New! Dark mode!
(Topic ID: 240536)
deadpool 1.00
By thunderking50
1 year ago
  • 9 posts
  • 8 Pinsiders participating
  • Latest reply 1 year ago by HighProtein
#1 1 year ago
LE V1.00.0 - April 9, 2019
- Added Modes:
- Mr. Sinister: The Megakrakolodonus Rex
- Battle the Megakrakolodonus Rex.
- Hit blue shots to reveal his weak spot at the Lil Deadpool target.
- While he is in a weakened state, hit his weak spot at the
Lil Deadpool target for big points.
- Mr. Sinister: The Final Battle
- Defeat Mr. Sinister.
- Phase 1
- Timed single ball mode: 45 seconds
- Collect the 4 Teamup shots
- Phase 2
- Timed multiball: 70 seconds
- Shoot blue shots to collect jackpots until time runs out.
- Lit Teamup shots double jackpot value.
- Hit final shot for big points in the last 15 seconds of the multiball.
- When mode ends, all balls drain, and a new ball is served to shooter lane.
- Mode Progression Updated:
- Complete Juggernaut, Mystique, and Sabretooth Battles
to light Sauron Multiball
- Complete Sauron Multiball
to light Juggernaut, Mystique, and Sabretooth Sauron Teamup Battles
- Complete T-Rex Quest, Megalodon Quest, Sauron Multiball
to light Mr. Sinister: The Megakrakolodonus Rex
- Complete Juggernaut, Mystique, and Sabretooth Sauron Teamup Battles
to light Mr. Sinister: Clone Multiball
- Complete Mr. Sinister: Clone Multiball
Mechsuit Multiball
to light Mr. Sinister: The Final Battle
- Complete Mr. Sinister: The Final Battle
to restart the mode progression
- High Score font size increased.
- The final tilt warning text has been changed to "DANGER DANGER".
- Lil Deadpool Multiball ball save timer increased to 10 seconds after ball is
released from Lil Deadpool Lock.
- Disco Multiball default ball save timer increased from 15 to 20 seconds.
- "Special is Lit" is awarded by Mystery and by making the final shot
in Mr. Sinister: The Final Battle.
- Added animations to Megalodon Quest, T-Rex Quest, Sauron Multiball, Mechsuit Multiball,
Ninja Multiball, Colossus/Sauron Teamup Battle, Mystique/Sauron Teamup Battle,
Sabretooth/Sauron Teamup Battle, BAM! top lane completion, and Colossal Jackpot.
- Added Instant Info.
- Added and improved light shows
- Polished speech in modes.
- Deadpool Pinball tutorial videos added to attract mode.
- Fixed: With a Battle or Quest lit and enough weapons banked to light Mechsuit Multiball
on the next Weapon Jackpot shot to the scoop, shooting the scoop will collect the
Weapon Jackpot, award "Light Mechsuit Multiball", and then display the Mode Select
screen, but does not allow you to start a mode.
- Fixed: starting Disco Multiball caused a stall in the game while content loaded.
- Fixed: Sauron Multiball - with 2 balls in play, locking a ball in the Katana Handle Lock
would end Sauron Multiball.
- Fixed: the HELLHOUSE EJECT switch was reported as SWITCH #2 in the Tech Alert screen.
- DIAGNOSTICS MENU: SOUND/SPEAKER TEST: Added music, speech, and sound effects.
- Adjustment: DISCO GI BRIGHTNESS (Default: DIM)
DARK, DIM, BRIGHT, VERY BRIGHT
- Adjustment: START GAME ON CREDIT moved from Feature Adjustments
to Standard Adjustments.
- System V2.26:
- Updated to nodeboard firmware v0.38.0
- Updated TechAlert switch numbering to be consistent with the game manuals.
- Added Standard Adjustment #57 "PRICING FORMAT". Values are:
"STANDARD", "MINIMAL", "STD W/ MONETARY SYMBOL", and "MIN W/ MONETARY SYMBOL".
"MINIMAL" will replace consecutive identical coin/credit increments with "..".
"MONETARY SYMBOL" will add the leading or trail monetary symbol appropriate
for the currency is use. For CUSTOM PRICING this can be TOKEN, COIN, SWIPE,
or TAP.
USA 13 (as opposed to the currect active GAME PRICING) is used to demonstrate
the effects of the different options in the Service Menu as there is a
difference between STANDARD and MINIMAL formatting. (and there may not be in the current
active pricing).
