(Topic ID: 120300)
Defender Help
By CapitolAuctions
9 years ago
  • 12 posts
  • 3 Pinsiders participating
  • Latest reply 8 years ago by TOK
#1 9 years ago
I know this is probably the wrong forum, but any help would be appreciated.
My Defender will not start a new game. I set #17 for free play(1) and scroll through all of the settings, close the door, push 1 player or 2 player start, and then nothing happens. I have checked the 1 player and 2 player buttons, and they appear to be working fine, I have jumpered the pins on the start buttons, and that does not work. The coin door switch is operating correctly.
On power up, it passes the initial tests, and the screen shows the attract mode, and all appears to work fine.
I have also played around with the settings, taking it off of free play, enabling the coin mech, and adding credits, and a game still will not start.
The machine was working great up until it stopped working, LOL
Thanks for any input.
#2 9 years ago
Check trough switches. It may not be detecting all balls (you have all 3 balls in the game, right?)
#3 9 years ago
Maybe I should have mentioned that this is the Williams Defender, arcade machine, not pinball. I know this is the wrong forum, but there is so much knowledge out there, that I thought I would give it a shot.
#4 9 years ago
Thanks for the response Fuko
#5 9 years ago
That is a key piece of info. I would try searching / posting on the klov forums at arcade-museum.com
Lots of classic Williams arcade expertise there
Super exclusive ad from the Pinside Marketplace!
#7 9 years ago
There is a little board with a ribbon cable that transfers control panel inputs to the game boards (commonly referred to as widget board). These ribbon cables are notoriously flakey. Squeeze each connector and see if you can get them to re-seat.
They're problematic because one end unplugs and the other doesn't. I can tell you I've dealt with your issue PLENTY of times!
#8 9 years ago
Thank you so much for the help. I have not had any luck. The wiring from the 1 player and 2 player start buttons to the widget board checks good.
I am thinking it may be the widget board.
#9 9 years ago
I found a widget board on E-Bay, replaced it, and the machine is now working great. Thanks for all of the input.
#10 9 years ago
Glad you got it going!
Its a blessing and a curse the way the old Williams games are made. More to go wrong, but since each section is separate stuff is easy to replace. The sound board on Stargate crapped out, and I was able to replace it with spare Robotron sound board I had.
1 month later
#11 8 years ago
Now for my next issue. The screen flickers sometimes. I know it makes it tougher to troubleshoot when it is not all of the time. Any suggestions on where to look. Thank you so much for the help.
#12 8 years ago
Do you have a way of isolating whether this is a board or monitor issue? I'm leaning toward monitor just based on the way my Williams games have crapped out. Board problems have typically been graphical corruption (mountains in Defender all over the screen), or a reset to the "rug" pattern.
$ 12.50
RoyGBev Pinball
Tools
Pincoder Store
Monrovia, MD
This page was printed from https://pinside.com/pinball/forum/topic/defender-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
