2 questions for you good people:
1) The ramp divertor only goes about half way when it activates. The mech is nice and smooth and when I pull the plunger into the coil it's very smooth and free. Is the coil that moves the divertor like a flipper coil with drive and hold coils? If so, maybe the drive coil isn't working... can I swap it with a flipper coil? Or maybe whatever drives this is defective... what to check first?
2) in my game there is a single switch that is closed when the coin door is closed, it has 4 wires on it (connected to the outer 4 connectors), but 6 connectors (middle 2 not connected). The bracket for this switch has places for 2 switches. There are 2 wires with spade connectors not connected to anything, but they are connected together by a jumper wire.
When I open the door, I can't operate the menu buttons and get a message telling me I need to open the coin door. If I remove the jumper wire connecting the two un-connected wires it thinks I've opened the coin door and I can use the menu switches...
The question is: should these un-connected wires be connected to the two un-used middle connectors of the switch that's there, or do they go onto a 2nd switch that's actually missing? I tried connecting them to the middle 2 connectors but it didn't work, but I don't know if that's because the switch is defective, or they shouldn't be there anyway...
Sorry if this sounds more confusing than it is...
Thanks for any help!!!
