This LED fix whirlwind has caused much confusion. But also been a learning experience that is highly appreciated. I did not realise, that the "ghost fix" that was introduced by ??? in 2011 (thanks) was infact inspired by an upgrade in the lamp refresh procedure that Williams did themselves in 1994. No offense to the "ghost fix" but this legitimises the change to me. My thought about it was, that if it fixes how LED lamps appear, does that then make incadecent lamps worse.
I have decided to start using this upgrade. Which should make the mods work with LEDs out of the box. No need for secondary patching. And to update the previously released mods: Addams, Creature, Getaway and Demolition Man LX-4.
The Demolition Man LH-6, and the mod version of this, is already upgraded AND SHOULD NOT NEED TO BE PATCHED FOR NO LED GHOSTING.
If some of you experience that the Demolition Man LH-6 (factory and mod) has LED lamps appear as ghosting, please let me know.
If some of you would like to test the Demolition Man LX-4 mod with the no ghost change applied, please let me know.
