Went to turn on my Last Action Hero and nothing. No GI or anything. Outlet is fine, all the fuses are fine, outlet inside the machine works. Lost right now. Any help is appreciated.
When you tested all the fuses, did you pull them out of circuit?
Trace the power from the service outlet to the transformer and check the testpoints on the rectifier board.
Also, check the power connectors going to/from the rectifier board. Pull the connectors and check for char.
faz
Quoted from PinballManiac40:And you checked the fuse in the power box inside the cabinet just to the right of the coin door?
Yes
Quoted from pinball_faz:When you tested all the fuses, did you pull them out of circuit?
faz
Did not see any char. What do the test points look like on DE games?
I don't own any DE games, but I've seen them on the other four games I have.
Looking at the power driver board, it looks like the upper right corner of page 11 of the pdf.
http://mirror2.ipdb.org/files/1416/Data_East_1993_Last_Action_Hero_Schematics_BW.pdf
faz
I had an open wire one time I found on my power cable on my jurassic park.
You need to check to see if you are getting 120VAC in your machine. I would either measure the 120VAC at the input of the transformer or pull out the power box and look for any of these issues.
power switch bad
power cord with an open wire
varistor blown
Are you saying that you flip the power switch and NOTHING happens?
No lights?
No noise other than the click of the switch?
But, the service outlet works?
Chris Hibler - CARGPB #31
http://www.Team-EM.com
http://www.PinWki.com - The Place to go for Pinball Repair Info
Quoted from ChrisHibler:the service outlet works?
Definately the easier way to check to see if 120V is coming into the machine.
Quoted from pinball_faz:Looking at the power driver board, it looks like the upper right corner of page 11 of the pdf
The PPB (power driver board as you're calling it) actually is in the bottom left of the backbox mounted under the power supply. Sounds like there is no voltage getting to any of the boards.
http://www.ipdb.org/showpic.pl?id=1416&picno=26289
Quoted from pinball_faz:I meant to say the test points are on the upper right corner of the power driver board.
That must have been me reading that wrong.
Quoted from ChrisHibler:Are you saying that you flip the power switch and NOTHING happens?
No lights?
Exactly that. Nothing at all. I plugged a fan into the outlet and it worked fine.
If the GI isn't even coming on, i would assume the transformer is putting out anything. Your problem is most likely from your wall outlet to the transformer. Check these things with a dmm WITH THE GAME UNPLUGGED!!!
1) Check continuity of the power cord
2) Check to make sure everything is good in the power box, in the cabinet. line filter, power switch, ect
3) Check the xfromer input connector, and for 120VAC
Your problem has to be somewhere along those lines. And i'm assuming you checked each fuse by pulling it out and testing it with a dmm. Visually isn't good enough.
Hope this helps
If your service outlet is working, I'd assume the power switch, line fuse, or a break somewhere between the power box and xformer.
Quoted from pinball_faz:It just occurred to me. What about a main fuse? Those can be hidden near the service outlet.faz
He said he already checked the main fuse.
Yes, I have checked the main fuse. I checked the other fuses with a mulitmeter but I didnt pull them out. Is that necessary? The service outlet does work.
Quoted from PinballManiac40:He said he already checked the main fuse.
Oops... missed that post.
Quoted from Ronnie1114:Yes, I have checked the main fuse. I checked the other fuses with a mulitmeter but I didnt pull them out. Is that necessary?
Absolutely! In circuit continuity will cycle through the rest of the game. Pull the fuse and check each one with a DMM.
faz
Ok, took every fuse out one at a time and tested it..... all were good. Only thing I can think of now is that the power switch has gone bad.
Quoted from PinballManiac40:I had an open wire one time I found on my power cable on my Jurassic Park.You need to check to see if you are getting 120VAC in your machine. I would either measure the 120VAC at the input of the transformer or pull out the power box and look for any of these issues.
power switch badpower cord with an open wirevaristor blown
other possibilites too
Quoted from Ronnie1114:Nothing obviously wrong.
Do you mean visually? or did you check with a meter.
Divide and conquer:
Refer to power wiring diagram page 48 of the manual below.
Find the 9 pin connector between input junk and transformer. Pull it apart and check for AC power across pins 1&7. Flip the switch and check again. If you are getting nothing here, problem is somewhere to the left. Since you said that the AC service outlet works, that would narrow the problem down to varistor,line filter, switch or wiring between this point.
Now if you do get power, then the problem is to the right. Check 4 pin connector, 2 yellow wires for AC power (this is the AC transformer secondary that supplies the GI)
Quoted from Ronnie1114:Tested for AC Voltage and got nothing. I think ill go out and buy a new switch.
