Anyone experience a heavy amount of audio noise? Seems like interference from something, has a pretty noticeable static noise. Any suggestions in what to look at? doesn't seem to be localized to any one speaker.
Do you have the ground loop isolator on it (should be somewhere by the computer box)? Not sure if they're shipping with them from the factory, but it has been an ongoing JJP problem that a ground loop isolator fixes.
Quoted from pinstyle:I do not believe it has one. I think I know what your talking about, I might have an extra one from my WOZ that was used for the sub that I never had connected. Is it basically a small box that just goes inline with the audio cable?
On WoZ it went on the 3.5mm headphone jack connector. I don't remember how the audio is set up on Dialed In, so not sure if it's like that or using RCA jacks.
Yes - unplug male cable from pink jack on sound card, plug that cable into female port on isolator, plug male cable from isolator into pink jack.
Quoted from pinstyle:That did it, thank you all. This game is nuts by the way.
Can you please post a picture of it? I’m having same problem, just got no idea what I’m looking for, or what I’ll need to get to fix it. Thanks!
Mpow Ground Loop Noise Isolator for Car Audio/Home Stereo System with 3.5mm Audio Cable (Black) https://www.amazon.com/dp/B019393MV2/ref=cm_sw_r_cp_tai_.vtCCb5XBA2R4
Is this something that will work?
Quoted from Lermods:Mpow Ground Loop Noise Isolator for Car Audio/Home Stereo System with 3.5mm Audio Cable (Black) amazon.com link »
Yeah this is exactly what you need. It drives me nuts that this is a known problem on DI yet JJP is too cheap to just include it from the factory.
Jjp ships you one when you log a ticket.
Unfortunately theirs isnt best quality and didnt work well on my machine.
Bought a cheap one on aliexpress and that works better (although also not perfect).
This is the one you need. Well worth the $9.
https://www.amazon.com/Mpow-Ground-Isolator-Stereo-System/dp/B019393MV2
This page was printed from https://pinside.com/pinball/forum/topic/dialed-in-le-auido-noise and we tried optimising it for printing. Some page elements may have been deliberately hidden.
