I just cant get this thing to work. First all of the optos didn't work. Now a whole bunch of switched don't work. Left inlane, Right outlane, Bottom popper (underground), shooter, Left ramp make, side ramp make, Right ramp enter, etc.. They all work in switch test.
Had some battery leakage originally. had the board repaired. Ive switched the CPU Board Power driver board and opto board with both judge Dredd and STTNG. They all work fine in those games and ALL act the same in DM. The CPU connectors had some corrosion on them I replaced them and have used my DMM to follow each wire to where the should go and do a continuity check. All are making connections. I don't know what to look for anymore. Ive even switched cable ribbons with the other games and same result. Any suggestions are welcome. Thanks.