STANDARD - USA 13 would be formatted as: 1/1.00 2/2.00 3/3.00 4/4.00 7/5.00
- USA 7 would be formatted as: 1/0.50 2/1.00 4/1.50 6/2.00
MINIMAL - USA 13 would be formatted as: 1/1.00 .. 7/5.00
- USA 7 would be formatted as: 1/0.50 .. 4/1.50 6/2.00
STD W/ MONETARY SYMBOL - USA 13 would be formatted as: 1/$1.00 2/$2.00 3/$3.00 4/$4.00 7/$5.00
- USA 7 would be formatted as: 1/$0.50 2/$1.00 4/$1.50 $6/2.00
MIN W/ MONETARY SYMBOL - USA 13 would be formatted as: 1/$1.00 .. 7/$5.00
- USA 7 would be formatted as: 1/$0.50 .. 4/$1.50 $6/2.00
- Updated Custom Pricing Editor to display using Pricing Format. Use <BACK and NEXT>
to select the pricing and EDIT to change the Pricing Format. The
Pricing Format adjustment will also be updated upon EXIT.
- Updated Custom Pricing Editor - Uses button navigation to select and edit
fields. Use <BACK and NEXT> to select the "CREDIT" or "AT:" field and
EDIT to change their value. RESET has the options of setting the
custom price to the FACTORY default or CURRENT pricing as a starting
point for creating the custom price. RESET can also CLEAR the custom price
to create one from scratch. Use EXIT to save and install the custom
price. Added support to specify money format descriptions for: country
monetary symbol ("$", "EUR", etc), "TOKEN", "COIN", and "SWIPE".
- Updated Custom Coin Door Editor - RESET has the options of setting the
custom coin door to the FACTORY default or CURRENT settings as a starting
point for creating the custom coin door. RESET can also CLEAR the custom
coin door to create one from scratch. Added error message when attempting
to EXIT when the custom coin door is not valid (UNITS PER PULSE is zero or
all coin switches have zero PULSES set).
- Updated Euro Coin Door/Electronic Coin Mech configuration.
Standard Euro Coin Door now configured as:
"10 units per pulse, Left 5, Center 10, Right 20, 4th 2, 5th 0, 6th 0"
Italian Euro Coin Door now configured as:
"10 units per pulse, Left 5, Center 1, Right 5, 4th 1, 5th 0, 6th 0"
- Updated Pricing Table:
Updated Australia 5 from "1/$2.00, 2/$5.00, 5/$10.00 AU" to "1/$2.00 AU, 2/$3.00 AU"
Removed Australia 7 "1/$2.00, 3/$4.00, 4/$5.00 AU"
Removed Italy 1 "1/EUR 0.50"
Removed Italy 2 "1/EUR 1.00, 3/EUR 2.00"
Added New Zealand 3 "1/$2 NZ, 2/$3 NZ"
Updated Switzerland 2 from "1/1 SwF, 3/2 SwF, 5/3 SwF, 7/4 SwF, 9/5 SwF" to "1/2 SwF, 2/4 SwF, 3/5 SwF"
Removed Switzerland 3 "1/2 SwF, 3/5 SwF"
Updated UK 1 from "3/1.00 GBP, 7/2.00 GBP" to "1/2.00 GBP"
Updated UK 2 from "4/1.00 GBP" to "1/1.00 GBP"
Removed UK 6 "3/2.00 GBP"
Removed Portugal "1/EUR 0.50"
Removed Germany 1 "1/EUR 0.50"
Removed Germany 2 "1/EUR 0.50, 2/EUR 1.00, 3/EUR 1.50, 5/EUR 2.00"
Removed Germany 3 "1/EUR 0.50, 2/EUR 1.00, 3/EUR 1.50, 6/EUR 2.00"
Removed Euro 4 "1/EUR 0.50, 2/EUR 1.00, 3/EUR 1.50, 6/EUR 2.00"
Removed Euro 5 "1/EUR 0.50, 3/EUR 1.00, 4/EUR 1.50, 7/EUR 2.00"
Removed Euro 6 "2/EUR 0.50"
Renamed Euro 7 to Euro 4 "1/EUR 1.00, 2/EUR 2.00, 3/EUR 3.00, 5/EUR 4.00"
Renamed Euro 8 to Euro 5 "1/EUR 1.00, 3/EUR 2.00"
Renamed Euro 9 to Euro 6 "1/EUR 1.00, 2/EUR 1.50, 3/EUR 2.00"
Renamed Euro 10 to Euro 7 "1/EUR 1.00, 3/EUR 2.00, 7/EUR 3.00"
Renamed Euro 11 to Euro 8 "1/EUR 1.00, 4/EUR 2.00"
Renamed Euro 12 to Euro 9 "2/EUR 1.00, 4/EUR 2.00, 6/EUR 3.00, 9/EUR 4.00"
Removed USA 4 "1/$0.50" "25 units per pulse, Left 1, Center 1, Right 1, 4th 1, 5th 0, 6th 0"
Removed USA 6 "1/$0.50" "25 units per pulse, Left 1, Center 6, Right 1, 4th 1, 5th 0, 6th 0"
NOTE: USA 3 "1/$0.50" "25 units per pulse, Left 1, Center 4, Right 1, 4th 1, 5th 0, 6th 0" remains unchanged
Updated Austria default pricing to Euro 5
Updated Belgium default pricing to Euro 5
Updated Finland default pricing to Euro 5
Updated France default pricing to Euro 7
Updated Germany default pricing to Euro 2 and Euro Coin Door
Updated Greece default pricing to Euro 5
Updated Italy default pricing to Euro 5 and Euro Coin Door
Updated Netherlands default pricing to Euro 5
Updated Portugal default pricing to Euro 1 and Euro Coin Door
Updated Spain default pricing to Euro 5
Updated Switzerland default pricing to Switzerland 1
- Added UTIL->SAVE and UTIL->LOAD which save and restore all game settings to/from a USB thumbdrive.
