Have a few questions about DP:
1) If you've made progress towards a Team-Up but you started a Battle before you got the Team-Up, does the progress count for the next Battle or it erased?
2) If you drain before you cashed in your weapons at the scoop are they lost?
3) When fighting a Villain teamed up with Sauron it seems like all damage stops until you hit the Sauron shots.. If you have a Team-up can you hit that shot for damage instead of hitting the Sauron shots or will it not do any damage?
4) Does damage from Team-up shots do damage to Juggernaut before the drops have been hit?
5) I know you can bring Ninja Multi-ball into Quests but can you bring it into the Villain modes too?
6) In the final wizard mode (Part III) what happens if you run out of time before you hit the 4 Team-up shots? Also, it appears you only have to hit the Team-up shots for the Team-ups you currently don't have, is this correct?
