I too would fill it & paint it black
Congrats on a $3400 LOTR sir!
If someone offered me $1600 to scratch my PF odds are I'd let em lol
Yeah, im going to attempt this weekend, just not sure if i should use wood filler or epoxy yet. Anybody know what makes a good clearcoat/ protectant for touch-ups on playfields?
yes, it can be fixed. Won't be cheap to fix tho. And a ton of work, because you have to strip the playfield and send it to one of us restorers. On the plus side, you will have extra clear on your field that should last forever from wear.
looks like a broken, bad or forgotten bushing for the balrog caused that.
Looks like a nice game! Too bad about the scratch.
From the picts I can't tell exactly how deep the scratch is. Maybe, because the surrounding area is dark, the light wood really stands out. If I were in your shoes I would consider using paint to fix it. Use an enamel, oil-based paint. Paint the gouge with black. Use light coats and give it a day to dry in between coats. Gradually you can build it up to be level with the playfield. No need for clear. You can try your hand at mixing some gray and other colors to "blend" into the surrounding areas. Might not be perfect but it will be cheap and you can do it yourself.
If it really is deep than I'd be worried that wood filler. Might not adhere well enough to put up with abuse from air balls.
Good luck!
Matt
he has to clear his touchups or don't even bother because the ball will wear them back off in no time.
Quoted from DarkWizard:I have to admit this thread scares the crap out of me.
Quoted from Elevatorman:How so?
Because he also owns LoTR and didn't realize until seeing this thread that the same thing might happen to his game some day.
Quoted from ccbiggsoo7:Deep gouge in lotr.
Saw the title of this thread and thought it meant you paid waaaay too much for your game.
Quoted from CaptainNeo:he has to clear his touchups or don't even bother because the ball will wear them back off in no time.
Correct. Otherwise it will be a constant repair job. Seal the wood with clear in a syringe to lock in the loose wood fibers, waterslide or touch-up on top, then clear over again. Some sanding would be involved and buffing, and it would be a bit tricky as a spot repair, but nothing compared to the amount of work involved with a full tear-down.
got a friend with a airbrush and a talent out of this world, he said he'd airbrush it after I get it leveled. I have a lot more faith in his skills then I do my own.
Quoted from ccbiggsoo7:got a friend with a airbrush and a talent out of this world, he said he'd airbrush it after I get it leveled. I have a lot more faith in his skills then I do my own.
It's good to have all sorts of friends with different skills. Post a pic when fixed.
There was a guy who posted pics of lotr cabinet he hand painted. It blew me away...peeps have mad skill and patience.
Quoted from DarkWizard:How hard is it to take this chap off? Seems like quite the undertaking just eyballing it.
Piece of cake. Disconnect the wiring harness underneath and pull the cotter pin on the top. It slides right off.
Quoted from ccbiggsoo7:trying to find thread, no luck. would love to see it!
https://pinside.com/pinball/forum/topic/restoring-a-lord-of-the-rings-cabinet-lotr
This thread still scares the crap out of me; I THINK mine are lock-tited already... I remember trying to disassemble this area to replace the rubbers and gave up as the hex posts seemed stuck...
This was years ago and my understanding of the mech was limited to me futzing around and not getting much done.
At the end of the day, putting white rubbers on did not seem worth the hassle for this part of the game.
Quoted from BC_Gambit:I THINK mine are lock-tited already...
You had me at lock tit.
This page was printed from https://pinside.com/pinball/forum/topic/deep-gouge-in-lotr/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
