Recently started noticing an issue with my Deadpool pro. Seemed to be after the code update. I tried a full install again and no changes. Wondering if anyone else has seen this or if my issue is something else.
The insert lights will randomly flash...mostly when I hit the flipper buttons. The top lanes RGB arrows, and the mode or enemy and playfield multiplier inserts will flash and blink randomly now.
Not sure if it is something I need to contact Stern about or something I can fix myself. Wondering if anyone has had this problem and how you solved it.
