We're back!
After a disaster in our datacenter took down our server, we are now running Pinside on a brand new server. However, things may not work as expected as we are still polishing the playfield and adjusting some switches! We might be switching to maintenance mode a few times. Please see this forum topic for more info.
(Topic ID: 105360)
PotC owners club: "Dead men tell no tales..."
By rai
6 years ago
  • 2,655 posts
  • 257 Pinsiders participating
  • Latest reply 1 day ago by maffewl
  • Topic is favorited by 113 Pinsiders
Topic poll
“Are you a Pirate?”
  • Arrg, I'm a Pirate 187 votes
    59%
  • I wish I were a Pirate 70 votes
    22%
  • I have no interest in Pirates 20 votes
    6%
  • I was a Pirate in the past but not at present. 40 votes
    13%
(317 votes)
There are 2655 posts in this topic. You are on page 44 of 54.
#2151 1 year ago
Hey guys (and gals),
Is there a setting to adjust coil strength? Mine seriously fire's a ball into the shooter lane from the ball trough. Apologies if I missed it, don't see it mentioned in the manual.
If not, I'm going to have to see if the solenoid coil is the right one.
Edit: Post 1859 mentions coil strength...looks like setting 43 in Standard Adjustments.
So a follow up question: Is that for all coils then?
#2152 1 year ago
Just got mine yesterday. Documented HUO, very low plays. Looks absolutely pristine.
#2153 1 year ago
Replaced stock T- molding with red.
#2154 1 year ago
Just installed pinshakers shaker motor - highly recommend - nothing like hitting the ship and having the game shake
#2155 1 year ago
Quoted from Spiderpin:
Replaced stock T- molding with red.[quoted image]
Not feeling it at all, but who cares as long as you like it.
#2156 1 year ago
Quoted from Birdnest:
I installed mine last weekend. Best upgrade on this game.
#2157 1 year ago
Quoted from woody76:
Is there a thread or post on how to do this. Sounds like a nice addition!
#2158 1 year ago
Quoted from V4Vendetta:
Is this getting better. Removed Red from top and bottom and replaced with black trim. Looking more like modern Stern game (WTD, GoT. AS, ect...)
#2159 1 year ago
Quoted from MT45:
pinshaker sells the kit, takes about 25min to install
#2160 1 year ago
Thx
#2161 1 year ago
I got the shaker about 3 years ago. Working on the flasher of the ship. Very cool effect on the kraken, extra ball, etc.
#2162 1 year ago
Opted for a raspberry red
2536201C-37D9-4A31-B2D3-9440B68E1A95 (resized).jpeg440F3638-F6E3-4D39-B4E5-4D2DE82B4B79 (resized).jpeg
Installed the air ball protector and took out ship(sneeze) guard as well. This has to be one of Stern’s best. Very underrated.
#2163 1 year ago
Quoted from volkdrive:
[quoted image][quoted image]
Nice!!
#2164 1 year ago
looks good, where did you get alt trans?
It is a great game. I added the pinshaker shaker motor a couple weeks ago - highly recommend.
#2165 1 year ago
Also installed the Pinshaker shaker motor on my POTC. All I can say is. I know it doesn't change anything to game play but makes it a whole different game. Nothing more satisfying then hitting the ship and having the shaker go off.
#2166 1 year ago
I removed the ship from my POTC yesterday in order to install the cannon led mod. Initially I connected to the wrong flasher (back middle) but I corrected my mistake and connected to the ship flasher. I also have a shaker motor which runs off the ship flasher and the spinning disk flasher. This worked fine both before and after the cannon mod. After reinstalling the ship I had several problems. Initially the sails on all the ships would drop after 1 hit, (sinking the ship took the correct number of hits) and the spinner would light the timer after 1 or 2 lights lit. After several plays the sails problem seemed to correct itself, but now the spinning disk is completed without entering this part of the playfield. Points are now continuously scored without hitting anything. Looking at the active switch menu does not indicate any wrong switches closed. Any suggestions on where I start looking to correct this problem?
#2167 1 year ago
Quoted from OTRChief:
Remove and reinstall the connectors on the opto board. I had a problem with it awarding hits to the ship after connecting shaker. Once I did this it cleared it right up. Might not be it but worth a try.
#2168 1 year ago
Quoted from arcademojo:
Thank you for your suggestion. My problem ended up being that the Tortega exit opto was blocked alligator clip that I used to install an extra green light several years ago. It must have moved due to all of the raising and lowering of the playfield.
A suggestion when working under the playfield; I use Pinball Universe Protectors to protect the inside side art during the many times I raise and lower the playfield. I found it interesting that Stern uses similar protectors when assembling and testing games.
#2169 1 year ago
I think alt trans was from Pugztoyz on eBay.....it’s been 5 yrs or so since I bought it.
1 month later
#2170 1 year ago
Has anyone done a custom sound mod for POTC with voices and music from the movies? Thanks in advance.
#2171 1 year ago
I know one version with voices from the movies.
#2172 1 year ago
Picked up one today so I’m in the club!
Not super happy with how the deal went but happy to get the game. Game was missing a sail, ramp is missing a piece about the size of a quarter and it the ship isn’t swaying/moving other than sails.
Partially my fault for trusting the guy and doing a parking lot deal, but still feels shitty.
I took the boat apart and cleaned it up. The motor seems to be spinning but noticed one of these screws that hold the clutch together won’t tighten. I’m hoping that’s the problem and the motor is spinning freely but not catching because of that.
