(Topic ID: 27901)
Detect running game?
By magsimoe
11 years ago
#1 11 years ago
Is there a way to detect whenever a game is running? A signal that is high or low only from when you hit start all the way until it's game over.
The pinball in question is a Viper Night Drivin.
Trying to have my arduino detect if someone is playing.
Thanks,
Magnus
#2 11 years ago
Could you hook it up to monitor flipper button activity?
#3 11 years ago
Thing is, I'm gonna hook this game up to an arduino and a webcam. Enabling us all at the office to play from our computers over the intranet. But I need to know when a game is being played so I can prevent others from interfering. And also make some kind of queue system so that when the current players game is over, he cant play again and the next in queue is allowed to play.
All the buttons are wired up and everything works perfectly except everyone can control the game at any time.
#4 11 years ago
Quoted from magsimoe:
that is ambitious.. reminds me of this but the next level..
#5 11 years ago
PING 192.168.1.73 (192.168.1.73) 56(84) bytes of data.
64 bytes from 192.168.1.73: icmp_seq=1 ttl=128 time=8.30 ms
64 bytes from 192.168.1.73: icmp_seq=2 ttl=128 time=7.08 ms
64 bytes from 192.168.1.73: icmp_seq=3 ttl=128 time=1.00 ms
64 bytes from 192.168.1.73: icmp_seq=4 ttl=128 time=5.26 ms
...and these two are sitting on the same desk. If you think Farscape flippers are laggy, running webcam video over even a local network would have to be maddening.
#6 11 years ago
The only way to do this is to have a closed-circuit video and serial control system that does not utilize a LAN.
#7 11 years ago
Can you wire it to detect if it is in attract mode or not?
#8 11 years ago
Do it to the power of the coils.
The pop bumpers or flippers will not have high power if the game is not running. Tap a relay off it and you have a low voltage signal.
#9 11 years ago
Off the top of my head I'd say to key off a switch in the ball trough. If there are multiple balls in the trough, key off of the last switch.
That wont solve the problem of stealing the game in the middle when you drain the ball, but it will stop mid-game stealing.
#10 11 years ago
Why not tie into the start button. Make it discrete 1 or 0. At the same time have a second line keep count of how many times the drain hole switch is activated.
If startBtn = 1
No go
If drainHole switch == 3 (or 5)
startBtn = 0
#11 11 years ago
Quoted from dlbuller:
If startBtn = 1
No go
startBtn = 0
Several problems with that. What if the start button is pressed more than once in a game? What about ball saves/ball searches? What about multiplayer and entering initials? The best way to really see if a game is running is to tie in to the logic that enables the flippers. On pre-fliptronics games you can monitor the state of the flipper relay. On fliptronics you can intercept communications between the CPU board and fliptronics board (this will of course require a little reverse engineering).
#12 11 years ago
So what if its pressed more than once. Does nothing. But yeah forgot about ball saves/searches. I guess I didn't know how deep he was going into it. Was trying to make it quick and dirty. I suppose you could tie it to any active switch and force a waiting time. If no switches are activated, then the person could play. Wouldn't solve multiplayer or be the best solution.
#13 11 years ago
I suppose also you could define in your web app or however you are interfacing over the Internet the number of players and force a login. If somebody is logged in, nobody else can play depending on player number.
#14 11 years ago
You could attach a magnetic probe to a coil.
#15 11 years ago
Quoted from castlesteve:
Good idea, this should work.
#16 11 years ago
You could sense the 'game over" or "insert coin" bulb too on many games.
#17 11 years ago
I think the easiest missed...use the coin return lock solenoid. Wire a relay in parallel. Done. Assuming of course there is one on this game.
#18 11 years ago
castlesteve and vid1900 and best is robertmee as its simple as pie (great ideas here)
#19 11 years ago
Thanks guys, for all the ideas.
I will try them out and see what works. The ideal thing would be to find a TTL signal on the cpu board that doesn't need to be converted in any way, but I've been looking through the schematics for several hours without any luck. My electronic skills just aren't that good I guess. hehe.
I will let you all know how my project turns out and perhaps even post a link to the game. Though the latency will most likely render it not playable over the internet.
Thanks again.
Magnus
#20 11 years ago
I never really captured why you would do this... but yea the many stages of video buffering, packet buffering and playback streaming will make this unplayable. I bet there's a 3 second lag at least.
$ 19.95
$ 45.95
5,000 (OBO)
Newtown, CT
$ 18.95
$ 18.95
$ 17.00
Nordic Pinball Supply
Gweem's Mods
6,995 (OBO)
Plantsville, CT
$ 18.95
This page was printed from https://pinside.com/pinball/forum/topic/detect-running-game and we tried optimising it for printing. Some page elements may have been deliberately hidden.
