I was so close to being done with my DESW but now I have run into an issue. After being disassembled for quite some time I finally put everything back together and had the game running. I ran a few test games to ensure everything was working. I did notice that when a ball went down the left lane, the laser kick would kind of stutter and not shoot the ball back into play. After a couple of tries, the coil began to function properly and shoot balls back out into the playing area.
Not sure if there is any relation to the following but for completeness sake, after the above tests I did the following:
- powered off the game and re-ran the wiring from inside the cabinet up to the backbox (I originally ran the wire bundle up the middle of the three holes between the backbox and cabinet. This was causing issues putting the playfield down in play position due to the bundle interfering with the light sockets on the back of the playfield and back playfield wall).
- I installed LEDs under the playfield while the game was in lamp test mode
After the above, I powered down the game and placed the playfield down. Upon power up I hear and see the laser kick coil energize and stay energized and then I smell that smell. I immediately power off and grab the manual. Q1 on the PPB drives the laser kick coil. I check the backbox and sure enough, it's toast. I pull the board and replace the TIP36c and diode for Q1. I think I may have had to replace the transistor at Q1 before (I have had the pin for two years and it has been disassembled for just about that long so forgot but I'm fairly certain) so just for safe measures I also replace the laser kick coil with a brand new one.
I checked all connections in the backbox and underneath the playfield and they look good. I power the game on again and same result; laser kick coil stuck on and smoke from the TIP36c at Q1.
What am I missing? What should I be looking at as the culprit?
- Mike
