(Topic ID: 151643)
Demo Man no pop bumpers
By bankmansam
8 years ago
#1 8 years ago
The game is fairly new to me. The pop bumper work from the test menu, but not from the play field. So far I have for signal at the switch then follow bad to pwb j and i have a switching signal their also. what now? Is the problem at the pwb J ? Thanks Chris
#2 8 years ago
Do they fire at all manually? There is an adjustment that can be made underneath. It's probably not making good contact. There is a little spoon underneath that can be cleaned also.
#3 8 years ago
Go into switch test and see if the pop bumper switches are registering. If none of them are working I would check for a broken wire. Right and left pop bumpers are both in column 4 (grn-yel wire). The wire can also be broken at the switch prior to the pop bumpers.
#4 8 years ago
Yes they fire from the test menu. I did the edge test and they do not register. I have already checked for a broken wire at the board it is good. I checked the resistance from green and yellow wire to the white and orange at the main board and you can see it trip so i think that rules out a broken wire. What do i do next? Thanks Chris
#5 8 years ago
Quoted from bankmansam:
You need to check for a broken wire under the playfield around the pops.
#6 8 years ago
Sounds like you just need to clean the contacts and adjust the switch. There is a white plastic spoon that needs to be centers on the stinger that come down from the pop bumpers.
Assuming there aren't any broken wires.
To clean contacts use a business card. Pinch the card between the contacts and pull the card out. (Do this with the machine off)
Upload pics if u need to.
$ 35.95
Mitchell Lighting
$ 81.95
$ 18.95
$ 65.00
Metal-Mods
$ 329.99
Monroe Township, NJ
YouBentMyWookie
$ 9.95
$ 85.00
$ 54.95
$ 45.00
86Pixels
4,690 (Firm)
La Porte, TX
4,600
Ponte Vedra Beach, FL
3,250
Bethlehem, PA
$ 39.99
Mitchell Lighting
$ 40.00
$ 18.00
Volcano Pinball
This page was printed from https://pinside.com/pinball/forum/topic/demo-man-no-pop-bumpers and we tried optimising it for printing. Some page elements may have been deliberately hidden.
