I've recently purchased a WPC-standard flatpack from Virtuapin. I'm using it for a real homebrew pin. However, there are no holes for mounting the hardware that the playfield rests on. I'm really new to pinball design, and there doesn't seem to be much out there showing how playfields are mounted inside the cabinet. Coming here for help!
1. Are playfields mounted parallel to the bottom wall of the cabinet, and then tilted via raising the back legs? Or are they mounted at the correct slope within the cabinet with respect to the ground, with all the legs the same height (and then slight adjustments on the legs after).
2. Does anyone have any resources to point me to that show example positions of the mounting hardware within the cabinet that I can use as a starting point?
Thanks so much!
