This thing has some bugs. I got it and the left flipper would stick in the up position. Did a full rebuild on bott two flippers. The left coil metered fine but the sleeve was so stuck, it was impossible to remove. So I replaced the coil. Game flipped fine with triggers and right flipper, but would reset the moment the left flipper button was depressed. Also, DMD had vertical bars through it at regular intervals. Reseated cables with no luck. On game reset the DMD showed fine but now none of the flippers or triggers work. Buttons on handle come up in switch edge test but not triggers or flippers.
Any suggestions? I’m out of town until Thursday and I was hoping for some suggestions when I get back home and troubleshoot. I’m not a repair expert by any means, but am learning.
