I assume the answer is yes, but just for kicks I would like to get some feedback on what happened to me over the weekend. Maybe someone else can learn from my mistake.
Over the weekend I rebuilt a power supply/rectifier board for a Bally Harlem Globetrotters. I replaced all 3 header sets, the diodes, and bridge rectifiers per Vid's guide (thanks @vid1900!). With the power supply unit on my bench, I connected AC power to the board and flipped the switch. There was a slight pause before the scene from Back to the Future where the lightning hits the clock tower was re-enacted on my board. Yikes! Much arcing there was to be seen! When I inspected the board, I found that the arcing happened on the back between the 2 sets of diodes that feed the 230VDC circuit. Of course I was to blame due to my shoddy soldering skills. But I could not find anything amiss. I completely inspected everything for solder bridges or things hooked up incorrectly (this board was hacked by many prior operators with multiple wires bypassing the headers). I could not find anything except a dead short between pins 6 and 7 on J2 (this is the AC line in voltage connection). I messed with it some more and completely cleaned it. One thing I found was a glob of conductive grease (at least I think that's what it was since it came off the back of the old bridge rectifiers) that was on the solder side of the board bridging the gap across a couple of traces. I'm not sure if removing this is what did the trick, but after the final cleaning, the dead short on the AC line in was gone. I was able to apply power to the unit and the voltages all check out ok. Weird. I took a smaller glob of the paste and held it between my DMM probes to check for continuity. Seemed like only when the probe tips were really close I could get 80 ohms or so of resistance. Seems to me that this could not be the issue but then again I do not know what the issue could have been... Anyone else ever experience anything like this?