Kind of pricey but lesson learned. I’ll try and repair first but may have to end up buying this.
https://www.marcospecialties.com/pinball-parts/500-7011-00
#2173 1 year ago
Quoted from jdoz2:
https://www.marcospecialties.com/pinball-parts/500-7011-00[quoted image]
Save a few bucks
https://www.pinballlife.com/potc-coupling-clutch-assembly.html
#2174 1 year ago
This maybe the same that you was looking for.
https://www.pinballlife.com/potc-ship-coupling-clutch.html
#2175 1 year ago
Awesome thank you! Of course I just put in a big order There
#2177 1 year ago
Got her all fixed up and working 100% minus my save setting issue which looks like it will require sending it to have someone replace my u11 on the MPU.
Really enjoying this game and it looks so good cleaned and LEDed.
#2178 1 year ago
Looking good jdoz2 I’m hopefully picking up a HUO POTC between Xmas and New Years, 300 plays since it was new, still on game looks like it just came out the box, still on release code too.
#2179 1 year ago
Quoted from jdoz2:
Really enjoying this game and it looks so good cleaned and LEDed.[quoted image]
Enjoy, I just sold mine and kind of regretting but need the room. It is super fun.
#2180 1 year ago
Quoted from jdoz2:
What’s the issue this is causing?
#2181 1 year ago
Quoted from JimB:
My mpu isn’t saving any settings so the volume and price keeps getting reset. Wouldn’t be a big issue for home use, but I’m putting this on location.
Replaced the battery and I get 3v to the correct pin on U11, but still not working. Stern tech support thinks my U11 is bad
#2182 1 year ago
Quoted from jdoz2:
Well it seems like putting a big Mylar circle over the new disk decals are required.
Really disappointed to see that after maybe 10 games, there is white flurries all over the playfield and stuck to the flippers.
Yay I get take that mech apart again
#2183 1 year ago
Quoted from jdoz2:
Hi, on this website they have 3 sizes of sppinning disk protectors
https://www.pinball.center/en/shop/pinball-parts-by-game/pirates-of-the-caribbean-stern/
Scroll down, i dont recall the size i used.
#2184 1 year ago
Hi everyone, I have 3 data east (tftc, jp, lw3) and maybe I will be able to take a POTC stern as the fourth and last pinball machine, what is better to check? How are software updates to the latest version done? I apologize for perhaps a little stupid questions but I don't technically know the pinball sterns
#2185 1 year ago
Nothing?
#2186 1 year ago
Well software opdates on POTC is via USB. So get the latest code of the stern site and upload it. Use dipswitch 8, it is in the manual. For the rest what to look for on a POTC. If the ship runs well, the display has no pixels out, the ramps, right ramp is mostly broken, shooter lane is almost always bad, Compass decal can be worn, check the opto's. For the rest I think no issues. Motor for the ship, gearbox and motor for compass plus ramps are expensive. The rest can be fixed easily with less costs.
#2187 1 year ago
Here is a link to how to update code for PotC. Latest code is 6.0 Listed under Disney’s Pirates ..
https://sternpinball.com/support/game-code/
#2188 1 year ago
Quoted from PeterG:
Where could I find that version ?
#2189 1 year ago
I have a version potc0600DS2.bin
#2190 1 year ago
Very very Thanks, the right ramp is broken... The rest should be fully functional, logically everything is to be clean ed, the board are in repair
#2191 1 year ago
I have a small issue with my POTC and I am wondering if this is a common problem. When I shoot the ship, only the first one (the interceptor), the post comes up holds the ball, and when the post drops the ball goes sdtm (8 times out of 10). The post in the retracted position protrudes about 1 mm above the playfield and the ball touches it on its way down. Should the post be flush with the playfield? The machine is level.
#2192 1 year ago
Quoted from jamex:
Very very Thanks, the right ramp is broken... The rest should be fully functional, logically everything is to be clean ed, the board are in repair[quoted image]
the right ramp is also missing the return blocking gate, seems it completely broke of. That is one dirty machine....
#2193 1 year ago
Quoted from Angel:
Yes, the post should be completely level with the playfield when down. Its a simple adjustment under the playfield.
I would try fixing the post to see if the SDTM problem resolves. It should not go SDTM after being released by the post, ever.
#2194 1 year ago
Quoted from PeterG:
If I take that, I will look for a used ramp plus a return blocking gate, I think I will have to look for it completely , only the right part exists?
#2195 1 year ago
I finally got around to putting the Zizzle figures in. I made clear plastic mounts for each one so they can mount to existing playfield screws and not be glued. I really like how Jack's hand grabs onto the rail. I have two more figures, but I think I'm liking just the three. Opinions?
IMG_20200110_192915 (resized).jpgIMG_20200110_192905 (resized).jpgIMG_20200110_192856 (resized).jpgIMG_20200110_192752 (resized).jpg
#2196 1 year ago
Very beautiful Zizzle figures
#2197 1 year ago
Has anyone made alternative sling plastics I hate the original ones
#2198 1 year ago
Quoted from mmuglia:
I finally got around to putting the Zizzle figures in. I made clear plastic mounts for each one so they can mount to existing playfield screws and not be glued. I really like how Jack's hand grabs onto the rail. I have two more figures, but I think I'm liking just the three. Opinions?[quoted image][quoted image][quoted image][quoted image]
Are you gluing them to the plastic mounts you made?
#2199 1 year ago
No. The figure is held on to the plastic mount with a screw. There's already a hole in the bottom of each foot, so it was pretty simple.
3 weeks later
#2200 1 year ago
New to the club today!
Trying to put together an order from comet. Like the warm white look with maybe a splash of color for the Gi. Any suggestions what bulbs are best? The choices are a bit overwhelming. Like the look of the comet spotlights on the sling shots too. How about the inserts, non ghosting but what shape? Any help here is appreciated. Thanks.