OK, I hope that's your problem. It only takes a few seconds to narrow this down with a meter.
Quoted from wayout440:OK, I hope that's your problem. It only takes a few seconds to narrow this down with a meter.
What do you mean?
Quoted from Ronnie1114:What do you mean?
He means you can set your meter to AC, probe the black and white wires leading from the switch, then switch the switch on then off. You should read power when on...no power when off. If you read no power ever, the switch is probably the problem.
You can absolutely isolate the problem to the switch by probing the outputs of the line filter. If you have power there...then it's definitely the switch.
Switches fail. I've replaced a few in my day.
Quoted from ChrisHibler:He means you can set your meter to AC, probe the black and white wires leading from the switch, then switch the switch on then off. You should read power when on...no power when off. If you read no power ever, the switch is probably the problem.
They do, and it's a easy test, but it's a rare one for sure.
Replaced the switch, nothing still. What is weird, both times I tried to measure voltage out is switch I got nothing. Am I doing something wrong?
Did you test for 115VAC power at the line filter?
Quoted from Ronnie1114:Replaced the switch, nothing still. What is weird, both times I tried to measure voltage out is switch I got nothing. Am I doing something wrong?
Did you check power going into the switch? Meter on AC. Check power for power into the switch - it probably isn't even getting there.
When you replaced the fuse, did you check with a meter for AC power both going into the fuse and out of the fuse? Sometimes you can have a bad/broken fuse holder.
Now check for power at the inputs to the line filter. Have it? If you measure AC power on the input to the line filter, but not out, then the line filter is bad. If you don't have power into the line filter, power down and use a meter set for ohms/continuity and check each terminal of the service outlet to the line filter to see if there is a break in either the hot(black) or neutral(white).
Basically your problem has to be between the service outlet and the switch because the service outlet is getting power but the switch isn't. There is only three components in this part of the circuit: The varistor, line filter, and fuse. You can eliminate the varistor, because if it were shorted you would blow the fuse and if it is open, it has no effect. You can then eliminate the other two with meter measurements in and out. All that is left from there is the wiring between them.
I tried metering both sets of black and white wires on either side of the line filter. It didn't show anything, I don't think I'm doing anything wrong, but I'm no expert
Ronnie,
You could save yourself time by performing the tests that we've detailed.
Wayout has a good set of steps.
To be very clear,
...meter on AC volts, or 200 VAC, depending on the type of meter you have.
...black probe on the solder joint where the black line power wire enters the line filter box.
...red probe on the solder joint where the white line power wire enters the line filter box.
Got about 115VAC?
Quoted from ChrisHibler:Ronnie,
To be very clear,
Got about 115VAC?
I'm saying that, I did that and didn't get anything. Sorry for any confusion
Quoted from Ronnie1114:I tried metering both sets of black and white wires on either side of the line filter. It didn't show anything, I don't think I'm doing anything wrong, but I'm no expert
Call me if you want some phone help. 313-268-oh five four 0ne
Quoted from Ronnie1114:I'm saying that, I did that and didn't get anything. Sorry for any confusion
Yes. That's what is confusing. Once testing for power at the line filter box failed, there was no reason to replace the switch. I assumed the test for power at the line filter was successful since you replaced he switch. That didn't add up. That's what confused me.
Quoted from eavedesian:Call me if you want some phone help. 313-268-oh five four 0ne
Nice Eric.
What a nice offer. Thank you for your help chris.
Talked with Eric, very helpful. Turns out the the likely culprit is the bill acceptor pulling too much voltage, which in turn shorted the line filter. I NEVER would have guessed that. Guess a new line filter is in order. Almost blew myself up during the process as well.
Yup, Eric's a good guy, even if he is a Detroit Tiger fan.
Quoted from Ronnie1114:Almost blew myself up during the process as well.
We're glad you didn't!
Well done Eric / Chris. Watching from the cheap seats...always learning.
Glad you made it out alive Ronnie!
faz
Quoted from pinball_faz:Well done Eric / Chris. Watching from the cheap seats...always learning.
faz
I am too. Only shaved about 5 years off my life.
Quoted from eavedesian:Current Ronnie....pulling too much current.
Pool or pond.... pond for you!
or
220, 221 ...whatever it takes
Details...
faz
This page was printed from https://pinside.com/pinball/forum/topic/dead-lah and we tried optimising it for printing. Some page elements may have been deliberately hidden.
