I just wanted to send a note to those that will be receiving their Airball Deflectors soon. There is a protective film on BOTH sides of the deflector. One side will be a slightly translucent white, and the other side will be clear. Remove both. Once these are removed, it should be nice, shiny, and transparent. Also, these were laser cut, so when you first look at the deflector, it will appear to have burn marks around the edges. No need to worry, these burn marks are only on the protective film and not the deflector itself. Also, similar to normal pinball plastics, do NOT over-tighten the screws when installing the deflector. Below is an image of the 2 screws that hold it in place (the screw at the right side of the Tortuga ramp, and the screw behind Jack the Monkey/near the Liars Dice scoop). I place the deflector on top of the existing PotC plastics. If you have any questions, please feel free to contact me. Thanks again, it's pretty exciting to see others put an idea I created for my own machine to use.
