Has anyone ever had this issue? The coil assembly rattled everything loose one time and ever since our posts that pop up to stop the ball on the Deathstar shot won't stay in a position that will allow them to fall back down with just the strength of the spring as it's intended. I put on a sturdier spring today hoping it would fix the issue and after I tightened everything down again it worked for a while, but then rattles loose and jams up again. It seems no matter what I cannot get everything associated with that coil too stay locked down and the stops sooner or later will jam and not go back into the PF.
