Quoted from donjagra:
I also fail to see how it's any different than suggesting using a $40 daughter board that only works half of the time.
I never recommend it for fixing the reset issue. I think it's an acceptible temporary measure and can assist with troubleshooting at times, but it's band aid fix. I always recommend that it's better to solve the actual source of the problem. I keep one in my toolkit when going to shows in case of an unexpected problem, but that's about it.
There are quite a number of threads about psu5 issues.
That's why I'm suggesting that you should diagnose the issue first to see if it's actually a problem. You're jumping straight to a conclusion.
Why do you say that? Yes, there can be some nominal variance of a couple hundredths of a volt, but nothing that would cause a problem.
Once again, I recommend going through the troubleshooting steps in order to figure out which component(s) are contributing to the reset issue. Shotgunning the board isn't really the correct approach.
All the other components that are part of the reset check list are no longer an issue because they don't need to smooth the current.
Normally, reset issues aren't just caused by one thing. Thats why there is a procedure for testing everything in a logical manner. I'm very surprised to hear that replacing the same component on multiple wpc driver boards *always* fixes reset issues. Years ago, a similar conclusion happened where folks thought the issue was *always* caused by C5, but it wasn't.
