(Topic ID: 178150)
Dead woofer replacement advice.
By Onevox
7 years ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 7 years ago by Onevox
#1 7 years ago
I have an SF2 and discovered today that the woofer is dead. I hooked up an 8" Boston Acoustics CS280 8 ohm ceiling mount speaker I had lying around and got good sound, so the sound board and wiring are good.
I'm assuming that if I simply install the BA speaker I will miss some of the low end sounds but is it a major sound omission?
The BA speaker has a 3/4" tweeter. From what I can tell, the 8 ohm speaker powered by a 4 ohm amp isn't an issue. 10-100 watts, 50Hz - 20Khz
#2 7 years ago
Turns out i can't use this speaker after all, the surround is higher than the metal mounting plate, and the tweeter is higher than the surround. Think I'll go to Parts Express for a new sub...
#3 7 years ago
I have seen alot of guys use the cheaper pyle brand woofers and say they sound great. Most sound boards dont put out much power so by spending too much on a really nice high wattage speaker is kind of a waste.
#4 7 years ago
Quoted from Onevox:
Get a VERY cheap one....you will hear no diff'rence in higher end stuff and it's just a waste of monies. You'll hear people say cheaper actually sounds better.
#5 7 years ago
If you buy a cheap modern sub is it simply plug and play? I would assume it would sound better than a 30 year old sub?
#6 7 years ago
Quoted from bam10:
just 2 wires
you assume incorrectly
#7 7 years ago
Great advice all. Got a $9 replacement speaker from parts-express and it fit perfectly, and even better sounds great.
2,000 (Firm)
Marietta, GA
$ 1.00
Pinball Alley
This page was printed from https://pinside.com/pinball/forum/topic/dead-woofer-replacement-advice and we tried optimising it for printing. Some page elements may have been deliberately hidden.
