(Topic ID: 278894)
Dealers Choice Start up Problem
By Kickout
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 3 years ago by Kickout
#1 3 years ago
Working on a Williams Dealers Choice.
Plug pin in
turn on toggle switch
G.O re. Latches
Drop coin in
Coin re does not activate
Press L. Flipper
Lock re. Locks
No Playfield or backglass lights. (Possible Bad connection? Cleaning Jones plus)
No Flippers ?
Check all fuses correct fuses installed.
Any ideas or help is well appreciated.
Kickout
BF881C02-4085-4CD8-95A7-96FD039A0002 (resized).jpegBF881C02-4085-4CD8-95A7-96FD039A0002 (resized).jpeg
#2 3 years ago
If the Replay button doesn't activate the Replay relay, Inspect and diagnose this circuit with Alligator clip jumper wires
http://www.planetimming.com/Pinball/troubleshooting/EM%20Troubleshooting.pdf
http://www.pinrepair.com/em/index3.htm#features
Example of a pinsider actually doing this https://pinside.com/pinball/forum/topic/red-baron-tech-question#post-5858156
#3 3 years ago
Quoted from Kickout:
No Flippers ?
Check fuses.
Capture (resized).pngCapture (resized).pngCapture1 (resized).PNGCapture1 (resized).PNG
#4 3 years ago
HowardR
If I am following your statement I would put a jumper on the yellow wire off the transformer And them touch the white/brown wire on the Replay re. If it fires then I would drop back to Game Over re switch, and keep doing this until I find where the Replay re does not fire. Is this correct.
Kickout
#5 3 years ago
HowardR
Kickout
Roughly, yes. Some switches along the way will already be closed and those can be tested how you said. Other switches will be open and you'll have to close those manually and/or close them in game operation.
Does that make sense?
#6 3 years ago
HowardR
Yes it does, I will be working on it today.
This page was printed from https://pinside.com/pinball/forum/topic/dealers-choice-start-up-problem and we tried optimising it for printing. Some page elements may have been deliberately hidden.
