantee
3) subways are 2 Ramps and theatre
4) more points in activated mode
5) move the scoop I would think, or adjust coil power
#5025 1 year ago
Quoted from delt31:
I've had a LOT of success 2 ways:
1) Go to the theater to feed the upper flipper, and hit it when it's about halfway down the flipper.
2) Start a multiball and go nuts in the center of the playfield. One will fall in eventually.
I owned a Jurassic Park for 2 years and did nothing but play that game religiously, and really crushed those upper flipper shots. I became good enough to feed the T-Rex & hit the Orbit, but that took a TON of daily practice. I can get the sim card on command quite easily because of that game. I rarely play a game where I don't collect the sim card, so keep at it. It's do-able.
#5026 1 year ago
Finally received my topper from Mezel Mods.
#5027 1 year ago
Quoted from knobstone:
[quoted image][quoted image]
I think it’s way better than the factory one but I think too much yellow and orange for a blue game.
#5028 1 year ago
I understand they are winding production on DI to the last ones now. I had a deposit for one of the last run DILE machines, but cancelled out. $9200 versus buying another open box DILE for $8k. Not sure if I will kick myself later...they seem to be dropping bit by bit in value over time.
#5029 1 year ago
Nice!
#5030 1 year ago
Does it light up?
#5031 1 year ago
Quoted from bondavi:
They’ll be making Dialed In for years, just switching over to POTC for a while to get all the preorders out.
#5032 1 year ago
Quoted from WackyBrakke:
Wldnt say all those preorders... dont believe it sold a whole lot especially after the spinning disk gate.....
#5033 1 year ago
Yep … when I was there a couple of weeks ago, DI was just recently switched to their smaller assembly line and will probably be making 5 per day on that line per Jack. Jack also said that they would be winding down TH with another run this fall. They plan to startup WOZ again later towards winter too. My guess is that TH will end first. DI has no license, so they can keep making them for a very long time as long as they keep selling. When I was there, they were loading up shipping containers to ship DI's across the pond.
#5034 1 year ago
Quoted from KingBW:
I hope they do so parts are always on hand if need be for this awesome game.
#5035 1 year ago
Dialed In is my favorite game! They have a real winner there
#5036 1 year ago
Quoted from kharri:
Does it light up?
Yes, it has a led strip in the box that holds the acrylic glass in the topper. I'll try to post a pic later today with the light on.
#5037 1 year ago
Quoted from KingBW:
Initially was disappointed with the slow pace of JJP but now realize some things like life are a marathon not a sprint, was glad to get my Woz built in 2017 many years on and hope Woz will continue to sell to new owners. Woz probably benefited by the delay of TH and DI got a boost in sales greatly by a delay in JJP PotC.
#5038 1 year ago
Quoted from rai:
To build on this comment, I owned a WOZ a few years ago - I think it was my 2nd or 3rd machine(!). I could not appreciate it then so I sold it.. recently played a RR on location with updated code. WOW. My updated code allowed me to appreciate it a bit more . WOZ has been out what, 3, 4 years?
#5039 1 year ago
5 years, and they are still in production. I actually considered getting a new WoZ over a DI when I bought one a month ago. It's just an incredible machine, and by now all the small flaws and kinks have been worked out.
#5040 1 year ago
Only to derail the thread for this post, I asked Jack if he did his dream theme yet and he pointed to the prototype WOZ pin in his office. That pin has pre release code on it that can't be updated (because of the prototype hardware), yet it is a treasure to him. He has lots of WOZ stuff throughout the office. The vibe that I got is that they will still be producing them for a few more years if sales continue. The "reboot" to get WOZ back on the line late this year will have some updated CPU boards like DI (see, there's a DI reference here). He said that they secured their next 3 titles/licenses - but we heard that recently from other people too.
Now, back to DI ... Hopefully updated code is coming soon. ???
#5041 1 year ago
Quoted from KingBW:
Awesome post. I love hearing that WoZ is sticking around for a few more years minimum and that they are already looking ahead at their next 3 titles!? Nice.
I am salivating for a code release for DI.
#5042 1 year ago
L@@K and admire its functionality and versatility! It can function as a mere glass holding a blood orange margarita or it can hold a beer within a pin-gulp caddy during intense game play or even function as a topper!
01136F7D-D027-43FC-A62E-ABACB3336062 (resized).jpegCF576706-696E-4A01-AFCB-C7E162FB53FC (resized).jpegDB146246-CC67-4C2C-B816-80369845047E (resized).jpeg
#5043 1 year ago
I may be looking at a Dialed In LE this weekend. Does someone mind sparing me reading the 100+ pages of the club and summarizing potential issues and what to look for? Thanks in advance!
#5044 1 year ago
Quoted from BigStiffy:
The trap door under the left ramp is the most common issue. Expect to have to adjust that at some point, it sticks open frequently. Fixing it is incredible simple though.
The other thing I can think of is to cut the Mylar away from the magnets as they protrude from the play field. Remove the magnet from underneath, then just take an X-acto knife and cut away the Mylar from the open hole (from below)
Also the little sign with the CRAZY BOB’s status is rotated weirdly on the game, so you can’t read it. It’s annoying but fixable; however is like that so it doesn’t cause a ball trap. Your call whether or not to address it
Others have mentioned messing with the screen colours and temperature, contrast, etc. I would recommend not doing that unless you are super familiar with how to dial in those settings - it can quickly make the LCD look worse if you don’t take the (long sometimes) time to get it perfect
#5045 1 year ago
Drones going bad. Phone issues. Trap door (mentioned before). Most minor issues
#5046 1 year ago
#5047 1 year ago
If you are using those glasses as a topper, you must not be a "nudger" ... unless you glue them down pretty good.
#5048 1 year ago
Video would be very appreciated! How do you like it?
#5049 1 year ago
Take a look at the key posts at the front of this thread. That lists most of the issues that may need attention.
#5050 1 year ago
Quoted from MEuRaH:
Fixed em all. The hardest one to fix was the error of balls locking in the train station and not unlocking properly during multiballs. If you're having this error, take off the train station lid and push the plunger all the way in. Does it stay pushed in? I know the fix. You need to adjust the lock screw, a tiny black hex screw where the plunger meets a horizontal stationary bar. Push the plunger all the way in to expose the screw. Loosen it, wiggle the plunger to adjust where it should be on the horizontal bar, tighten it back up and check. You should be good to go now.
Thanks to ltg with the rest of the stuff. That was awesome. You're the best, Lloyd.
What did you do to fix the left ramp from not registering? Was the metal switch your problem or something else?
Trade
Machine - For Trade
Fort Lee, NEW JERSEY
$ 239.00
Tilttopper
$ 76.95
Gweem's Mods