- When restoring the settings to the SAME MACHINE, you can choose to restore:
"RESTORE ALL SETTINGS"
"RESTORE ALL ADJUSTMENTS"
"RESTORE ONLY STD ADJUSTMENTS"
"RESTORE ONLY HIGH SCORES"
"RESTORE ONLY AUDITS"
- When using the saved settings with another machine of the SAME TITLE and MODEL (for example
settings file created on a DeadPool Pro and restoring to a different DeadPool Pro)
- When using the saved settings with another machine of a DIFFERENT TITLE or MODEL (for example
settings file created on a DeadPool Pro and restoring to a Munsters Pro)
you can only choose to restore:
- "RESTORE ALL ADJUSTMENTS" will restore the Standard Adjustments listed below and
all Feature Adjustments.
- "RESTORE ONLY STD ADJUSTMENTS" will restore the following Standard Adjustments:
Custom Message
Custom Pricing
Custom Coin Door
"REPLAY TYPE"
"REPLAY PERCENTAGE"
"REPLAY AWARD"
"REPLAY LEVELS"
"REPLAY BOOST"
"SPECIAL LIMIT"
"SPECIAL AWARD"
"SPECIAL PERCENTAGE"
"FREE GAME LIMIT"
"EXTRA BALL LIMIT"
"EXTRA BALL PERCENTAGE"
"GAME PRICING"
"MATCH AWARD"
"MATCH PERCENTAGE"
"BALLS PER GAME"
"TILT WARNINGS"
"TILT DEBOUNCE"
"CREDIT LIMIT"
"FREE PLAY"
"KNOCKER VOLUME"
"START GAME ON CREDIT"
"GAME RESTART"
"TIMED PLUNGER"
"FLIPPER BALL LAUNCH"
"COINDOOR BALL SAVER"
"COMPETITION MODE"
"CONSOLATION BALL"
"PLAYER COMPETITION"
"TEAM SCORES"
"ALLOW HIGH SCORES"
"HIGH SCORE AWARD"
"GRAND CHAMPION AWARDS"
"HIGH SCORE #1 AWARDS"
"HIGH SCORE #2 AWARDS"
"HIGH SCORE #3 AWARDS"
"HIGH SCORE #4 AWARDS"
"HSTD INITIALS"
"HSTD RESET COUNT"
"COIN INPUT DELAY"
"LOST BALL RECOVERY"
"COIN DOOR DISABLE TILT"
"TIME FORMAT"
"FAST BOOT"
"LANGUAGE"
"PLAYER LANGUAGE SELECT"
"PLAY ATTRACT TUTORIAL VIDEOS"
"ATTRACT MODE B.BOX BRIGHTNESS"
"GAME PLAY B.BOX BRIGHTNESS"
"SERVICE MENU B.BOX BRIGHTNESS"
- Games will now persist ALL SETTINGS after a software update. This functionality will be available
in the game release AFTER the release which uses system 2.24.
-2
#2 1 year ago
Still LE’s available....
#3 1 year ago
So how does it play now ? they added modes , battle a final batlle , wow that
is freakin awesome !
they also added light show, how does it look ?
#4 1 year ago
Also updates for Munsters and BM66. Going to be a great pinball weekend.
#5 1 year ago
Nice update it's amazing how much the code has improved on this game since it was released.
#6 1 year ago
It’s epic. /thread
#7 1 year ago
I was a hater on this game initially. Now I want one I find it so fun. Good job Stern!
-2
#8 1 year ago
Ghostbusters Code !?!
What
Where
Hey I tried
Very cool that didn’t leave DP as it has tons of potential
#9 1 year ago
But isn't this just barf from the main DP thread?
$ 5,899.00
Classic Game Rooms
$ 79.95
Hookedonpinball.com
