Hello again got a problem with my demoman pinball all the coils except for the flippers are weak! For example the ball launcher isn't able to drop the ball and if i drop a ball in the upper-right hole the coil is too week to pull it out
I have tested the power board TP points since looking on the web the problem could be here.. these are the results:
TP1=13.3V (should be 12V)
TP2=5V (should be 5V)
TP3=12V (should be 12V)
TP6=68V (should be 50V)
TP7=1V (should be 20V) !!!
TP8=15.3V (should be 18V)
As you can see there are clearly some problems, but I really don't know where to look for the cause!
I have also tested the power on some coils --flippers are 43/45v and the ball launcher 63/64v
What do you think of the results? Any suggestion on what to do?
Thank you!!!!
