Okay, so i checked all the props and found none of them to be clearly binding. That being said, i was unwilling to pull the props, because i swear i was going to break the drone.
The behavior of the drone is as follows during the test.
None of the drones will spin until i manually start a prop. First one was with my finger, and i warn anyone, they may be little, but they sting just a bit...hah... it appeared that as long as i spun the prop the drone would pulse a few times. It was a pulse of two or three then it would stop until manual intervention.
The good news is that my machine is under warranty.
The bad news is that the likelyhood of all three being bad is low, and that there is some other problem.
Any other thoughts are appreciated. For now ill use the warranty process before i take apart one of the drones and apply some direct current.
